首页 > 电气装备用线缆
[布电线缆] RVVP屏蔽线详细技术参数
P:2011-07-18 13:36:57
RVVP屏蔽线详细技术参数
- 1、用途:适用于视频信号、门禁考勤、楼宇对讲、通讯音频、广播音响系统、仪表、电子设备及自动化设备、抗干扰线路屏蔽
- 2、生产标准:国家标准、企业标准
- 3、技术参数:
- 导体使用多支铜线绞合
- 裸铜或镀锡铜编织屏蔽
- 聚氯乙烯绝缘
- 聚氯乙烯护套
- 额定电压Uo/U为300/300V
- 长期允许工作温度应不超过70℃
- 包装长度:200米/卷(包装规格可根据客户要求更改。)
| 型号/规格 | 芯数×标称截面(m㎡) | 绝缘厚度规定值(mm) | 护套厚度规定值(mm) | 编织屏蔽密度≥% | 平均外径(mm) | 20℃时导体电 阻最大值Ω/Km | 70℃时导体电阻最小值MΩ.Km | |
| 上限 | 下限 | |||||||
RVVP 2×7/0.15 | 2×0.12 | 0.4 | 0.6 | 80 | 3.7 | 4.9 | 158 | 0.016 |
RVVP 2×12/0.15 | 2×0.20 | 0.4 | 0.6 | 80 | 4.1 | 5.3 | 92.3 | 0.013 |
RVVP 2×16/0.15 | 2×0.30 | 0.5 | 0.6 | 80 | 4.8 | 6.2 | 69.2 | 0.014 |
RVVP 2×28/0.15 | 2×0.50 | 0.5 | 0.6 | 80 | 5.3 | 6.8 | 39.0 | 0.012 |
RVVP 2×24/0.20 | 2×0.75 | 0.5 | 0.6 | 80 | 5.8 | 7.4 | 26.0 | 0.010 |
RVVP 2×32/0.20 | 2×1.00 | 0.6 | 0.6 | 80 | 6.4 | 8.2 | 19.5 | 0.010 |
RVVP 2×48/0.20 | 2×1.50 | 0.6 | 0.8 | 80 | 7.3 | 9.2 | 13.3 | 0.009 |
RVVP 2×78/0.20 | 2×2.50 | 0.7 | 0.8 | 80 | 8.5 | 10.5 | 7.98 | 0.008 |
RVVP 3×7/0.15 | 3×0.12 | 0.4 | 0.6 | 80 | 3.9 | 5.1 | 158 | 0.016 |
RVVP 3×12/0.15 | 3×0.20 | 0.4 | 0.6 | 80 | 4.5 | 5.8 | 92.3 | 0.013 |
RVVP 3×16/0.15 | 3×0.30 | 0.5 | 0.6 | 80 | 5.1 | 6.5 | 69.2 | 0.014 |
RVVP 3×28/0.15 | 3×0.50 | 0.5 | 0.6 | 80 | 5.6 | 7.1 | 39.0 | 0.012 |
RVVP 3×24/0.20 | 3×0.75 | 0.5 | 0.6 | 80 | 6.1 | 7.8 | 26.0 | 0.010 |
RVVP 3×32/0.20 | 3×1.00 | 0.6 | 0.8 | 80 | 7.2 | 9.1 | 19.5 | 0.010 |
RVVP 3×48/0.20 | 3×1.50 | 0.6 | 0.8 | 80 | 8.0 | 10.0 | 13.3 | 0.009 |
RVVP 3×78/0.20 | 3×2.50 | 0.7 | 0.9 | 80 | 9.1 | 11.1 | 7.98 | 0.008 |
RVVP 4×7/0.15 | 4×0.12 | 0.4 | 0.6 | 80 | 4.5 | 5.8 | 158 | 0.016 |
RVVP 4×12/0.15 | 4×0.20 | 0.4 | 0.6 | 80 | 4.9 | 6.2 | 92.3 | 0.013 |
RVVP 4×16/0.15 | 4×0.30 | 0.5 | 0.6 | 80 | 5.5 | 7.0 | 69.2 | 0.014 |
