首页 > 新手区
[每日签到] 2025-08-02签到,你签了吗?
P:2025-08-02 00:27:36
我2025-08-02签到,获得3声望,1金币,悲剧的RP啊!明天再来试试手气吧?
blocking layer - 挡水层,阻挡层 (0) 投诉
P:2025-08-02 00:32:34
我2025-08-02签到,获得3声望,3金币,小意思小意思了,你签了吗?
extruder ring-band marker - 挤出机环带标志器 (0) 投诉
P:2025-08-02 01:47:29
我2025-08-02签到,获得1声望,1金币,悲剧的RP啊!明天再来试试手气吧?
surge voltage - 冲击波电压 (0) 投诉
P:2025-08-02 04:17:18
我2025-08-02签到,获得1声望,8金币,RP爆发了,你签了吗?
caterpillar-belt style measuring device - 履带式测量装置 (0) 投诉
P:2025-08-02 05:58:38
我2025-08-02签到,获得2声望,2金币,悲剧的RP啊!明天再来试试手气吧?
cable termination - 电缆终端(连接),电缆终端头 (0) 投诉
P:2025-08-02 06:01:53
我2025-08-02签到,获得4声望,4金币,小意思小意思了,你签了吗?
electrical heat tracing cable - 电加热跟踪电缆 (0) 投诉
P:2025-08-02 06:02:35
我2025-08-02签到,获得5声望,8金币,RP爆发了,你签了吗?
single fiber - 单纤,单光纤 (0) 投诉
P:2025-08-02 06:08:47
我2025-08-02签到,获得4声望,2金币,悲剧的RP啊!明天再来试试手气吧?
steady state mode distribution - 稳态模分布 (0) 投诉
P:2025-08-02 06:19:20
我2025-08-02签到,获得1声望,4金币,小意思小意思了,你签了吗?
circular compressed connection - 环形压接连接 (0) 投诉
P:2025-08-02 06:27:16
AO - atomic oxygen原子氧 (0) 投诉
P:2025-08-02 06:46:06
我2025-08-02签到,获得2声望,3金币,小意思小意思了,你签了吗?
capacity unbalance testing equipment - 电容不平衡测试设备 (0) 投诉
P:2025-08-02 06:52:56
sealing end vulcanized to the cable - 有硫化法固定在电缆上的密封端 (0) 投诉
P:2025-08-02 07:00:37
我2025-08-02签到,获得1声望,9金币,RP爆发了,你签了吗?
side-to-side crosstalk coupling - 实四路间串音耦合合,实路对实路的串音耦合 (0) 投诉
P:2025-08-02 07:01:40
我2025-08-02签到,获得1声望,6金币,收获还不错,你签了吗?
sophisticated dual heating system - 高级复式加热系统 (0) 投诉
P:2025-08-02 07:03:02
POTDR - polarization-optical time domain reflectometer[-try]偏振光时域反射计[法] (0) 投诉
267
