首页 > 标准共享
[国外标准] UL 1581-2008 Reference Standard for Electrical Wires, Cables,and Flexible Cords
P:2011-08-09 16:31:29
空心菜 奖励 2 金币,.01 声望,于 2011-8-10 10:56:53 原因:感激分享
glazed wire - 漆包线 (0) 投诉
P:2011-08-10 10:56:25
下载来看看,以前有,不过不是08的
simplex paper - 单层纸 (0) 投诉
P:2011-08-11 15:25:01
有资料就得支持
graded leaky coaxial cable - “渐变型”漏泄同轴电缆 (0) 投诉
P:2011-08-14 17:27:57
impulse voltage test - 冲击电压试验,脉冲耐压试验 (0) 投诉
P:2011-09-02 17:10:40
UNDERWRITERS LABORATORIESAPPLIANCE WIRING MATERIAL
Subj.758Section 1Page 1581Issued:1973-01-19
Revised:2011-08-15
Style 1581Single conductor with extruded insulation
Rating80 deg C, 300 Vac, Horizontal flame. Optional - 60 deg C or 80 deg C Oil.
Conductor15 AWG - 10 AWG, solid or stranded.
InsulationExtruded PVC, 16 mils minimum average thickness, 13 mils minimum thickness at any point.
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInternal wiring of Appliances where not subjected to mechanical abuse. Tags may indicate the following: 600 Volts Peak - For Electronic Use Only.
polyester elastomer - 聚酯弹性体 (0) 投诉
P:2011-09-24 00:15:31
很好,谢谢楼主的分享。
extremely low-frequency emission - 超低频辐射 (0) 投诉
P:2011-09-28 23:32:41
谢谢楼主的分享
triple extruder - 三层挤出机,三层共挤挤出机 (0) 投诉
P:2011-10-11 10:58:26
這個有,不下了.
沒錢了.
fuse together - 熔合 (0) 投诉
P:2011-10-19 09:19:10
不会吧是英文的
VC-EVA - vinyl chloride-ethvlene vinyl acetate氯乙烯-乙烯醋酸乙烯 (0) 投诉
P:2011-10-20 20:53:17
已经有了这个,路过支持一下楼主的辛苦。
three-core termination - 三芯终端接头 (0) 投诉
P:2011-10-22 20:10:08
nick-free stripping - 无缺口剥皮 (0) 投诉
P:2011-10-31 08:24:38
顶下
die polish - 线模抛光 (0) 投诉
P:2012-05-05 13:59:29
天书
transmission path - 传输路径,信道 (0) 投诉
P:2012-05-23 11:47:05
thermal force distribution - 热应力分布 (0) 投诉
P:2012-06-04 17:27:57
好东东啊,顶
snagging - 打磨 (0) 投诉
21
