首页 > 线缆设计|参数计算
[功率载流] 低压电缆导体能承载的电流计算
P:2011-08-24 10:41:25
花了点时间做的, 如果看了觉得不错就顶一个!
IDDS - International Digital Data Service国际数字数据业务 (0) 投诉
P:2011-08-24 10:45:27
equalizing bus-bar - 均压母线 (0) 投诉
P:2011-08-24 14:56:34
是自己编的吗?
reversing wheel - 回动轮;换向手轮 (0) 投诉
P:2011-08-24 21:11:11
是的。
high frequency output - 高频输出 (0) 投诉
P:2011-10-01 15:06:29
False Pict False Pict False Pict False Pict False Pict <OBJECT class=shape id=Label1 height=24 width=70 classid=CLSID:978C9E23-D4B0-11CE-BF2D-00AA003F40D0 v:shapes="_x0000_s1025"></OBJECT><OBJECT class=shape id=Label2 height=24 width=98 classid=CLSID:978C9E23-D4B0-11CE-BF2D-00AA003F40D0 v:shapes="_x0000_s1026"></OBJECT><OBJECT class=shape id=Label3 height=24 width=101 classid=CLSID:978C9E23-D4B0-11CE-BF2D-00AA003F40D0 v:shapes="_x0000_s1027"></OBJECT><OBJECT class=shape id=Label4 height=24 width=71 classid=CLSID:978C9E23-D4B0-11CE-BF2D-00AA003F40D0 v:shapes="_x0000_s1028"></OBJECT><OBJECT class=shape id=Label5 height=24 width=161 classid=CLSID:978C9E23-D4B0-11CE-BF2D-00AA003F40D0 v:shapes="_x0000_s1029"></OBJECT>
False Pict False Pict False Pict False Pict False Pict <OBJECT class=shape id=C_Size height=24 width=96 classid=CLSID:8BD21D30-EC42-11CE-9E0D-00AA006002F3 v:shapes="_x0000_s1030"></OBJECT><OBJECT class=shape id=C_ITem height=24 width=96 classid=CLSID:8BD21D30-EC42-11CE-9E0D-00AA006002F3 v:shapes="_x0000_s1031"></OBJECT><OBJECT class=shape id=C_Str height=24 width=96 classid=CLSID:8BD21D30-EC42-11CE-9E0D-00AA006002F3 v:shapes="_x0000_s1032"></OBJECT><OBJECT class=shape id=C_WTem height=24 width=96 classid=CLSID:8BD21D30-EC42-11CE-9E0D-00AA006002F3 v:shapes="_x0000_s1033"></OBJECT><OBJECT class=shape id=MaxA height=26 width=95 classid=CLSID:8BD21D10-EC42-11CE-9E0D-00AA006002F3 v:shapes="_x0000_s1034"></OBJECT>
False Pict <OBJECT class=shape id=CommandButton1 height=32 width=51 classid=CLSID:D7053240-CE69-11CD-A777-00DD01143C57 v:shapes="_x0000_s1035"></OBJECT>
Note1: PE/PP/SRPVC一般选80℃;
PVC/IRRPVC/TPE/Nylon一般选105℃;
Kynar/Tefzel/Halar一般选125~150℃;
Teflon FEP/Teflon PFA一般选200℃;
Note2:绝缘温度等级越高, 导体允许承受的电流越大
Note3:芯线数量越多, 散热越差, 导体允许承受的电流越小
Note4:环境温度越高, 导体电阻越高, 散热降低, 导体允许承受的电流越小
Note5:导体越大, 电阻越小,发热量越低, 导体允许承受的电流越大
n mi - nautica mile海里<=1853.2m> (0) 投诉
P:2011-10-01 15:07:57
上面的一个被骗了
Foxpro - 一种个人计算机数据库 (0) 投诉
P:2011-11-13 17:20:11
沒下載完成,可否Email給我
jack2204@139.com
感謝
electronic balance - 电子天平 (0) 投诉
P:2011-11-18 14:21:06
这个价格太高了啊!~~
control and instrument cabinet - 控制仪表柜 (0) 投诉
P:2011-11-19 14:50:32
应该好好学习一下
SVOO - 表示绝缘及外被皆採用耐油之鸟坡林材料,构造同 SV。 (0) 投诉
P:2014-11-14 18:41:53
这个楼主是个骗子,大家不要上当下载了,我下载看了一下,根本没法用,还50G,真是太坑人了!!!!!
bitumen box - 沥青箱 (0) 投诉
P:2017-07-29 16:29:25
骗人的
optical fibre plant - 光纤设备,光纤制造设备 (0) 投诉
P:2017-08-23 15:49:44
ddd000:
我可以负责任的告诉大家,是能用的哦!
packaging standard - 包装标准 (0) 投诉
P:2017-08-23 15:51:06
BJG:
骗人的
安全提示要选择信任!
OF - optical fiber光纤 (0) 投诉
