[问题求助] 请帮忙翻译下面的英文标准,多谢了
P:2011-06-28 16:53:58
ISO6722
     This International Standard specifies the dimensions, test methods, and requirements for single-core 60 V cables intended for use in road vehicle applications where the nominal system voltage is u (60 V d.c. or 25 V a.c.). It also specifies additional test methods and/or requirements for 600 V cables intended for use in road vehicle applications where the nominal system voltage is > (60 V d.c. or 25 V a.c.) to u (600 V d.c. or 600 V a.c.). It also applies to individual cores in multi-core cables.
主要是翻译最后一句,多谢谢拉
Shop inspection - 出厂检验 (0) 投诉
P:2011-06-28 17:14:09
它还适用于多芯电缆的单个芯线。
也就是说可以做为多芯电缆的绝缘使用,应该是这个意思吧。
SCCEW - single cotton coveredenamelled wire单纱包漆包线 (0) 投诉
P:2011-06-29 12:53:03
谢谢楼上的老大
cold-forging die - 冷锻模 (0) 投诉
P:2017-07-28 10:48:42
你们的线都出口的吗
LT - line terminal[-tion]线路终端 (0) 投诉
P:2025-07-18 13:18:57
它也适用于多芯电缆中的单个芯线。
Orthonic - 奥索尼克(一种磁性材料商品名) (0) 投诉
