首页 > 标准共享
[国外标准] UL AWM STYLE PAGE 20251 请提供原版
P:2007-05-18 00:06:21
UL AWM STYLE PAGE 20251请提供原版
gap width - 间隙宽度 (0) 投诉
P:2007-05-18 09:23:46
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 2       Page 20251       Issued:  1983-02-23
                                    Revised:  2003-08-07
Style 20251     Multi-Conductor Cord.
______________________________________________________________________________
Rating      60°C, 150 Volts, 300 Volts peak.
Conductor       Two to ten 18-33 AWG, tinned or bare, solid, stranded,
            or tinsel.  May include mixed AWG sizes.
Insulation      Polypropylene, 7 mils minimum average, 5 mils minimum
            at any point.
Shielding       (Optional) One or more may be shielded.
Jacket      PVC, Class 43, 20 mils minimum average, 16 mils minimum
            at any point.
Assembly        Cable may be either straight or wound in retractile
            form.  Core may be either flat or round.  Barrier
            layer and/or fillers optional.
Standard        Appliance Wiring Material UL 758.
Instructions    Detailed Examination.
to UL           Physical Properties, Unaged Insulation and Jacket.
Representative  Spark Test.
            Flexibility Test, unaged, if unable to perform Physical
               Properties on tinsel and/or stranded conductors.
UL          (4)  Detailed Examination.
Counter-Check   (4)  Physical Properties of Insulation and Jacket,
Program          Unaged and Aged.
            (4)  Heat Shock.
            (4)  Cold Bend.
            (4)  Deformation.
*           (12) Horizontal Flame Test on Cable.
            (4)  Flexibility Test, if unable to perform Physical
                 Properties on Tinsel and/or Stranded Conductors.
Marking     General.
Use         Internal cable of electronic equipment, or as
            "Handset Wire or Telephone Cord for Subscriber Sets".
physical transmission network - 物理传输网络 (0) 投诉
P:2007-05-19 11:07:09
非常感谢!
请问在哪里能买到做这个认证线的PP料啊!
telephone cable for non-essential communication services - 非主要通信设备用电话电缆 (0) 投诉
