首页 > 成缆 绕包 填充
[喷码印字] 印字内容可不可以同用一个印字轮?
P:2007-05-08 17:00:45
各位行家大家好!~
请问PVC印2464印字,与PU印2464印字可不可以同用一个印字轮。
还是要重新申请印字号。
Dri-Fill - 干粉状填充材料(Northern Telecom公司产品的商名,供通信电缆密封之用) (0) 投诉
P:2007-05-08 17:51:52
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 2       Page 2464        Issued:  1968-05-02
                                    Revised:  2003-05-02
Style 2464      PVC Jacketed Cable.
______________________________________________________________________________
Rating      80°C, 300 V.
Insulated       Labeled or complying with manufacturer's AWM Procedure
Conductors      having a minimum rating of 80°C and 300 V.
Assembly        Two or more singles, twisted pairs of groups of twisted
            singles twisted together or singles or groups of singles
            may be laid parallel to form flat, oval or round cable.
            Lay not specified.  Barrier layer and/or fillers optional.
            Manufacturer shall maintain a complete description of each
            assembly.  May use same or mixed AWG size.
*Covering       (Optional.)
Shield      Optional.
Jacket      PVC - Class 43
                         THICKNESS OF PVC JACKET (mils)
            #Dia. of Cable                  Minimum
            Under Jacket        Minimum     at any
               in Inches         Average      point
            0.700 or less          30             24
            0.701 - 1.000          45             36
            1.001 - 1.500          60             48
            1.501 - 2.500          80             64
            2.501 - 4.000         110             88
            4.001 or larger        140           112
            # Major diameter if cable is flat or oval.
Braid           Optional.
Standard        Appliance Wiring Material UL 758.
                                (Continued on Page 2464A)
Subj. 758       Section 2       Page 2464A     Issued:  1968-05-02
                                   Revised:  2003-05-02
Instructions    Detailed Examination of the cable assembly and jacket.
to UL           Physical Properties of Jacket.
Representative  Dielectric Strength Test, 1500 Volts (shielded cable only).
The designation of all Styles of the individual conductors used making up the cable assembly shall be available, and the UL Representative’s tag shall indicate if the Style is labeled or not.  If they are not labeled, the appropriate Follow-Up Tests shall be conducted.
UL          (4)  Detailed Examination.
Counter-Check   (4)  Physical Properties of Jacket.
Program     (4)  Heat Shock on Jacket.
            (4)  Cold Bend on Completed Cable.
            (4)  Deformation on Jacket, Class 43.
            (12) Cable Flame Test on Completed Cable.
If the insulated styles are not labeled, the appropriate Follow-Up Tests shall be conducted.
Marking     General.
Use         Internal wiring or external interconnection of electronic
            equipment (such as desk-type calculators, dictating
            machines, or x-ray equipment).
endface radius - 端面半径 (0) 投诉
P:2007-05-08 17:52:30
2464的护套可以使用PU吗
grouping - 成组,编组 (0) 投诉
P:2007-05-08 20:38:31
就是啊,我也没见过啊!
C.F. - call finder寻线机 (0) 投诉
P:2007-05-09 10:20:45
可以
copper alloy wire - 铜合金线 (0) 投诉
P:2007-05-09 15:27:34
如可以就不能称呼 2464,应该是其他的名称吧?
minus ion - 负离子 (0) 投诉
P:2007-05-09 21:34:26
与以上各位一样疑问
double-ram cable sheathing press - 双活塞电缆护套挤压机,双筒式压铅[铝]机 (0) 投诉
P:2014-03-04 08:17:46
o搞得寺内
OLT - optical line terminal光线路终端 (0) 投诉
