首页 > 专业英语|国际贸易
[翻译求助] 电缆中jack什么意思?
P:2007-05-08 09:19:56
Telephone wall(surface) jack  4pin
Bix Connector 10 pairs for Bix Frame
这个不明白什么意思 请教了
cotton wrapping head - 纱包头,扎纱头 (0) 投诉
P:2007-05-08 12:19:04
           jock  指被覆体  insulation   絕緣体
ultra-short wave - 超短波 (0) 投诉
P:2007-05-08 13:45:26
是保护层(绝缘或护套)
short circuit capability - 短路容量 (0) 投诉
P:2007-05-09 12:04:20
不是“护层”的意思,此处是“插座”的意思(电学),即socket。
护套:jacket
lay-plate - 分线板 (0) 投诉
P:2007-05-12 09:34:03
1. Yes.  It should be " socket/ jack with 4pin in telephone surface wall"
电话机外壁上的四针孔插座.
2.Bix should be a small equipment's name or brand.
用于BIX 框架/箱壳十副BIX接头/线.
Yes or not ?  It is better you check the pratical items! Maybe we can help you more with yr uploaded photo. Surely, I mean the photo of these products which your English words indicate. Don't worry about it, u will understand more with serious study or practical work.  I think many warm-heart persons will help green guys, especially the style you have been in the web. Good luck!
[isl2005 在 2007-5-12 9:43:14 编辑过]
drum-emptying device - 料桶排空装置(安装在塑料颗粒定量系统上) (0) 投诉
P:2007-07-05 11:28:21
护套的意思
很多国家喜欢这么用
有些国家就是用sheath
International Standards organization - 国际标准组织 (0) 投诉
P:2007-08-07 09:27:26
isl2005:
电话机外壁上的四针孔插座.
你是翻译么  超厉害哦
reel-to-reel changeover - 换盘,更换线盘 (0) 投诉
P:2007-08-07 22:16:38
雕虫小技, 何足挂齿.
毛主席说过: 世上无难事, 只要肯登攀;
古诗人叹曰: 会当凌绝顶, 一览众山小.
吾等皆俗类, 更当每日三省以求上善.
To be better, to be harder. Richer yr mind , improve yr life.
[isl2005 在 2007-8-7 22:21:36 编辑过]
save energy - 节能 (0) 投诉
P:2007-08-10 17:17:18
Jack 是插头,或是PLUG 也可以(公的)MALE
SOCKET是插座,或是sheath也可以(母的)FEMALE
不要和JACKET混淆,它是外被的意思。
air-patented rod - 空气淬火线杆,空气冷却线杆 (0) 投诉
P:2007-08-10 17:22:39
JACK 是插头,或是PLUG
JACKET是外被
grounding cable - 接地电缆 (0) 投诉
P:2007-08-14 17:03:55
JACK generally stands for socket or modules
screened-conductor cable - 屏蔽导体电缆,屏蔽电缆 (0) 投诉
P:2007-08-15 16:26:06
就是电线电缆的护套
small-pair-count telephone cable - 小对数电话电缆 (0) 投诉
P:2008-04-01 17:16:47
jacketing 护套
tps - terminals per station每站终端数,终端/站 (0) 投诉
P:2008-04-01 18:58:18
jack是插座jacket是外被
fibre optic safety guide - 光纤安全导则 (0) 投诉
P:2008-04-14 14:49:13
jack 的意思是电缆外护套
scanning - 扫描;检测 (0) 投诉
23
