首页 > 型号析疑 产品报价
[型号解析] NYY NYM这个是什么线材的型号呢?
P:2011-06-16 15:20:24
请教各位大大,
NYY NYM这是线材型号吗?
我们工厂是做网线的,但是客户要我报NYY NYM的所有价格,
但是我不明白这是什么意思哦!!!
多谢,各位帮忙!
BT - British Telecom英国电信 (0) 投诉
P:2011-06-16 20:45:19
NYY可能是PVC绝缘和护套,NYM我暂没见过,N是VDE规范,Y是PVC,M有绞合(股)导体的意思,有高手的还请赐教
swelling powder - 泡胀粉末(通信电缆密封用) (0) 投诉
P:2011-06-16 21:09:39
帮楼主差了查,NYM,可能是PVC绝缘,皱纹钢护套
IR - 绝缘电阻(Insulation Resistance)之缩写 (0) 投诉
P:2011-06-19 16:11:44
Installation cable, PVC insulated NYM-J
300/500 V
According to VDE 0250 part 204
Characteristics Properties Unit
Group Power cables < 1 kV
Class Installation cable
Type NYM-J
Conductor material Cu
Nominal conductor cross sectional area See type table mm²
Structure of conductor See type table
Number of conductors See type table pce
Conductor insulation PVC
Conductor-coding See type table
Conductor colour code See type table
Yellow/green conductor Yes
Shielded No
Drain wire No
Support organ None
Lead shield No
Armoured None
Outer sheath material PVC
Colour of outer sheath Grey
Halogen free (acc. EN 50267-2-3) No
Flame retardant Acc. EN 50265-2-1
Low smoke (acc. EN50268-2) No
System integrity No
Outer diameter See type table mm
Minimum bending radius 4 x outer-Ø
Minimum installation temperature 5 - 70 °C
Maximum operating temperature -40 - 70 °C
Maximum conductor temperature 70 °C
Maximum short circuit temperature 160 °C
Nominal voltage Uo 300 V
Nominal voltage U 500 V
ATA - Advanced Technology Attachment高级技术附加装置,ATA 接口 (0) 投诉
P:2011-06-21 11:29:56
哇。。大哥 还要金币的哇
那这样表示 应该是光纤的一种线缆吧。。。。
kneading - 捏炼; 捏合,混合; 混炼 (0) 投诉
P:2011-06-21 12:42:25
印尼一带用这类型号!具体可以参考pt jambo 的产品目录查询
floor type measuring equipment - 落地式测量设备 (0) 投诉
P:2011-06-21 16:26:41
好的,多谢啊
不过 好像我们做不了这个线 呵呵
variation - 变化;变量;偏差 (0) 投诉
