[射频电缆] 电缆术语-中英文
P:2010-07-02 11:03:52
螺杆式挤出机 screw extruder
螺圈形软线 coiled cord
螺旋式绕包 helical application
螺旋式绕包 to apply helically
螺旋式绕包 to apply spirally
螺旋式绕包机 spiral wrapping machine
螺旋芯软线 spiral-conductor flexible cord
螺旋芯软线、有弹簧的塞绳 spiral-conductor flexible cord
螺旋形导线 fish line conductor
螺旋形绕包 spiral wrap
螺旋形绕包、螺绕 helical wrapping
裸导线 uninsulated conductor
裸铜丝编织 bare copper braiding
裸线车间 workshop for bare conductor
麻包层 jute serving
麻包铅套电缆 jute serving cable
麻包头 jute covering head
麻包头 jute lapper
麻包头 jute serving head
麻绕包 jute spinner
麻绕包 jute wormings
麻绕包 jute wrapping
麻填料、填充麻 jute filler
麦加[沙特阿拉伯] Mecca
麦克风[话筒]软线 microphone cord
麦克风[话筒]软线 mike cord
毛刷式放线装置 curl flyer
美国埃塞克斯集团有限公司(中国的全塑话缆从此引进) Eessex Group Inc
门式放线架 portal-type pay-off stand
门式放线架[装置] portal type pay-off
密度 Density
密封(包层)光纤 hermetic (optical) fiber
密封绕包 sealing wrap
棉纱编织 cotton braiding
棉纱编织(层) cotton braid
棉纱编织层 braided cotton covering
棉纱编织机 cotton-yarn braiding machine
模场直径 mode field diameter
模连续拉丝机 n-die continuous wiredrawer
模湿式拉丝机、八模湿拉机 wet drawing machine with 8 dies
焊接皱纹钢带护套 welding corrugated steel sheath
护套起皱 wrinkle of jacket
壁厚、绝缘[护套]厚度 wall thickness
内护套、内护层 undersheath
硬橡皮电缆护套 tough rubber cabtyre sheath
高频熔焊皱纹金属护套 toughlex sheath
挤包绝缘或护套 tubing
双活塞电缆护套挤压机 twin-ram cable sheathing press
热塑性氯化聚乙烯护套 thermoplastic chlorinated polyethylene jacket
air spaced paper-insulated core - 纸绝缘线芯(紧包的);空气纸绝缘线芯 (0) 投诉
P:2010-07-02 11:04:41
热塑性塑料绝缘及护套电缆 thermoplastic insulated and jacketed cable
挤压[挤包]铅护套、压铅 to apply the lead sheath
剥除电缆护套 to strip the cable sheath
夯实、捣固、铅护套扩张试验 tamping
丁苯合成橡皮护套 styrene-butadiene synthetic rubber jacket
在接头处护套互联的电缆系统 system with the cable sheaths connected across the joints
钢-铝-聚乙烯综合护套电缆 stalpeth cable
钢-铝-聚乙烯护套 stalpeth cover
钢-铝-聚乙烯综合护套 stalpeth sheath
钢-铝-聚乙烯综合护套电缆 stalpeth sheathed cable
钢-铝-聚乙烯综合护套 stalpeth-sheath
钢护套 steel sheath
光护套、光滑护套 smooth sheath
光滑铝护套 smooth-profile aluminium sheath
光滑护套电缆 smooth-sheathed cable
护层、护套 sheath
护套轧纹 sheath crimping
护套偏心监控仪 sheath eccentricity monitor
护套涡流损耗系数 sheath eddy current loss factor
护套绝缘环 sheath insulating ring
护套损耗 sheath loss
护套损耗 sheath losses
护套结构 sheath make-up
护套加固箍 sheath reinforcing bandage
护套的接续 sheath splice
护套的接续 sheath splicing
护套加强元件、护套加强单元 sheath strength member
护套剥除机、剥护套机 sheath stripping machine
护套表面 sheath surface
护套厚度 sheath thickness
护套换位 sheath transposition
护套(内)壁 sheath wall
护套壁厚 sheath wallthickness
护套线、被覆线 sheath wire
护套电缆 sheathed cable
固定布线用护套电缆 sheathed cable for fixed wiring
有外护套层的卷边纵包金属护套布线电缆 sheathed metal-clad wiring cable
护套线、被覆线 sheathed wire
挤[包]护套、护套 sheathing
护套混合物[料] sheathing compound
护套挤包设备 sheathing equipment
护套挤制生产线 sheathing line
护套挤出机 sheathing machine
护套材料 sheathing material
护套试样 sheathing test-piece
护套线、被覆线 sheathing wire
护套颜色 sheating color
护套工段 sheating department
单护套 single sheath
单芯电缆(有或无护套) single-core cable (with or without sheath)
