首页 > 国外线缆
[问题求助] UL标准询问
P:2011-09-19 08:23:20
查看UL STYLE 1185标准有几点疑问:
UNDERWRITERS LABORATORIES INC.                        APPLIANCE WIRING MATERIAL
Subject 758       Section 1         Page 1185          Issued: May 1, 1959
                                                      Revised: Dec. 15, 1981
Style 1185        PVC Insulated, Shielded and Jacketed Wire.
______________________________________________________________________________
Rating            80°C, 300 Volts.
Conductor         Copper - 30-4/0 AWG, solid or stranded, tinned or bare,
                  page 26
Insulation        Extruded PVC, Class 12
                  AWG       Min. Avg., Mils      Min. at any point Mils
                  30-16            15                   13
                  15-10            30                   27
                   9-8            45                   40
                   7-2            60                   54
                   1-4/0     80                   72
Shield            Page 24.
Jacket            Extruded PVC, Class 12
                  30-16            15                   12
                  15-2            30                   24
                   1-4/0     45                   36
                  30-16    or lacquered braid
Shield            Optional, page 24.
Jacket            Optional, PVC Class 12,15 mils min. avg., 12 mils. min. at
                  any point.
Strandard         Flexible Cord and Fixture Wire, UL62 and Thermoplastic
                  Insulated Wire, UL 83.
Instructions      Detailed examination.
to UL             Physical properties - insulation and pvc jacket, Page 32.
Representative    Spark Test. Page 30
                  (Continued on 1185A)
Subject 758             Section 1         Page 1185A  Issued:  May 1, 1959
                                                      Revised:  April 2, 1984
UL                (4)  Detailed Examination.
Counter-Check     (4)  Physical Properties - Insulation and PVC Jacket,
Program                Page 33.
                  (4)  Heat Shock, Page 57.
*                 (4)  Deformation, Page 38.
                  (4)  Cold Bnd, Page 58.
                  (2)  Flame Test, Page 31.
Marking           General, Page 13.
Use               Internal Wiring of Appliances and Electronic Equipment.
疑问一:内容中红色标记 PAGE26 PAGE24怎么看?
疑问二:UL1185是属于UL758中的,下面strandard中怎么又是UL62 和UL83呢?
请明白人给解答一下,谢谢~!
oscillator binder unit - 摆动式绕扎装置 (0) 投诉
P:2011-09-19 09:56:00
难道论坛就没个明白人吗?
高人再现~~!~!
cable subway - 电缆管道 (0) 投诉
P:2011-09-20 08:50:38
此贴引发的深思:
按理说这个帖子的疑问无非是怎么查看标准,以及标准的基础知识而已;
不知道大家是看到了不会回答还是没看到,至今的确没有答案;
论坛里经常看到讨论一些较为高深的问题,确实可喜,可身为电线人如果连基本的标准识读都难的话,我表示深深的忧虑。
mass-impregnated paper insulation - 粘性浸渍纸绝缘 (0) 投诉
P:2011-10-11 14:22:05
這個問題不好意思回答.
self-supporting riser cable - 自承式提升型电缆 (0) 投诉
P:2011-11-06 19:41:41
真不好意思回答你!!!!!!!!!!!!这种问题!!!!!!
high-ratio extrusion facility - 高比率挤出设备 (0) 投诉
P:2011-11-07 09:41:38
楼主你这个标准是从哪里来的?
TE - terminal equipment终端设备 (0) 投诉
P:2011-11-07 09:45:19
这是我刚刚查询的标准!
UNDERWRITERS LABORATORIESAPPLIANCE WIRING MATERIAL
Subj.758Section 1Page 1185Issued:1959-05-01
Revised:2011-10-24
Style 1185Single conductor using extruded non-integral jacket.
Rating80 deg C, 300 Vac, Horizontal flame.
Conductor30 AWG - 4/0 AWG, solid or stranded.
InsulationPVC
Conductor sizeMinimum average thicknessMinimum thickness at any point
30-16 AWG15 mils13 mils
15-10 AWG30 mils27 mils
9-8 AWG45 mils40 mils
7-2 AWG60 mils54 mils
1-4/0 AWG80 mils72 mils
AssemblyInsulated conductor, optional shield, required jacket, optional shield, optional jacket.
ShieldOptional.
JacketExtruded PVC.
30-16 AWG15 mils12 mils
15-2 AWG30 mils24 mils
1-4/0 AWG45 mils36 mils
30-16 AWGor lacquered braid
Outer ShieldOptional.
Outer JacketOptional. Extruded PVC, 15 mils minimum average thickness, 12 mils minimum thickness at any point.
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInternal Wiring of Appliances and Electronic Equipment.
litz wire - 束线,束绞线,编织线 (0) 投诉
P:2011-11-07 14:06:24
楼主的StylePAGE好像是错误的!
cable drum table - 电缆盘转台,转盘 (0) 投诉
P:2011-11-07 15:25:07
我这个更新日期是:Revised: 2011-10-24
fusion mass-splice - 熔融整体接头(光纤的) (0) 投诉
