首页 > 专业英语|国际贸易
[翻译求助] 帮忙看看这是什么意思
P:2012-02-04 13:47:06
Driver Training: 30 wires (minimum)
> * Material covered: XLPE - 15 Kv
> * Application: In woodland
> * Applicable standards: NTC 810 634 (Sep / 09) and NTC 810022
> (Sep/09) - Even for sampling and inspection plan
> * Package: (NBR 11137) Code of the spool 100 / 60 - Bidding
> 400 meters
> * Technical mandatory
> * Quantity: 700,000 meters
shear-type extrusion head - 剪切式挤出机头 (0) 投诉
P:2012-02-05 11:52:40
这个意思就是说: Driver Training: 30 wires (minimum)
> 400 meters
infrasonic cooling unit - 亚声冷却装置 (0) 投诉
P:2012-02-07 14:03:51
感觉这段话是从西语或是葡语中经人翻在的英语,但不专业:
意思是:
Driver Training: 30 wires (minimum) 导体最少30根
> * Material covered: XLPE - 15 Kv 绝缘材料为15KV XLPE
> * Application: In woodland 产品用于森林或是植被覆盖区
> * Applicable standards: NTC 810 634 (Sep / 09) and NTC 810022 标准为:NTC 810 634 和
> (Sep/09) - Even for sampling and inspection plan 尤其是(09-09版中取样和试验程序
> * Package: (NBR 11137) Code of the spool 100 / 60 - Bidding 包装(标准NBR 11137)代号为100/60 木轴-投标用400m
> 400 meters
> * Quantity: 700,000 meters 数量700,000米
high pressure reactor - 高压反应器,高压力反应器 (0) 投诉
P:2012-04-21 20:20:07
上楼很专业
Rocontrol Siemens - AG公司研制的一种微处理机控制系统 (0) 投诉