内部配线用单芯无护套电缆、布线电缆 single-core non-sheath cable for internal wiring
有护套的单芯导线 single-core sheathed conductor
单护套电缆 single-jacketed cable
聚乙烯密封护套 sealpeth sheath
金属护套的无缝挤包、无缝护包金属护套 seamless extrusion of metal sheaths
自粘性外护套 self-bonding overcoat
半导体护套 semi-conducting jacket
护套剥离绳 rip cord
橡皮绝缘护套 rubber insulating blanket
橡皮护套、橡套 rubber sheath
加固型铅护套 reinforced lead sheath
增强型护套 reinforced sheathv
剥除(绝缘、护套)、拆卸 remove
铝护套电力电缆 power cable with aluminium sheath
抗压力护套 pressure-retaining sheath
护套 protective jacket
护套、护层 protective jackte
护套 protective sheath
平[光]滑护套 plain sheath
塑料护套 plastic sheath
塑料护套厚度检测装置 plastic thickness test unit
塑料[非金属]护套电缆 plastic-sheathed cable
塑料护套软线 plastic-sheathed flexible cord
氯丁橡胶护套电缆 polychloroprene sheathed cable
聚乙烯护套 polyethylene jacket
聚乙烯护套料 polyethylene jacking compound8
字形绕包聚乙烯护套 polyethylene sheath of figure-8 formation
聚乙烯护套料 polyethylene sheating compound
聚乙烯护套电缆 polyethylene-jacketed cable
铅-聚乙烯综合护套 polyethylene-protected lead sheath
聚乙烯铝膜粘接护套 polyethylene/aluminium bonded laminate sheath
聚乙烯护套电缆 polythene jacketed cable
聚乙烯绝缘聚氯乙烯护套电缆 polythene-insulated cable sheathed with PVC
聚氯乙烯绝缘及护套电缆 polyvinyl chloride insulated and sheathed cable
PC - polycarbonate聚碳酸酯 (0) 投诉
P:2010-07-02 11:05:53
聚氯乙烯护套 polyvinyl chloride jacket
护套的透潮 permeation through jacket
普通塑料护套软线 ordinary plastic-sheathed flexible cord
普通聚氯乙烯护套软线 ordinary(PVC-)sheathed flexible cord
聚合物外护套 outer polymeric sheath
外护套 outer sheath
外护套 outer shell
外护套、外护层 overcoat
外护套、外护层 oversheath
耐臭氧乙丙橡胶护套 ozone-resisting ethylene propylene rubber jacket
包套、外护套 package sheathing(
油浸)纸绝缘铅护套电缆 paper-insulated lead-covered cable(
油浸)纸绝缘铅护套电缆 paper-insulated lead-sheathed cable
纸绝缘金属护套电缆 paper-insulated metal-sheathed cable
非金属护套 non-metallic sheath
非金属护套电缆 non-metallic-sheathed cable
无护套电缆 non-sheathed cable
固定布线用无护套电缆 non-sheathed cable for fixed wiring
非金属护套 nonmetallic covering
尼龙护套电缆 nylon jacketed cable
尼龙护套光纤 nylon-jacketed optical fiber
纸绝缘金属护套充油电缆 oil-filled paper-insulated metal-sheathed cable
光缆护套挤出生产线 optical cable sheathing line
多层护套(北美采用) multilayered jacket
多层护套 multilayered sheath
多层护套、层式护套 multiple sheath
天然橡胶护套 natural rubber jacket
金属护套 metal sheath
卷边纵包金属护套布线电缆 metal-clad wiring cable
金属护套电缆 metal-sheathed cable
铜芯矿物绝缘铜护套电缆 mineral-insulated copper-sheathed cable with copper conductor
防潮护套 moisture barrier jacket
防潮护套 moisture barrier sheath
氧化镁绝缘金属护套电线 magnesia-insulated metal sheathed wire
聚乙烯-铅综合护套层、铅-聚乙烯综合护套 lepeth
铅-聚乙烯综合护套电缆 lepeth cable
铅-聚乙烯综合护套电缆 lepeth-sheath cable
轻型聚氯乙烯护套电缆 light PVC-sheathed cable
轻型塑料护套软线 light plastic-sheathed flexible cord
轻型聚氯乙烯护套软线 light(PVC) sheathed flexible cord
浅色护套 light-colored jacket
铝-聚乙烯粘接护套 laminated aluminum-polyethylene sheath
金属护套 metal sheath
层式护套、多层护套、薄层粘接护套 laminated sheath(
层状)粘接[结]带、金属-塑料综合护套用复合带 laminated tape
压铅机、电缆铅护套挤压机 lead cable-sheathing press
lower knife axle - 下刀轴(切纸机的) (0) 投诉
