首页 > 标准求助
[标准求助] 求ICEA S-76-474-2011 NEUTRAL-SUPPORTED POWER CABLE ASSEMBLIES WITH WEATHER-RESISTANT EXTRUDED IULAT
P:2022-03-17 17:51:52
求ICEA S-76-474-2011 NEUTRAL-SUPPORTED POWER CABLE ASSEMBLIES WITH WEATHER-RESISTANT EXTRUDED INSULATION RATED 600 VOLTS 标准。先谢了!
flaring tool - 胀铅(用于把铅护套胀成喇叭口形的工具) (0) 投诉
P:2022-03-18 14:27:08
https://www.--doc88.com/p-6784830245860.html?r=1
cold-bend test - 冷弯曲试验,低温弯曲试验,低温卷绕测试 (0) 投诉
