[问题求助] Journal of Electromagnetic Analysis and Applicatio
P:2011-07-22 09:12:44
Journal of Electromagnetic Analysis and Applications
ISSN: 1942-0730 (Print) 1942-0749 (Online).
JEMAA free online access:Scientific Rasearch Publishing
Table of Contents(Vol.03 No.06, Jun. 2011):
SF6 Byproducts in High-Humidity Environment: an Experimental Evaluation between 200oC and 500oC
Yu Wang, Li Li, Weijian Yao
Path Integral Approach to Faraday's Law of Induction
Sami Mohammad Al-Jaber
Simplified Model of a Layer of Interconnects under a Spiral Inductor
Sonia M. Holik, Timothy D. Drysdale
Non Linear Magnetic Hysteresis Modelling by Finite Volume Method for Jiles-Atherton Model Optimizing by a Genetic Algorithm
Seddik Azzaoui, Kamel Srairi, Mohamed El Hachemi Benbouzid
Lateral Waves near the Surface of Sea
Osama M. Abo-Seida, Samira T. Bishay, Khaled M. El-Morabie
Characterization and Optimization of Photonic Crystal Optical Power Limiters
Igor Guryev, Igor Sukhoivanov, E. Alvarado Mendez, José Andrade Lucio
On Chebyshev Array Design Using Particle Swarm Optimization
Mohammed H. Bataineh
An Entropy-Approach to the Duality Property
Salam Abdelhady
Design of Reflective, Photonic Shields for Atmospheric Reentry
Nikolay Komarevskiy, Valery Shklover, Leonid Braginsky, Christian Hafner, et al.
Coupled Resonator Diplexer without External Junctions
Talal F. Skaik, Michael J. Lancaster
History and Advancement of the Family of Log Periodic Toothed Planer Microstrip Antenna
Arti Vaish, Anita Dalal
Evaluation of the Exposure to Electromagnetic Fields in Computer Labs of Schools
Isidor Kokalari, Theodhor Karaja
More Issues
Vol.3 No.5, May 2011 | Vol.3 No.4, Apr. 2011 | Vol.3 No.3, Mar. 2011 |
JEMAA is an OPEN ACCESS journal dedicated to the latest advancement of electromagnetic analysis, testing and application.
Topics:
· Antenna Arrays · Antenna Theory and Applications · Biological Effects · Electric Power and Grounding (Earth) · Electrical Machine · Electroencephalograph (EEG) · Electromagnetic Compatibility · Electromagnetic Compatibility (EMC) · Electromagnetic Field Theory · Electromagnetic Inverse Problems · Electromagnetic Material Modelling · Electromagnetic Nondestructive Testing · Electromagnetic Physics · Electromagnetic Structure Optimization · Electromagnetism and Medical Devices · Electromyography · Fiber Optics · Integrated Optics · Medical Applications · Moving Conductor Eddy Current Problems · Noise And Signals · Optical and Millimeter Wave Techniques · Quasi-Static Fields · Radiated Electromagnetic · Serges (Thunderbolts or Static Electricity) · Static Fields · Test Electromagnetic Analysis Method (Team) Workshop Benchmark Problems · Waveguides | · Eddy Current Problems · Electric Power Line · Electrocardiograph (ECG) · Electromagnetic Breaker · Electromagnetic Compatibility and Electromagnetic Environment · Electromagnetic Devices · Electromagnetic Interferences (EMI) · Electromagnetic Launch · Electromagnetic Measurement Technology and Instruments · Electromagnetic Numerical Analysis · Electromagnetic Solid Mechanics · Electromagnetism and Biological Tissues · Electromagnetism in Medical Applications · Environmental Pollution by Electromagnetics · High Frequency Techniques · Magnetic Fluid · Measuring Technique of Radiated Electromagnetic · Multiphysics Coupled Problems · Noise Reduction · Printed Circuits · Radar Measurements and Applications · Scattering and Diffraction · Solid State Devices and Circuits · Static Magnetic · The Problems of The Propagation of Electromagnetic Waves |
Contact us:jemaa@scirp.org
EHQ2VP4
[123ht 在 2011-7-22 9:17:25 编辑过]
semi-automatic line control unit - 半自动生产线控制装置 (0) 投诉
