首页 > 国外线缆
[问题求助] UL2835内芯线有没有要求需要符合UL
P:2006-08-16 16:07:18
現我司有一款UL2835的線材內絕緣我司采用的材質為發泡PE,而我司沒有通過發泡PE絕緣認証,UL公司要進行處罰,但我手上沒有UL2835標准,煩請哪位傳給我一份。
lead of screw - 螺杆的螺距 (0) 投诉
P:2006-08-16 17:34:34
这是COPY的,希望对你有帮助.
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 2 Page 2835 Issued: Oct. 28, 1976
Revised: June 12, 2001
Style 2835 PVC Jacketed Cable.
______________________________________________________________________________
Rating 60°C, 30 V.
Conductors 40 AWG min. Material not specified.
Insulation Material not specified - For use Statement No. 1A or 1B.or
Insulated Labeled or complies with manufacturer's Procedure - for
Singles use Statement No. 2A or 2B.
Assembly Consists of two or more conductors, twisted pairs, or groups
of twisted conductors. The conductors may be laid parallel
or twisted together to form a flat, oval, or round cable
construction. Lay not specified. Barrier layer and/or
fillers optional. May use same or mixed AWG sizes.
Manufacturer shall maintain a complete description of each
assembly.
Covering Optional. PVC, 5 mil min at any point, over the assembly or
groups of singles.
Shield Optional. May be over one or more of the insulated
conductors or applied over the assembly.
Jacket PVC - Class 43 -
* If parallel construction is rippable, the measurements are
made after ripping.
Dia# of Cable
under Jacket Minimum Minimum
in Inches Average (mils) at any point
0.250 or less 15 13
0.251 - 0.424 30 27
0.425 - 0.700 60 48
0.701 - 1.500 80 64
1.501 - 2.500 110 88
2.501 or larger 140 112
# = Major dia if flat or oval construction.
(Continued on Page 2835A)
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL
Representative
UL (4) Detailed Examination.
*Counter-Check (4) Flexibility Test.
*Program (4) Vertical Flame Test on completed cable, external use,
* Constructions 1B and 2B.
* (4) Horizontal Flame Test on completed cable internal use,
Constructions 1A and 2A.
*Marking General.
Use No. 1A Internal wiring in Class 2 circuits of electronic equipment
where each end is terminated in connectors.
or
Use No. 1B CABLES - using 30 mils or greater jacket thickness only:
External interconnection or internal wiring in Class 2
circuits of electronic equipment where each end is
Use No. 2A Internal wiring in Class 2 circuits of electronic equipment
or external interconnection in Class 2 circuits of
electronic equipment where not routed along walls, floors,
or other abuse areas.
or
Use No. 2B CABLES - using 30 mils or greater jacket thickness only:
circuits of electronic equipment.
管理员 奖励 0 金币,1 声望,于 2006-8-16 17:34:34
extrusion technology - 挤出工艺 (0) 投诉
P:2006-08-16 20:08:03
謝謝!
MOVPE - metal organic vapor phase epitaxy金属有机汽相外延 (0) 投诉
P:2006-08-18 09:46:03
这个应该准确的称为AWM2835。
by-pass - 旁路,分路 (0) 投诉
P:2006-08-19 16:24:54
UL标准是有规定的,复合线如AWM 2464,2835等用的绝缘线也必须有UL的认证,如2464一般绝缘用SR-PVC,一般是用 AWM1061的认证.
管理员 奖励 0 金币,1 声望,于 2006-8-19 16:24:54
preselector measuring device - 定长计米装置,定长计米器 (0) 投诉
P:2006-08-21 19:48:30
沒有規定內絕緣要符合UL吧,我們沒有發泡絕緣認証,但與UL溝通后,就講沒有明顯規定,我們內絕緣用的為NO-UL標准,最后解禁了封條
helically stranded segment - 螺旋形绞合扇形导体 (0) 投诉
P:2006-08-21 20:49:52
这是你运气好,UL检验员会听你的,在UL没有报备的材料是不能随意用于UL产品的.
这此都是UL的要求.
or
or
管理员 奖励 0 金币,1 声望,于 2006-8-21 20:49:52
nondripping flame-retardant cable - 不滴流阻燃电缆 (0) 投诉
P:2006-08-21 20:59:50
你去看一下UL1581中84页的Table 50.193吧!这是Class 2的要求.
关键是你的材料是否能达到它的物性要求.
sintering device - 烧结装置 (0) 投诉
P:2007-11-11 12:12:42
class 2 是什么意思
PTN - physical transmission network物理传输网(络) (0) 投诉
