[HDMI] 求HDMI不解的地方
P:2010-11-18 17:35:01
今天HDMI发出什么通知,关于LOGO方面的,先不提,
下面这些小弟一直不清楚他们之间的区别,请高人详解一下:
  • Standard HDMI? Cable
  • Standard HDMI? Cable with Ethernet
  • Standard Automotive HDMI? Cable
  • High Speed HDMI? Cable
  • High Speed HDMI? Cable with Ethernet
  • VQA - Vendor Quality Assurance 供货商质量保证 (0) 投诉
    P:2010-11-18 22:51:06
    temperature controller - 温度控制仪,温度调节器 (0) 投诉
    P:2010-11-19 10:47:48
    Important Notice to Manufacturers and Resellers of HDMI Cables
    PLEASE TAKE TIME TO REVIEW THESE CHANGES AS THEY MAY HAVE A DIRECT IMPACT ON YOUR BUSINESS
    As of November 18, 2010, important changes to the way HDMI cable products are sold and marketed go into effect.
    The following are now mandatory for cable products.
    • You shall not use HDMI version numbers in the labeling, packaging, or promotion of any cable product. This includes releases of the HDMI specification (for example, HDMI 1.3, etc.), interim version numbers (for example, HDMI 1.3a, etc.) and CTS (Compliance Test Specification) version numbers (for example, 1.2, 1.3c, etc.).
    • All cables shall be labeled, both on the cable itself and on the front of the cable packaging, with the appropriate cable name (see below). As of November 18, 2010, compliance will be mandatory.
      • Standard HDMI® Cable
      • Standard HDMI® Cable with Ethernet
      • Standard Automotive HDMI® Cable
      • High Speed HDMI® Cable
      • High Speed HDMI® Cable with Ethernet
    • You shall label the physical cable based on the requirements listed in Section 5.2 of the Adopted Trademark and Logo Usage Guidelines.
    • All packaging for HDMI cables shall clearly indicate the cable type by using the Cable Type Logos shown in Section 5.3 of the Adopted Trademark and Logo Usage Guidelines.
    In order to enforce the cable market and ensure that only compliant HDMI cables are sold in the market, HDMI Licensing, LLC has been working with Custom and Border Protection agencies in the US, Europe and China. These agencies will evaluate imported and exported HDMI cable products based on their compliance with all aspects of the Adopter Agreement including these latest marketing requirements. HDMI Licensing, LLC strongly recommends that all Adopters abide by these requirements in order to ensure that there is no disruption to your business.
    For more information, please reference the latest Adopted Trademark and Logo Usage Guidelines. To download a copy, please visit http://www.--hdmi.org/logosphotos/atlug.aspx
    _____________________
    Charlene Wan
    Tel: (408) 616-1549
    HDMI Licensing, LLC
    www.--hdmi.org
    Click to view this email in a browser
    If you no longer wish to receive these emails, please reply to this message with "Unsubscribe" in the subject line or simply click on the following link: Unsubscribe
    HDMI Licensing, LLC
    1060 Arques Av
    Sunnyvale, California 94085
    Read the VerticalResponse marketing policy.
    edge radius - (扇形导体的)弯边半径 (0) 投诉
    P:2010-11-19 17:06:42
    shaper - 成型机,整形器 (0) 投诉
    P:2010-11-20 09:25:44
    我也收到了,
    prespiralled conductor - 预扭线芯 (0) 投诉
    P:2010-12-14 12:14:42
    因为HDMI本来版本有1.3升版到1.4,
  • Standard HDMI® Cable  为HDMI 1.3 cat1
  • Standard HDMI® Cable with Ethernet  为HDMI 1.4 cat1
  • Standard Automotive HDMI® Cable   汽车用线
  • High Speed HDMI® Cable  为HDMI 1.3 cat2
  • High Speed HDMI® Cable with Ethernet   为HDMI 1.4 cat2
  • ACM - Association for Computering Machinery(美国)计算机协会 (0) 投诉
    P:2010-12-14 16:53:55
    楼上的兄弟会误导观众呀,HDMI1.4出来了就没有1.3了,上面五种都是HDMI1.4的。
    CJNTR - cable jointer电[光]缆连接器 (0) 投诉
    P:2010-12-15 18:06:24
    6楼说的解释的很清楚
    cogging - 接头 (0) 投诉
    P:2011-01-19 09:35:27
    说的是跟1.3CAT1一样 虽然不叫1.3了
    artificial cable - 仿真电缆 (0) 投诉
    P:2011-01-19 14:28:55
    学习了,原来如此
    soldering torch - 焊炬 (0) 投诉
    P:2011-01-19 15:50:26
    Standard 是指Cat.1; High Speed是指Cat.2.
    automatic dynamic dual spooler - 自动动力双盘收线装置 (0) 投诉
    P:2011-01-21 23:08:13
    ink jet marking device - 喷墨标志装置 (0) 投诉
    P:2011-05-24 17:38:53
    經鑒定。6樓和11樓是高手
    artificial silk - 人造丝 (0) 投诉
    P:2011-08-10 13:38:03
    acid-free wi。re-cleaning system - 无酸线材清洗系统 (0) 投诉
    P:2011-08-10 16:20:03
    學買了
    lubrication point - 润滑点 (0) 投诉
    22
