首页 > 光纤光缆
[光纤光缆] Fiber CHecker光缆检测工具
P:2011-11-11 16:26:42
Description:
The Fiber Checker is a very useful tool designed for
checking the defects of a fiber cable. It emits a visible
635 nm or 650 nm wavelength red laser light through
fiber optic cables, then if there are breaks or defects in
the fiber will refract the light, creating a bright glow
around the faulty area.
The universal connector can be used for all the most widespread fiber
interfaces such as ST / SC / FC connector. It is suitable to test both
Singlemode and Multimode cables. With an optional 2.5 mm to 1.25 mm
optional Adapter, you can easily test 1.25 mm diameter fiber LC or MU
connector. The visibility is from 3 km to 5 km dependent upon the output power
of the Fiber Checker.
Internally there is also a specifically designed power circuit called an APC
suspended transposition - 浮空交叉 (0) 投诉
