首页 > 新手区
[电缆常识] 新意!手机可以借济南电线电缆电力
P:2014-06-23 17:02:09
<div> </div><div> 当你每次在玩手机的时候,你会不会关心手机没有电的状况啊,您如果注意到了,那济南电线电缆:http://www.--sddxxl.com/将可能会帮助到您。</div><div> When you every time when playing mobile phone, you will not care about mobile phone no electricity situation ah, if you notice, the Jinan electric wire and cable may help to you.</div><div> 听说这个实现手机共享电力,是有一个外国公司为另一个外国公司的蜂窝网络设计的共享电力的济南电线电缆。</div><div> Heard that the implementation of mobile phone sharing power, is a Foreign Company for Jinan electric power cable design of cellular network sharing anotherForeign Company</div><div> 这种的电缆在使用的时候是易操作的,只要将两头的插口分别连接到电量不足的手机和一个电量充足的手机上,简单理解可以是手机充电宝的功能,不同就是手机和手机充电</div><div> 通过济南电线电缆向B手机借点电量。</div><div> This cable is easy in use, as long as the two socket is respectively connected to the power shortage of the mobile phone and a sufficient power of mobile phone, mobile phone charger is simple to understand and can treasure function, different mobile phone and mobile phone is chargingBorrow power to the B mobile phone through the Jinan wire and cable</div><div> 如果您的手机电量充足,正好朋友的手机没有电了,您可以通过济南电线电缆为他们充电,这就节省了找充电器的时间。</div><div> If your mobile phone is a friend enough power, the mobile phone has no electricity,you can use the Jinan wire and cable for charging, which saves time for charger</div><div> http://www.--sddxxl.com/shownews.asp?id=19</div>
stranding cage - 绞笼 (0) 投诉
