首页 > 国外线缆
[问题求助] 请问各位三并RCA线能否印UL 2468?
P:2009-11-19 10:04:26
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 2 Page 2468 Issued: 1968-05-07
Style 2468 Flat Ribbon-Type Cable.
______________________________________________________________________________
Rating 80°C, 300 Volts.
Conductor 2-150, Nos. 32-16 AWG. Tinned or bare, solid or stranded
copper, conductors laid parallel and in one plane. Same
or mixed AWG.
*Insulation Each conductor has a nominal 15 mils wall or heavier
thermoplastic (PVC). This forms a flat cable with a
single row of conductors having a 1/2 in. maximum width
web between insulated conductors. The nominal and minimum
insulation thickness along the ripped edges for each
conductor shall be 15 and 13 mils, respectively.
Shield Optional.
Covering (Optional) PVC, 5 mils min. at any point 80 mils max.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
*to UL Tensile Strength and Elongation of Insulation.
*Representative Spark Test.
UL (4) Detailed Examination.
*Counter-Check (4) Tensile Strength and Elongation of Insulation.
Program (4) Heat Shock.
(4) Cold Bend.
(4) Deformation.
(12) Horizontal Flame Test.
Marking General.
Use Internal wiring of Appliances; or internal wiring of
Appliances where exposed to oil at a temperature not
exceeding 60°C or 80°C, whichever is applicable.
看下标准吧。。
scorching - 焦烧(挤出机机筒内);早期硫化 (0) 投诉
18
