首页 > 专业英语|国际贸易
[专业词汇] 电线电缆专业外语词汇总汇
P:2007-04-27 21:10:33
<DIV class=Section1 style="LAYOUT-GRID: 15.6pt none">
湿式中拉机 medium wet drawing machine
中拉机 medium wire drawing machine
中拉 intermediate drawing
中拉机 intermediate wire drawing machine
中拉机、大拉机 coarse wire drawing machine
粗-细线拉线机、中拉机 coarse-fine wire drawing machine
多根拉线-退火-束线机组 multi-wire drawing-annealing-bunching line
四节距束线机 four twist bunching machine
双节距束线机 double twist buncher
双节距束线机 double-twist bunch strander
双节距[双倍]束线机 double-twist bunching machine
双节距高速束线机 double-twist laying-up machine
复合束线、复[混[合束线 compound bunch
磨光机、束线机 buffing machine v
束线、束绞 n
束线 bunch v
束线、束绞 bunch-strand
束绞铜束线 bunch-stranded copper conductor
束线、绞合线 bunched wire
束线机 buncher
束线机 bunching machine
灌注 potting
双面双层十六头纱包机 16- head double-side douoble-rosette cotton covering machine)
立式双层鼓轮 vertical double draft bull block
双层编包风雨线 weatherproof double braid
双层挤出(机)头 twin (extruder) head
双层鼓轮拉线机 twin capstan drawing machine
双头挤出、双层挤出 twin-head extrusion
双层的 twin-layer
橡皮绝缘双层编包线 rubber-covered double braided
双层环氧漆包圆铜电磁线 heavy epoxy-coated round copper magnet wire
泡沫皮绝缘、泡沫/实心双层绝缘 foam skin insulation
双层编织机 double tier type braiding machine
词汇汇总-电线电缆行业词汇
束线、束绞 n
束线 bunch v
束线、束绞 bunch-strand
束线、绞合线 bunched wire
束线机 buncher
灌注 potting
双层的 twin-layer
LIGHTPACK Cable - LIGHTPACK 线缆 (0) 投诉
P:2007-04-27 21:11:24
电工用圆铜杆 round copper rod for electrical purpose
成圈铜杆放线架 pay-off stand for copper rods in coils
热轧铜杆 hot-rolled copper rod
铜杆 copper bar
铜杆、(电缆头用)铜出线梗、接线柱 copper rod
铜杆剥皮机 copper rod descaler
铜杆拉出 copper rod withdrawal
控制电缆 control cables
自动带宽控制 ABC
断线控制系统 wire break control system
线张力控制 wire tension control
线张力控制仪、紧线器 wire tensioner
电压控制 voltage contro
扭力控制装置 torsion control equipment
热液控制、液体控温(法) thermal liquid control
厚度(控制)仪、测厚仪 thickness gage
色调控制孔径 toll-control aperture
带子张力控制 tape tension control
温度控制[调节] temperature control
液体控温(法)、热液控制 temperature control by a liquid medium
温度控制仪 temperature control meter
张力控制[调节]装置 tension control device
张力控制装置 tension control unit
张力控制放线装置 tension controlled pay-off
张力控制仪 tensioner
测试线、控制[操作、监视]线 testing conductor
严格控制[检验、检查] strict control
严格控制[检验、检查] stringent test
监督、检验、检查、控制 supervision
电场控制[调整]、应力控制 stress control
应力控制带 stress control tape
应力控制管 stress control tubing
电[磁]场控制的、应力控制的 stress-controlling
严格检验[检查、控制] severe control
严格检验[检查、控制] severe test
控制线路用多芯用电缆、船用控制电缆 shipboard multicore cable for control circuits
