首页 > 新手区
[每日签到] 是德E5071C 285矢量网络分析仪
P:2021-01-30 18:22:05
Keysight是德E5071C ENA 矢量网络分析仪285
主要特性和功能蒋
9 kHz 至 4.5/6.5/8.5/14/20 GHz
2 或 4 端口,50 Ω,S 参数测试仪
提供 130 dB 宽广的动态范围、8 ms 快速测量速度和 0.005 dB/℃ 温度稳定度,可改善测量精度、提高产品良率并增加设计裕量
增强时域分析选件可对高速串行互连进行全面表征,增强您对设计的信心
所有选件均可升级,保护您的投资
选件
Additional features
E5071C-010 时域分析
E5071C-790 测量向导助手(MWA)软件
E5071C-008 频率偏置模式
E5071C-TDR E5071C-TDR 增强型时域分析选件
Timebase stability
E5071C-UNQ Standard stability timebase
E5071C-1E5 High stability timebase
Calibration documentation
E5071C-1A7 Calibration + Uncertainties + Guardbanding (Not Accredited)
E5071C-A6J ANSI Z540-1-1994 Calibration
Test set
E5071C-280 2-port Test Set, 9 kHz to 8.5 GHz without Bias Tees
E5071C-285 2-port Test Set, 100 kHz to 8.5 GHz with Bias Tees
E5071C-480 4-port Test Set, 9 kHz to 8.5 GHz without Bias Tees
E5071C-485 4-port Test Set, 100 kHz to 8.5 GHz with Bias Tees
E5071C-240 2-port Test Set, 9 kHz to 4.5 GHz without Bias Tees
E5071C-245 2-port Test Set, 100 kHz to 4.5 GHz with Bias Tees
E5071C-440 4-port Test Set, 9 kHz to 4.5 GHz without Bias Tees
E5071C-2K5 2-port Test Set, 300 kHz to 20 GHz with Bias Tees
E5071C-445 4-port Test Set, 100 kHz to 4.5 GHz with Bias Tees
E5071C-4K5 4-port Test Set, 300 kHz to 20 GHz with Bias Tees
E5071C-4D5 4-port Test Set, 300 kHz to 14 GHz with Bias Tees
E5071C-465 4-port Test Set, 100 kHz to 6.5 GHz with Bias Tees
E5071C-460 4-port Test Set, 9 kHz to 6.5 GHz without Bias Tees
E5071C-2D5 2-port Test Set, 300 kHz to 14 GHz with Bias Tees
E5071C-265 2-port Test Set, 100 kHz to 6.5 GHz with Bias Tees
E5071C-260 2-port Test Set, 9 kHz to 6.5 GHz without Bias Tees
Hard disk drive options
E5071C-017 Removable Data Storage
E5071C-019 Standard Data Storage
Accessories
E5071C-1CM Rack mount kit
E5071C-1CN Front handle kit
E5071C-1CP Rack mount and front handle kit
E5071C-810 Add keyboard
E5071C-820 Add mouse
BESA - British Engineering standard Association英国工程标准协会 (0) 投诉
