首页 > 企业招聘
[企业招聘] 各位线缆界精英都来看看
P:2011-09-01 16:37:18
我司研发了新产品,说明如下
XJ-300型双层热烘包带机
XJ-300型双层热烘包带机 XJ-300 type dual taping and heating machine
■极细线包带
■XJ-300型微电脑双层热烘包纸机说明:
The specification for the XJ-300 type microcomputer dual taping and heating machine:
■该款机型是应客户要求设计制作出的专门用于极细线轴装带包带用;
It is designed for the customer's latest requirement , specifically for the fine wires' taping;
■PLC+PID+伺服双盘包带+伺服引取+高频火花机在线检测+微动力收放线张力控制+高性能加热管对外层热缩膜进行加热粘合;
PLC+PID+servo dual taping heads+servo drawing+high frequency CHJ detecting on line+micro-power clutch controlling the tensions+high efficiency heater to bond the outer film;
■包带轴规格:Ø
The sizes of the film reel: Ø100*
■收线盘规格:Ø200- Ø
The sizes of the take-up bobbin: Ø200- Ø
■最高转速:1500RPM/MIN;
The max speed: 1500RPM/MIN;
■包带种类:铜箔,铝箔,麦拉带,透明带、氟塑料麦拉带等;
The material of the films: copper foil,aluminium foil,mylar,transparent tape,teflon mylar etc.
■线径范围:Ø
The diameter span of the fine wires(OD): Ø
■有断线、断带、反带、完带,火花自动停机报警装置。
The CHJ machine will stop running and alert when the wire is broken,the film is broken,the film is verso and the film is over as well.
self-supporting take-up - 自承式收线装置 (0) 投诉