硅管外径控制器 silica tube outer diameter controller
设定值、控制点 setpoint
严格检验[检查、控制] rigid test
严格检验[检查、控制] rigorous test
自动控制收线装置 robot take-up
垂度控制 sag control
垂度控制器 sag controller
垂度控制环 sag-control loop
调节[控制]范围 regulating range
调节[整]器、控制器 regulator
按扭控制[操纵] push-button control
质量控制[检验] quality control
质量检验[控制] quality inspection
生产过程控制、程序控制 process control
工序控制检验 process control inspection
生产过程控制 production control
程序控制 programme control
控制导线、辅助芯线 pilot
控制线芯、监视线芯 pilot conductor
导引绝缘线芯、控制线芯、监视线芯 pilot core
控制线、操作线 pilot line
压缩空气控制 pneumatic operation
放线人工控制速度 pay off manual speed control
放线自动控制微调 payoff automatic-control triment
氢氧焰温度控制器 oxyhydrogen flame temperature controller
控制板[配电盘]开关装置 panel switching equipment
操作台、操纵盘、控制板 operator panel
操作台、控制台 operator's desk
噪声控制装置 noise control equipment
铜杆 copper bar
控制电缆 control cables
自动带宽控制 ABC
电压控制 voltage contro
张力控制仪 tensioner
设定值、控制点 setpoint
垂度控制 sag control
控制导线、辅助芯线 pilot
控制线、操作线 pilot line
adhered substance - 异物附着 (0) 投诉
P:2007-04-27 21:12:14
软拉 soft drawn
软或退火铜线、软铜线 soft or annealed copper wire
箔软线、塞线 tinsel cord
电话软线 telephone cord
电信软件 telesoftware
电源软线 supply cord
交换机电缆[塞子软线] switchboard cable
退火(软)线 soft annealed wire
退火、韧炼、软化退火 soft annealing
软电缆 soft cable
软陶瓷绝缘电磁线 soft ceramic insulated magnet wire
软涂层 soft coating
软拉 soft drawn
软橡胶 soft rubber
软链段 soft segment
软焊料钎焊、锡焊 soft soldering
退火铜线、软铜线 soft-annealed copper wirev
软焊料钎焊、锡焊 soft-solder
软化剂 softener
软化 softening
软化剂 softening agent
软化[退火]装置 softening plant
软化点 softening point
软化区、增塑区 softening region
软钎焊(缝、点、头) soldered joint
软钎焊(缝、点、头) soldering joint
扁形(软线)接头 spade tag
扇形(软线)接头 spade terminal
螺旋芯软线、有弹簧的塞绳 spiral-conductor flexible cord
星绞八芯软电缆 spiral-eight cable
星绞四芯软电缆 spiral-four cable
星绞四芯软电缆 spiral-four type cable
船用软同轴电缆 shipboard flexible coaxial cable
爆破[放炮]用软线 shot-fire cord
丝包软线 silk-covered cord
镀银软或退火铜线、镀银软铜线 silver-coated soft or annealed copper wire
单线软绳 single-wire cord
可收缩软线、弹簧线 retractile cord
橡套软电缆 rubber jacketed flexible cable
橡胶素炼机、软胶机 rubber-homogenizer
软拉 s.d.(soft drawn)
游览车用软线 recreational-vehicle cord
预装配的软电缆 pre-assembled flexible cable
预装配的软电缆及软线 pre-assembled flexible cables and cords
精密排列的扁形软电缆 precision-tiered flat flexible cable
箔软线、塞线 tinsel cord
电话软线 telephone cord
电信软件 telesoftware
电源软线 supply cord
软电缆 soft cable
软涂层 soft coating
软拉 soft drawn
软橡胶 soft rubber
软链段 soft segment
软化剂 softener
软化 softening
软化剂 softening agent
