首页 > 国外线缆
[国外型号] 谁有UL2586、UL2501的style
P:2011-12-19 10:06:56
2586見下<div>
</div>
| Rating | 105 deg C, 600, 1000 Vac, Cable flame. |
| Conductor | 40 AWG min solid or stranded. |
| Insulation | Labeled or complying with manufacturer's AWM Procedure. |
| Assembly | Two or more conductors or groups of conductors laid parallel or twisted forming a flat, oval or round cable. The lay of the conductors is not specified. A barrier layer and/or fillers are optional. May use same or mixed AWG size. |
| Shield | Optional. |
| Covering | (Optional) A 6 mil or heavier PVC. |
| Jacket | PVC |
| major dia of cable under jacket in inches of 0.700 or less | 30 mils min average | 24 mils minimum at any point |
| 0.701-1.000 dia | 60 avg | 48 min |
| 1.001-1.501 dia | 80 avg | 64 min |
| 1.501-2.500 dia | 110 avg | 88 min |
| Standard | Appliance Wiring Material UL 758. |
| Marking | General. |
| Use | External interconnection or internal wiring. |
campus cable - 建筑园区电缆 (0) 投诉
P:2011-12-19 10:07:25
| UNDERWRITERS LABORATORIES | APPLIANCE WIRING MATERIAL | ||||
| Subj.758 | Section 2 | Page 2501 | Issued:1970-04-07 |
| Revised:2008-05-27 | |||
| Style 2501 | Jacketed Cable. | |
| Rating | 105 deg C, 600 Vac, Cable flame. |
| Conductor | 40 AWG min, solid or stranded round, tinned or bare copper. |
| Insulation | Labeled or complying with Manufacturer's AWM Procedure |
| Assembly | Consists of two or more conductors, twisted pairs or groups of twisted conductors twisted together. The conductors or groups of conductors may be laid parallel forming a flat, oval or round cable. The lay of the conductors is not specified. A barrier layer and/or fillers are optional. Manufacturer shall maintain a complete description of each assembly. May use same or mixed AWG size. |
| Covering | Optional. A 6 mil or heavier PVC covering may be extruded over the conductor assembly. |
| Jacket | PVC |
| major dia in inches of 0.700 or less | 60 mils min average | 48 mils minimum at any point |
| 0.701-1.500 dia | 80 avg | 64 min |
| 2.501 dia and larger | 140 avg | 112 min |
| Use | Internal wiring or external interconnection of electronic equipment. |
barrier-layer - 阻挡层 (0) 投诉
P:2011-12-19 13:53:04
http://data.ul.com/link/stylepage.aspx?style=2501
改后面的数字=xxxx ,就可以了
colouring agent - 着色剂 (1) 投诉
