首页 > 型号析疑 产品报价
[问题求助] 请问UL1230是不是与1015一样的?
P:2011-12-19 13:50:17
| 是不一樣的! UNDERWRITERS LABORATORIES | APPLIANCE WIRING MATERIAL | ||||
| Subj.758 | Section 1 | Page 1230 | Issued:1960-12-02 |
| Revised:2009-03-28 | |||
| Style 1230 | Insulated Wire. | |
| Rating | 105 deg C, 600 Vac, Horizontal flame, 60 deg C wet, optional Oil Resistance 60 deg C. |
| Conductor | 26 AWG - 9 AWG solid or stranded. |
| Insulation | R/C QMTT2 PVC Insulation Compounds for use in Type TW, 30 mils minimum average, 27 mils minimum at any point. |
| Standard | Appliance Wiring Material UL 758. |
| Marking | General. |
| Use | Internal Wiring. |
smelting furnace for aluminium - 熔铝炉 (0) 投诉
P:2011-12-19 13:50:35
| Subj.758 | Section 1 | Page 1015 | Issued:1959-05-01 |
| Revised:2008-05-27 | |||
| Style 1015 | Insulated Wire. | |
| Rating | 80, 90, 105 deg C, 600 Vac, 750 Vdc, Horizontal flame, Oil Resistant 60 deg C or 80 deg C (optional) |
| Conductor | 30 AWG - 2000 kcmil Solid or Stranded Round. |
| Insulation | PVC |
| 30-9 AWG conductor size | 30 mils min average | 27 mils minimum at any point |
| 8-7 AWG | 45 avg | 40 min |
| 6-2 AWG | 60 avg | 54 min |
| 1-4/0 AWG | 80 avg | 72 min |
| 250-500 kcmil | 95 avg | 86 min |
| 550-1000 kcmil | 110 avg | 99 min |
| 1100-2000 kcmil | 125 avg | 112 min |
| Use | Internal Wiring of Appliances; or Internal Wiring of Appliances where exposed to oil at a temperature not exceeding 60 deg. C or 80 deg. C (whichever is applicable). Tags may also indicate the following: 2,500 V peak - for electronic use only. |
interoffice cable - 局间电缆 (0) 投诉
