首页 > 连接器 插头附件
[问题求助] ipod 30Pin连接器
P:2011-10-10 16:07:24
资料没附上,连结不上,辛苦自己看一下
iphone接口定义英文版的:
This connector is used on iPod (starting from 3rd generation) and iPhone. It is used to connect the iPod or iPhone to various devices: PC (via USB or FireWire IEEE1394), audio amplifier, serial device (controlled via the Apple Accessory Protocol).
Pin Signal Description
1 GND Ground (-), internaly connected with Pin 2 on iPod motherboard
2 GND Audio and Video ground (-), internaly connected with Pin 2 on iPod motherboard
3 Right Line Out - R (+) (Audio output, right channel)
4 Left Line Out - L(+) (Audio output, left channel)
5 Right In Line In - R (+)
6 Left In Line In - L (+)
8 Video Out Composite video output (only when the slideshow mode is active on iPod Photo)
9 S-Video Chrominance output for iPod Color, Photo only
10 S-Video Luminance output for iPod Color, Photo only
11 GND Serial GND
12 Tx ipod sending line, Serial TxD
13 Rx ipod receiving line, Serial RxD
14 NC
15 GND Ground (-), internaly connected with pin 16 on iPod motherboard
16 GND USB GND (-), internaly connected with pin 15 on iPod motherboard
17 NC
18 3.3V 3.3V Power (+)
Stepped up to provide +5 VDC to USB on iPod Camera Connector.
If iPod is put to sleep while Camera Connector is present, +5 VDC at this pin slowly drains back to 0 VDC.
19,20 +12V Firewire Power 12 VDC (+)
21 Accessory Indicator/Serial enable Different resistances indicate accessory type:
1KOhm - iPod docking station, beeps when connected
10KOhm - Takes some iPods into photo import mode
500KOhm - related to serial communication / used to enable serial communications Used in Dension Ice Link Plus car interface
1MOhm - Belkin auto adaptor, iPod shuts down automatically when power disconnected Connecting pin 21 to ground with a 1MOhm resistor does stop the ipod when power (i.e. Firewire-12V) is cut. Looks to be that when this pin is grounded it closes a switch so that on loss of power the Ipod shuts off. Dock has the same Resistor.
22 TPA (-) FireWire Data TPA (-)
23 5 VDC (+) USB Power 5 VDC (+)
24 TPA (+) FireWire Data TPA (+)
25 Data (-) USB Data (-)
26 TPB (-) FireWire Data TPB (-)
27 Data (+) USB Data (+)
Pins 25 and 27 may be used in different manner. To force the iPod 5G to charge in any case, when 'USB Power 5 VDC' (pin 23) is fed, 25 must be connected to 5V through a 10KOhm resistor, and 27 must be connected to the Ground (for example: pin 1) with a 10KOhm resistor.
28 TPB (+) FireWire Data TPB (+)
29,30 GND FireWire Ground (-)
production-line - 生产线,生产流水线 (0) 投诉
