首页 > 标准讨论 培训学习
[标准信息] 求助UL 1054中文版标准
P:2009-10-08 19:53:47
哪位大哥大姐有UL1054标准,请上传一份,小弟在此谢过了
MIAM - model-independent analytic method模式独立分析法(用于通过测定成缆光纤偏振模色散系数计算出光纤的平均值、方差及三阶矩) (0) 投诉
P:2009-10-08 20:59:19
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 1 *Page 1054 Issued: May 1, 1959
Revised: June 21, 2001
Style 1054 Thermoplastic (PVC) - Insulated Wire.
______________________________________________________________________________
Rating 80°C, 600 Volts.
Conductor Nos. 18-10 AWG, stranded copper.
Insulation PVC, 60 mils min. avg., 54 mils min. at any point wall,
60°C or 80°C in oil, if applicable.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Physical Properties, unaged.
Representative
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties.
Program (4) Heat Shock.
(4) Deformation.
(4) Cold Bend.
Marking General.
Use Internal Wiring of Electric Refrigerating Equipment
or Room Air Conditioners or Room Cooler Units or
or Room Air Conditioners or Room Cooler Units where
exposed to oil at a temperature not exceeding
(60°C or 80°C, whichever is applicable).
http://www.dxdlw.com/ShowPost.aspx?ThreadID=25631
wet drawing machine with 8 dies - 8模湿式拉线机 (0) 投诉
