[问题求助] ZCVV电缆和ZAVV电缆的区别?
P:2011-09-16 15:03:26
VV是电缆的型号,是聚氯乙烯绝缘聚氯乙烯护套电力电缆,额定电压是0.6/1kV
ZC和ZA是阻燃类别代号,A和C是指阻燃级别,这是GB/T19666-2005阻燃耐火电线电缆通则中规定的
表4阻燃电缆成束阻燃性能要求
Table 4 Bunched burning characteristic
代号 Code | 试样非金属材料体积/(L/m) Volume of non metal materials(L/m) | 供火时间/s Time of fire supply/s | 合格指标 Acceptable index | 试验方法 Test mode |
ZA ZB ZC ZD | 7 3.5 1.5 0.5 | 40 40 20 20 | 1) 试样上炭化的长度不应超过距喷嘴底边上 The length of carbonation is no more than 2) 停止供火后试样上的有焰燃烧时间不应超过1h The time of flaming combustion shall be no more than 1h, after fire supply is stopped. | GB/T 18380.3 IEC 6 |
ZD适用于试样外径不大于 ZD is suitable for the cables whose sample's outer diameter is no more than | ||||
JIH - Japan Information Highway日本信息高速公路 (0) 投诉
