首页 > 标准共享
[国外标准] BS EN 50525 德标电缆新标准(18集合)
P:2021-06-22 10:59:01
德标电缆新标准EN50525
BS EN 50525-1:2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750V (U0/U) Part 1.pdf
BS EN 50525-2-21:2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750V (0/) Part 2-21.pdf
BS EN 50525-2-22:2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750V(U0/U) Part 2-22.pdf
BS EN 50525-2-31-2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V Part 2-31.pdf
BS EN 50525-2-41-2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V.pdf
BS EN 50525-2-12:2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) Part 2-12.pdf
BS EN 50525-2-51:2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) Part 2-51.pdf
BS EN 50525-2-71-2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) Part 2-71.pdf
BS EN 50525-2-42-2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) Part 2-42.pdf
BS EN 50525-2-81-2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) Part 2-81.pdf
BS EN 50525-2-82-2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) - Part 2-82.pdf
BS EN 50525-2-83-2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) Part 2-83.pdf
BS EN 50525-3-11-2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) - Part 3-11.pdf
BS EN 50525-3-21:2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) Part 3-21.pdf
BS EN 50525-3-31-2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) - Part 3-31.pdf
BS EN 50525-3-41:2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) Part 3-41.pdf
BS EN 50525-2-72-2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U) - Part 2-72.pdf
BS EN 50525-2-11:2011 Electric cables-Low voltage energy cables of rated voltages up to and including 450/750V (U0/U) Part 2-11.pdf
quality verification test - 质量验证试验 (0) 投诉
P:2021-06-23 10:18:05
可以合成一个文件么
winch - 绞车,绞盘 (0) 投诉
P:2021-06-24 16:04:13
有的人可能不需要这么多,只要其中 的一两个或者几个哦,所以分开来了
cable column - 卷缆柱 (0) 投诉
P:2021-12-02 10:36:16
有中问版的吗
stress control tape - 应力控制带 (0) 投诉