RVVP 4×28/0.15 | 4×0.50 | 0.5 | 0.7 | 80 | 5.8 | 7.8 | 39.0 | 0.012 |
RVVP 4×24/0.20 | 4×0.75 | 0.5 | 0.7 | 80 | 6.6 | 8.6 | 26.0 | 0.010 |
RVVP 4×32/0.20 | 4×1.00 | 0.6 | 0.8 | 80 | 7.4 | 9.4 | 19.5 | 0.010 |
RVVP 4×48/0.20 | 4×1.50 | 0.6 | 0.8 | 80 | 8.4 | 10.4 | 13.3 | 0.009 |
RVVP 4×78/0.20 | 4×2.50 | 0.7 | 0.9 | 80 | 10.2 | 12.2 | 7.98 | 0.008 |
RVVP 5×7/0.15 | 5×0.12 | 0.4 | 0.6 | 80 | 4.8 | 6.2 | 158 | 0.016 |
RVVP 5×12/0.15 | 5×0.20 | 0.4 | 0.6 | 80 | 5.3 | 6.7 | 92.3 | 0.013 |
RVVP 5×16/0.15 | 5×0.30 | 0.5 | 0.6 | 80 | 6.0 | 7.6 | 69.2 | 0.014 |
RVVP 5×28/0.15 | 5×0.50 | 0.5 | 0.8 | 80 | 6.2 | 8.2 | 39.0 | 0.012 |
RVVP 5×24/0.20 | 5×0.75 | 0.5 | 0.8 | 80 | 7.3 | 9.3 | 26.0 | 0.010 |
RVVP 5×32/0.20 | 5×1.00 | 0.6 | 0.9 | 80 | 8.0 | 10.0 | 19.5 | 0.010 |
RVVP 5×48/0.20 | 5×1.50 | 0.6 | 1.0 | 80 | 9.4 | 11.4 | 13.3 | 0.009 |
RVVP 5×78/0.20 | 5×2.50 | 0.7 | 1.1 | 80 | 11.7 | 13.7 | 7.98 | 0.008 |
RVVP 6×7/0.15 | 6×0.12 | 0.4 | 0.6 | 80 | 5.2 | 6.6 | 158 | 0.016 |
RVVP 6×12/0.15 | 6×0.20 | 0.4 | 0.6 | 80 | 5.7 | 7.2 | 92.3 | 0.013 |
RVVP 6×16/0.15 | 6×0.30 | 0.5 | 0.6 | 80 | 6.5 | 8.2 | 69.2 | 0.014 |
RVVP 6×28/0.15 | 6×0.50 | 0.5 | 0.8 | 80 | 7.0 | 9.0 | 39.0 | 0.012 |
RVVP 6×24/0.20 | 6×0.75 | 0.5 | 1.8 | 80 | 8.4 | 10.4 | 26.0 | 0.010 |
RVVP 6×32/0.20 | 6×1.00 | 0.6 | 1.0 | 80 | 9.3 | 11.3 | 19.5 | 0.010 |
RVVP 6×48/0.20 | 6×1.50 | 0.6 | 1.0 | 80 | 10.8 | 12.8 | 13.3 | 0.009 |
RVVP 6×78/0.20 | 6×2.50 | 0.8 | 1.2 | 80 | 12.7 | 14.7 | 7.98 | 0.008 |
RVVP 7×7/0.15 | 7×0.12 | 0.4 | 0.6 | 80 | 5.2 | 6.6 | 158 | 0.016 |
RVVP 7×12/0.15 | 7×0.20 | 0.4 | 0.6 | 80 | 5.7 | 7.2 | 92.3 | 0.013 |
RVVP 7×16/0.15 | 7×0.30 | 0.5 | 0.6 | 80 | 6.5 | 8.2 | 69.2 | 0.014 |
RVVP 7×28/0.15 | 7×0.50 | 0.5 | 0.8 | 80 | 7.3 | 9.3 | 39.0 | 0.012 |
