[供应信息] 安装用电线
P:2012-02-02 10:15:25
安装用电线13600023420图
名称:铜芯聚氯乙烯绝缘安装用电线
型号:AVR
产品规格:0.2-0.4㎜2
A用途:广东省广州市东方电线电缆厂额定电压300/300V导体最高温度105℃聚氯乙烯绝缘安装电线,该电线选用99.95﹪纯铜,优质塑胶应用光管支架,电子镇流器,变压器,光灯支架,灯盘和净化灯盘上等。
欢迎浏览网站:http://www.--cable-china.cn
Installed with wire map 13600023420
Name: PVC insulated copper wires used to install
Model: AVR
Product specifications :0.2-0.4 mm 2
Uses: Guangzhou City, Oriental rated voltage wire and cable conductors 300/300V maximum temperature of 105 ℃ PVC insulated wires installed, the selection of 99.95% pure copper wire, high-quality plastic stent application of fluorescent tubes, electronic ballasts, transformers, light frame,dengpan upper dengpan and purification.
Welcome to browse the website: http://www.--cable-china.cn
产品简介:
cable engineering expert - 电缆技术专家 (0) 投诉
P:2012-02-02 10:30:36
打廣告呀...
PMJ - prefabricated mo(u)lded joint预制式模塑接头 (0) 投诉
P:2012-02-02 14:18:00
打廣告,上电视
jelly filling head - 石油膏填充头 (0) 投诉
P:2012-02-24 13:37:33
AVR是从0.08、0.12、0.2、0.3、0.4、0.5、0.75这么几个平方开始的,再往上就是1、1.5、2.5、4、6、叫做RVV 这两种的电压等级不一样,你们工厂如果能够成产,请给我报个价格,13313032133@189.cn
Extension rate - 扩展速率,延伸速率,稀释率 (0) 投诉
P:2012-03-30 21:39:55
S.C.W. - standard copper wire标准铜线 (0) 投诉
