首页 > 国外线缆
[问题求助] 那位知道UL1435的结构
P:2011-11-28 14:00:03
论坛里的那位知道UL1435的结构,和相关的测试标准,跪求!
plug optical fibre - 插塞式光纤 (0) 投诉
P:2011-11-28 17:04:06
这就是 普通的单绝缘电子线,标准UL758.
wire-insulation compound - 线材绝缘料 (0) 投诉
P:2011-11-28 17:16:35
UNDERWRITERS LABORATORIESAPPLIANCE WIRING MATERIAL
Subj.758Section 1Page 1435Issued:1967-07-14
Revised:2008-05-27
Style 1435Jacketed wire.
Rating80 deg C, 300 Vac, Horizontal flame.
Conductor30 AWG - 10 AWG solid or stranded round, tinned or bare copper.
InsulationSolid or cellular FRPE or PE, for 30-16 AWG, 15 mils min. average, 13 mils minimum at any point. For 15-20 AWG, 20 mils min. avg, 18 mils min. at any point.
AssemblyInsulated conductor built with optional barrier tape, optional shield, optional covering, optional shield and required jacket.
ShieldOptional.
CoveringOptional. A textile braid, nylon jacket (2 mil min thickness), or min 8 mils of semi-rigid or regular PVC may be applied between the insulation and shield
JacketPVC, 15 mils min average, 12 mils minimum at any point.
Misc.Optional Barrier Tape - Polyester tape.
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInternal wiring of electronic equipment.
cable marking system - 电缆标志系统,电缆标志装置 (0) 投诉
P:2011-11-29 07:59:28
谢谢!
outer conductor - 外导体(同轴电缆的);相线芯(力缆的);外侧线(电力线的) (0) 投诉
P:2011-11-29 08:10:44
楼上的这份资料里的结构是得做PE绝缘,编织,被覆是不?
drying room - 干燥室,烘干室 (0) 投诉
P:2011-11-29 12:04:56
英文,读起来,真是吃力!
hardfacing - 表面硬化(处理) (0) 投诉