RVVP 8×7/0.15 | 8×0.12 | 0.4 | 0.6 | 80 | 5.1 | 7.1 | 158 | 0.016 |
RVVP 8×12/0.15 | 8×0.20 | 0.4 | 0.6 | 80 | 5.6 | 7.6 | 92.3 | 0.013 |
RVVP 8×16/0.15 | 8×0.30 | 0.5 | 0.6 | 80 | 6.7 | 8.7 | 69.2 | 0.014 |
RVVP 8×28/0.15 | 8×0.50 | 0.5 | 0.8 | 80 | 7.9 | 9.9 | 39.0 | 0.012 |
RVVP 8×24/0.20 | 8×0.75 | 0.5 | 0.9 | 80 | 9.4 | 11.4 | 26.0 | 0.010 |
RVVP 8×32/0.20 | 8×1.00 | 0.6 | 1.0 | 80 | 1.04 | 12.5 | 19.5 | 0.010 |
RVVP 8×48/0.20 | 8×1.50 | 0.6 | 1.0 | 80 | 12.7 | 14.7 | 13.3 | 0.009 |
RVVP 10×7/0.15 | 10×0.12 | 0.4 | 0.6 | 80 | 6.4 | 8.1 | 158 | 0.016 |
RVVP 10×12/0.15 | 10×0.20 | 0.4 | 0.6 | 80 | 7.4 | 9.3 | 92.3 | 0.013 |
RVVP 10×16/0.15 | 10×0.30 | 0.5 | 0.6 | 80 | 8.7 | 10.9 | 69.2 | 0.014 |
RVVP 10×28/0.15 | 10×0.50 | 0.5 | 0.8 | 80 | 8.9 | 10.9 | 39.0 | 0.012 |
RVVP 10×24/0.20 | 10×0.75 | 0.5 | 0.9 | 80 | 10.3 | 12.4 | 26.0 | 0.010 |
RVVP 10×32/0.20 | 10×1.00 | 0.6 | 1.0 | 80 | 12.6 | 14.6 | 19.5 | 0.010 |
RVVP 10×48/0.20 | 10×1.50 | 0.6 | 1.0 | 80 | 13.6 | 15.6 | 13.3 | 0.009 |
RVVP 12×7/0.15 | 12×0.12 | 0.4 | 0.6 | 80 | 6.6 | 8.3 | 158 | 0.016 |
RVVP 12×12/0.15 | 12×0.20 | 0.4 | 0.6 | 80 | 7.6 | 9.6 | 92.3 | 0.013 |
RVVP 12×16/0.15 | 12×0.30 | 0.5 | 0.6 | 80 | 9.0 | 11.2 | 69.2 | 0.014 |
RVVP 12×28/0.15 | 12×0.50 | 0.5 | 0.9 | 80 | 9.5 | 11.5 | 39.0 | 0.012 |
RVVP 12×24/0.20 | 12×0.75 | 0.6 | 1.0 | 80 | 12.6 | 14.6 | 26.0 | 0.010 |
RVVP 12×32/0.20 | 12×1.00 | 0.7 | 1.1 | 80 | 13.6 | 15.6 | 19.5 | 0.010 |
RVVP 12×48/0.20 | 12×1.50 | 0.7 | 1.1 | 80 | 15.2 | 17.2 | 13.3 | 0.009 |
RVVP 16×7/0.15 | 16×0.12 | 0.4 | 0.6 | 80 | 7.6 | 9.5 | 158 | 0.016 |
RVVP 16×12/0.15 | 16×0.20 | 0.4 | 0.6 | 80 | 8.6 | 10.8 | 92.3 | 0.013 |
RVVP 16×16/0.15 | 16×0.30 | 0.5 | 0.6 | 80 | 9.9 | 12.3 | 69.2 | 0.014 |
recoiling machine - 成圈复绕机,成圈线复绕机 (0) 投诉
