首页 > 光纤光缆
[光纤光缆] optical fiber cable谁能生产?
P:2007-04-29 10:02:10
24fiber cable will be our standard SMT0MS-24SM cable (non armored multi tube (4x6) cable with 7x1.0mm steel rope messneger).
    from 144 up to 576 fibers per cable. And all of them also should be also messengered ! Cable should be multi tube, with glass central element, non-armored. And steel messenger should be strong anough to let the cable be fixed up to 100meters long ! Corning SMF-28 fiber will be used.
    In example fibers can be organized in thicker loose tubes in 12 x fiber bundles grouped with colored binders (in example 576 cable can consist of 12 tubes with 4 x 12 fibers in every tube). Or you can suggest ribbon cables.
    We will need not anly prices but datasheet with description of structure, mecanical parameters, messneger rope size and tensile strength, cable dimensions (outer diameter, diameters of used loose tubes, etc),  cable weght.
As follows:
1. Optical fiber cable SM 576x9/125 (outdoor) messengered
2. Optical fiber cable SM 432x9/125 (outdoor) messengered
3. Optical fiber cable SM 288x9/125 (outdoor) messengered
4. Optical fiber cable SM 144x9/125 (outdoor) messengered
5. Optical fiber cable SM 24x9/125 (outdoor) messengered
这样要求的室外光缆谁能生产,联系QQ376010113
voltmeter-ammeter method - 电压-电流法 (0) 投诉
P:2007-07-13 00:58:12
这是普通的带状光缆,能作的厂家很多.13705544067
conductivity-imparting agent - 导电添加剂 (0) 投诉
P:2007-07-13 13:15:14
同问,室外光缆和室内光缆有谁做的比较好,且愿意做OEM的,可否告知厂商和联系方式?谢谢大家
bitumen-sheathed paper cable - 沥青绝缘纸电缆 (0) 投诉
P:2007-08-04 21:26:31
生产厂家很多
bias capstan - 偏置牵引轮 (0) 投诉
P:2010-10-29 20:54:47
Submission of tender - 投标 (0) 投诉
