首页 > 国外线缆
[问题求助] 请问UL2517可以做成双并线(类似UL2468)的形状吗
P:2011-12-13 11:35:30
PRI - primary rate interface基本速率接口,一次速率接、口 (0) 投诉
P:2011-12-13 13:41:10
UNDERWRITERS LABORATORIESAPPLIANCE WIRING MATERIAL
Subj.758Section 2Page 2517Issued:1970-10-21
Revised:2009-06-23
Style 2517Jacketed Cord.
Rating105 deg C, 300 Vac, Cable flame.
Conductor40 AWG minimum.
InsulationLabeled or complying with Manufacturer's AWM Procedure.
AssemblyConsists of two or more singles, twisted pairs or groups of twisted singles twisted together. The singles or groups of singles may be laid parallel forming a flat, oval or round cable. The lay of the conductors are not specified. A barrier layer and/or fillers are optional. Manufacturer shall maintain a complete description of each assembly. May use same or mixed AWG size.
ShieldOptional.
CoveringOptional.
BraidOptional, provided over Jacket.
JacketPVC.
Dia. of Cable under Jacket@Minimum averageMinimum at any point
0.700 inch or less30 mils24 mils
0.701 - 1.000 inch60 mils48 mils
1.001 - 1.501 inch80 mils64 mils
@ - Major diameter if cable is flat or oval.
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseExternal interconnection of electronic equipment or internal wiring of electronic equipment or appliances. Tags may also indicate the following: "600 Volts peak for Electronic Use Only".
interfacial-gel copolymerisation - 界面凝胶共聚技术 (0) 投诉
P:2011-12-13 16:04:39
不可以.
International Cablemakers federation - 国际电缆制造商联盟 (0) 投诉
P:2011-12-14 08:30:04
balloon type insulated coaxial cable - 鱼泡式绝缘同轴电缆 (0) 投诉