软化点 softening point
扁形(软线)接头 spade tag
软拉 s.d.(soft drawn)
BRI - Basic Rate Interface基本速率接口 (0) 投诉
P:2007-04-27 21:13:00
抽头、引线、软导线 pigtail
超软细股线 pigtail wire
塑料护套软线 plastic-sheathed flexible cord
移动式软线 portable cord
普通塑料护套软线 ordinary plastic-sheathed flexible cord
普通型耐磨橡套软电缆 ordinary tough-rubber sheathed flexible cable
普通耐磨橡套软线 ordinary tough-rubber sheathed flexible cord
普通聚氯乙烯护套软线 ordinary(PVC-)sheathed flexible cord
耐油软线 oil-proof cord
耐油软线 oil-resistant cord
光纤软线 optical fiber cord
多芯软线 multicore cord
多芯软线 multiple cord
网络软件 network software
镀镍软或退火铜线、镀镍软铜线 nickel-coated soft or annealed copper wire
麦克风[话筒]软线 microphone cord
麦克风[话筒]软线 mike cord
移动房屋用软线 mobile-home cord
定型设计的电话软线、弹簧电话软线 modular telephone cord
防潮双绞软线 moisture proof twisted cord
单塞绳、单软线 monocord
低温柔软性 low temperature flexibility
低漏泄电流用户软线 low-leakage-current service cord
轻型塑料护套软线 light plastic-sheathed flexible cord
轻型聚氯乙烯护套软线 light(PVC) sheathed flexible cord
电灯(软)线 lamp cord
铅合金包覆软铜线 lead-alloy-coated soft copper wire
铅包软铜线 lead-coated soft copper wire
仪器用软线[塞绳] instrument cord
绝缘软线 insulated flexible wire
综合软件 integrated software
高温软线 high-temperature flexibles
素炼机、软胶机 homogenizing roller
布线用线、安装线、跨接线、柔软连接线 hook-up wire
软管、橡皮管 hose
苛刻条件用软线 hard-service cord
耐热护套软电缆 heat-resistant sheathed flexible cable
重型耐磨橡套软电缆 heavy tough-rubber sheathed flexible cable
镀锌软[低碳]钢丝 galvanized mild steel wire
玻璃丝绝缘软线 glass-fiber-insulated flexibles
馈电软线 feed cord
超软细股线 pigtail wire
移动式软线 portable cord
耐油软线 oil-proof cord
多芯软线 multicore cord
多芯软线 multiple cord
麦克风[话筒]软线 mike cord
单塞绳、单软线 monocord
电灯(软)线 lamp cord
软管、橡皮管 hose
馈电软线 feed cord
shunt excitation - 并激 (0) 投诉
P:2007-04-27 21:13:41
扁形软电缆 flat flexible cable
扁形双芯软线 flat twin flexible cord
扁形双芯软线[塞绳] flat twin tinsel cord
软线 flex conductor
柔软性 flexibility
柔软度试验 flexibility test
软线、连接塞绳、软电缆确良 adj
柔软的 flexible
软电缆 flexible cable
矿工帽灯用软线 flexible cable for miners' cap lamps
软接线 flexible circuit conductor
软导体、柔软导体、软线 flexible conductor
软线、连接塞绳 flexible cord
电缆软接头 flexible joint
移动式电力软线 flexible portable power cord
电力软线 flexible power cord
软绞线 flexible stranded conductor
软绞线 flexible stranded wire
软[花、皮]线 flexible wire
软线布线 flexible wiring
软线、软绳 flexibles
弹性[延伸]软绳 extension cord
特软绞线 extra-flexible stranded conductor
极苛刻条件用软线双芯软线[塞绳] double conductor cord
软化击穿 cut-through
耐切通性、切通强度、耐软化击穿性能 cut-through resistance
切通温度、软化击穿温度 cut-through temperature
