首页 > 专业英语|国际贸易
[已经解决] 有奖翻译,参与即有奖励,满意的奖金币100个!
P:2009-03-05 12:34:16
翻译如下段落:
卤素的阻燃机理与无卤的阻燃机理不一(黑色为含卤素的聚氯乙烯,蓝色为无卤的聚烯烃)
含卤素的材料,由于受热时会发生分解,释放出卤化氢,卤化氢能捕捉活性的自由基HO,从而能减缓和终止燃烧链锁氧化反应,达到阻燃目的。此外卤化氢气体是难燃性的气体,它们的比重比空气重,能排代空气,形成保护层,起隔绝氧气的作用,从而使燃烧延缓或熄灭,聚氯乙烯树脂中含氯量达56.8%,树脂的氧指数更是高达42,其本身的难燃性就较好,为自熄性聚合物。
无卤的阻燃聚烯烃材料是选用聚烯烃作为基础聚合物,其基料氧指数为18,为易燃物,添加大量的Al(OH)3或Mg(OH)2而组成。聚烯烃系纯碳氢化合物,极易燃烧,燃烧时分解成水和二氧化碳,不产生明显的烟雾和有毒的腐蚀性气体。Al(OH)3或Mg(OH)2受热后会释放结晶水,吸收大量热量,从而抑制聚合物温度上升,延缓热分解,阻止燃烧。此外,脱水分解所产生的水蒸气也能稀释可燃性的气体,从而起到阻燃效果。
mesh welder - 网焊机 (0) 投诉
P:2009-03-05 13:17:57
Halogen containing materials, will happen because of the heat decomposition, releases hydrogen halide, hydrogen halide to capture the activity of free radicals HO, so that it can slow down and termination of chain combustion oxidation reaction to reach the purpose of fire-retardant. In addition halogenated flame retardant are precursors of hydrogen gas, which is heavier than air, the proportion can be scheduled on behalf of the air, the formation of protective layer, isolated from the role of oxygen, thus delaying or burning off, the chlorine content of PVC resin reached 56.8 % resin oxygen index is as high as 42, the Flame of its own on the better for the self-extinguishing polymer.
Halogen-free flame retardant polyolefin material is selected as the basis of polyolefin polymers, its oxygen index for the base material 18, as the combustible, add a large number of Al (OH) 3 or Mg (OH) 2 formed. Department of pure polyolefin hydrocarbons, easily burning, burning when broken down into water and carbon dioxide, does not produce obvious toxic smoke and corrosive gases. Al (OH) 3 or Mg (OH) 2 after heating to release crystal water, absorb substantial heat, thus inhibiting polymer temperature rise, retard thermal decomposition, to prevent burning. In addition, the dehydration produced by decomposition of water vapor can also dilute the flammable gases, which play a fire-retardant effect.
[cuijiude 在 2009-3-5 13:18:28 编辑过]
all-metal swift - 全金属绕线架,全金属绕线筒 (0) 投诉
P:2009-03-06 14:51:07
The flame retardant mechanism of halogen ang halogen-free is different(Black as the polyvinyl chloride containing halogen, blue is the halogen-free polyolefin)
Because of the materials containing halogen will decompose , release hydrogen halide,and halogenating hydrogen can capture the activity of free radicals HO when heated.Thus can slow down and terminate the oxidation reaction of combustion chains to achieve the purpose of flame retardant.Besides the gaseous halogenating hydrogen is Flame retardant gas ,and it's heavier than air so that it is able to exhaust and replace the air and form protective layer which can isolated from the oxygen.Thus burning delay or extinguished.The chlorine that PVC resin content reached 56.8 % ,and the resin oxygen index is as high as 42.
It is the self-extinguishing polymer for the flame retardant itself is good .
Halogen-free flame retardant polyolefin materials choise the polymers based on polyolefin. Its oxygen index for the base material which is combustible and add a large number of Al (OH) 3 or Mg (OH) 2 reach to 18. Polyolefin is pure hydrocarbons can be easily burning.They decompose into water and carbon dioxide, no obvious smoke and poisonous corrosive gas when burning.Al (OH) 3 or Mg (OH) 2 release crystal water and absorb substantial heat after heating .Thus restrain polymer temperature rise, retard pyrolysis, and prevent burning. In addition, the water vapor produced by dehydration decomposition can also dilute the flammable gases, which play the effect of flame retardant .
[抗倭先锋 在 2009-3-6 14:53:21 编辑过]
low boiling point liquid foaming agent - 低沸点液体发泡剂 (0) 投诉
P:2009-03-21 12:55:21
一时手痒,加上缺钱,所以也来试试。字句次序有改动以适应英语的习惯语气。
Although both halogen and halogen-free materials can be fire retardant, the mechanisms are different. (PVC with halogen content is black in color while halogen-free Polyolefin is blue)
The material containing Halogen can release Hydrogen Halide when heated. Hydrogen Halide absorbs free HO, which slows down or even terminates the chain reaction of oxidation (combustion). In addition, since Hydrogen Halide is non-flammable and heavier than air, it stays below the air and isolates the oxygen from the burning object when released. Thus the fire is confined and then extinguished. In the particular case of PVC resin, the high Chlorine content (52.8%) and oxygen index (42) also contribute to its superior non-flammable property. It is so called self-extinguishable polymer material.
On the other hand, halogen-free material comprises of base material Polyolefin and a large amount of Al(OH)3 or Mg(OH)2. Polyolefin itself is pure hydro-carbon with oxygen index of 18. It is extremely flammable and decomposes into water and CO2 when burnt, without producing visible smog or corrosive poisonous gas. Al(OH)3 or Mg(OH)2 releases water vapors as well when its crystalline framework destructed by heat. However, the vaporization of the water then absorbs significant amount of heat so that effectively stopped further material destruction and therefore extinguish the fire. Besides, water vapor itself dilutes the flammable gas and further enhances the fire retardant effect.
L.F. - low frequency低频 (0) 投诉
P:2009-05-29 10:50:36
不过还是很感谢。你的积分我加不了啊。
