首页 > 新手区
[问题求助] Pure Copper suppliers
P:2018-01-09 14:53:54
Product Description
Pure Copper Rod is available in different finish options including forged, hot rolled, extruded as well as in cold worked options in dimensional finish as demanded by the customers. These precision constituted and finished Pure Copper Rod can be also made available in hard, half-hard as well as soft finish conditions in required dimensions.
Product Show
Product Data
Grade Chart
ChinaInternational StandardUnited StatesJapanUnited KingdomGermany
T2Cu-RTPC11000C1100C101R-Cu57
TU1Cu-OFC10200C1020C110OF-Cu
TU2Cu-OFC10300C1020C103OF-Cu
TP1Cu-DLPC12000C1201
SW-Cu
TP2Cu-DHPC12200C1220C106SF-Cu
Chemical Composition
AlloyCu+
AgPAgBiSbAsFeNiPbSnSZnO
T299.9
0.0010.0020.0020.005
0.005
0.005
TU199.970.002
0.0010.0020.0020.0040.0020.0030.0020.0040.0030.002
TU299.950.002
0.0010.0020.0020.0040.0020.0040.0020.0040.0030.03
TP199.90.004-0.012
TP299.90.015-0.04
Mechanical Properties
AlloyStateTensile TestHardness Test
Thickness/mmTensile
Strength Rm/MPaPercentage Elongation After
Fracture A11.2/%Thickness/mmHVHRB
T2
TP1
TP2
TU1
TU2R0.4-14≥195≥30
M
Y1
Y2
Y
T0.3-10≥205
215-275
245-345
295-380
≥350≥30
≥25
≥8
-≥0.3≤7
60-90
80-110
90-120
≥110
Product Application
Precision engineered and finished Pure Copper Rod is available in hard, half-hard as well as in soft conditions in Extruded, Forged, Hot Rolled, as well as Cold worked options, in different dimensions. Further, our team also ensures that the copper material used making Pure Copper Rod is made available with minimum copper content of 99.99% as per IS-191.
Package and Delivery
1. Standard Exporting package.
2. Original package or neutral package.
3. According to clients ' needs.
4. Shipped in10-35 days after payment.Pure Copper suppliers
vapour cure - 蒸汽硫化 (0) 投诉