切通试验、软化击穿试验 cut-through test
连接塞绳、软线 connecting cord
铜芯聚氯乙烯绝缘平型软线 copper conductor PVC-insulated parallel flexible cord
铜芯聚氯乙烯绝缘绞型软线 copper conductor PVC-insulated twisted flexible cord
软线[绳]、电线电缆、塞绳 cord
花线、装饰线路用软线 cord for decorative chains
带有插塞的电话软线 cord setextra-hard-service cord
成套塞绳、带有插塞的电话软线彩色软线 colour cord
通信软件 communication software
锥形软模具 cone-shaped flexible die
同轴软线、同轴线塞绳 coaxial cord
螺圈形软线 coiled cord
橡皮绝缘(软)电缆、橡套[软件]电缆 cabtyre cable
橡套电缆、软管电缆 cabtyre sheathed cable
配套软件 bundled software
软管电缆 cab-tire cable
橡皮绝缘软线〔软塞绳〕 cab-tyre cord
电缆软接头 cable flexible joint
软连接用电缆 cable for flexible connections
软线 flex conductor
柔软性 flexibility
软线、连接塞绳、软电缆确良 adj
柔软的 flexible
软电缆 flexible cable
软线、软绳 flexibles
软化击穿 cut-through
软线[绳]、电线电缆、塞绳 cord
螺圈形软线 coiled cord
软管电缆 cab-tire cable
Milliken conductor - 分割导体,密里根导体(一种集肤效应小的圆形导线,由各股分别绝缘的成型绞线组成) (0) 投诉
P:2007-04-27 21:14:37
电缆软管 cable hose
电缆软管夹托架 cable hose clamp bracket
编织软绳 braided flexible cord
退火、韧炼、软化 anneal
肖飚(本软件开发者、电缆工艺工程师) XIAOBIAO
屈服[流动、软化、击穿]点 YP(yield point)
柔软控制电缆 FCC(flexible control cable)
硬链段与软链段的嵌段共聚物 HYTREL
挤出机 extruders
挤出 extrusion
挤气式挤出机 vent extruder
通用回转式挤出机 versatile turret extruder
立式连续挤出硫化机组 vertical continuous extruding and vulcanizing machine
立式挤出机 vertical extruder
立式挤出 vertical extrusion
二段式挤出机 two-stage extruder
三层挤出机 triple extruder
三层挤出(机)头 triple extruder head
三层挤出(机)头 triple extrusion head
双螺杆挤出机 twin-screw extruder
三层挤出绝缘电缆 three-layer extruded cable(
挤出机)模嘴、模芯、末端 tip
串列式挤出机 tandem extruder
挤出物料的脱节 starving of extrudate flow(
挤出机)送料螺杆 stockscrew
滤网<挤出机的> strainer
剪切式挤出机头 shear-type extrusion head
护套挤出机 sheathing machine
单螺杆挤出机 single screw extruder(
挤出机筒内)焦烧、早期硫化 scorching(in extruder cylinder)
螺杆式挤出机 screw extruder
半导体材料挤出机 semicon extruder
挤出头、压力模座 press block
压力型多层一次挤出模 pressure-type coextrusion die
分段式挤出机 piggyback extruder
行星齿轮式挤出机 planetary gear extruder
(塑料)挤出机 plastic extruder
制粒挤出机 pelletising extruder(
挤出机)斜角机头 oblique head
单段式挤出机 one-stage extruder
光缆护套挤出生产线 optical cable sheathing line
多色挤出机 multi-colour extruder
多层挤出机 multi-layer extruder
多级[多段]式挤出机 multi-stage extruder
多根挤出法 multi-wire insulation process
多头挤出装置 multiline extrusion system
退火、韧炼、软化 anneal
挤出机 extruders
挤出 extrusion
挤出机)模嘴、模芯、末端 tip
挤出机)送料螺杆 stockscrew
滤网<挤出机的> strainer
sounder - 音响器 (0) 投诉
P:2008-12-12 17:19:09
谢谢版主,能不能也给我来一份,不是电缆专业,不过现在从事电缆行业,dwlovelxf@126.com 或quality@henrycables.com 谢谢!
JASC - Japan Sea Cable日本海底电缆 (0) 投诉
27
