首页 > 专业英语|国际贸易
[有奖翻译] 有奖翻译
P:2016-10-29 10:11:17
活跃一下气氛,进行一段时间的有奖翻译 软件翻译不评分
One of the most important advantages of aluminum, other than economics, is its low density. A unit length of bare aluminum wire weighs only 48% as much as the same length of copper wire having an equivalent DC resistance. However, some of this weight advantage is lost when the conductor is insulated, because more insulation volume is required over the equivalent aluminum wire to cover the greater circumference.
single-transverse mode laser - 单横模激光器 (0) 投诉
