首页 > 国外线缆
[问题求助] ul标准询问
P:2011-09-19 10:49:00
ul标准询问
查看UL STYLE 1185标准有几点疑问:
UNDERWRITERS LABORATORIES INC.                        APPLIANCE WIRING MATERIAL
Subject 758       Section 1         Page 1185          Issued: May 1, 1959
                                                      Revised: Dec. 15, 1981
Style 1185        PVC Insulated, Shielded and Jacketed Wire.
______________________________________________________________________________
Rating            80°C, 300 Volts.
Conductor         Copper - 30-4/0 AWG, solid or stranded, tinned or bare,
                  page 26
Insulation        Extruded PVC, Class 12
                  AWG       Min. Avg., Mils      Min. at any point Mils
                  30-16            15                   13
                  15-10            30                   27
                   9-8            45                   40
                   7-2            60                   54
                   1-4/0     80                   72
Shield            Page 24.
Jacket            Extruded PVC, Class 12
                  30-16            15                   12
                  15-2            30                   24
                   1-4/0     45                   36
                  30-16    or lacquered braid
Shield            Optional, page 24.
Jacket            Optional, PVC Class 12,15 mils min. avg., 12 mils. min. at
                  any point.
Strandard         Flexible Cord and Fixture Wire, UL62 and Thermoplastic
                  Insulated Wire, UL 83.
Instructions      Detailed examination.
to UL             Physical properties - insulation and pvc jacket, Page 32.
Representative    Spark Test. Page 30
                  (Continued on 1185A)
Subject 758             Section 1         Page 1185A  Issued:  May 1, 1959
                                                      Revised:  April 2, 1984
UL                (4)  Detailed Examination.
Counter-Check     (4)  Physical Properties - Insulation and PVC Jacket,
Program                Page 33.
                  (4)  Heat Shock, Page 57.
*                 (4)  Deformation, Page 38.
                  (4)  Cold Bnd, Page 58.
                  (2)  Flame Test, Page 31.
Marking           General, Page 13.
Use               Internal Wiring of Appliances and Electronic Equipment.
疑问一:内容中红色标记 PAGE26 PAGE24怎么看?
疑问二:UL1185是属于UL758中的,下面strandard中怎么又是UL62 和UL83呢?
请明白人给解答一下,谢谢~!
high potential test - 耐压试验,耐电压试验 (0) 投诉
P:2011-09-19 15:39:48
NO、NO,
wire ferrule - 线箍 (0) 投诉
P:2011-09-19 21:36:25
你这个style page是在哪找的
demountable optical connector - 可拆式光纤接头 (0) 投诉
P:2011-09-20 08:39:29
就是UL STYLE里找的啊
Internal Stress - 内应力 (0) 投诉
P:2011-09-20 11:19:13
专业生产电线电缆、橡胶塑料、电工电器等行业试验检测设备。欢迎致电:温小姐:13480042699
polyethylene filler - 聚乙烯填充物 (0) 投诉
