首页 > 国外线缆
[问题求助] UL1017电子线的规格结构是什么样的
P:2011-06-08 09:58:18
ul 1017 电子线的规格结构是什么样的‘;
capstan - 牵引轮,绞盘 (0) 投诉
P:2011-06-08 11:50:43
UNDERWRITERS LABORATORIESAPPLIANCE WIRING MATERIAL
Subj.758Section 1Page 1017Issued:1959-05-01
Revised:2008-05-27
Style 1017Insulated Wire.
Rating80 deg C, 600Vac, Horizontal flame, Oil Resistant 60 deg C or 80 deg C (optional).
Conductor22 AWG - 8 AWG Solid or Stranded Round, tinned or bare copper.
InsulationPVC, 45 mils min average, 40 mils minimum at any point.
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInternal wiring of Appliances where exposed to oil at a temperature not exceeding 60 deg C or 80 deg C, whichever is applicable.
Elastic buckling - 弹性屈服 (0) 投诉
P:2011-06-09 09:03:48
UL1017 PVC HOOK-UP WIRE
<DIV class=STYLE2 align=left>Product Category:</DIV><DIV class=STYLE2 align=left>PVC HOOK-UP WIRE</DIV>
<DIV class=STYLE2 align=left>Temperature Rating:</DIV><DIV class=STYLE2 align=left>80℃ </DIV>
<DIV class=STYLE2 align=left>Rated voltage:</DIV><DIV class=STYLE2 align=left>600V</DIV>
<DIV class=STYLE2 align=left>Test voltage:</DIV><DIV class=STYLE2 align=left>6000V</DIV>
<DIV class=STYLE2 align=left>Insulation Material:</DIV><DIV class=STYLE2 align=left>PVC</DIV>
<DIV class=STYLE2 align=left>Conductor material:</DIV><DIV class=STYLE2 align=left>bare copper/tinned copper/sliver copper</DIV>
<DIV class=STYLE2 align=left>Application:</DIV><DIV class=STYLE2 align=left>The wire can use for the Internal wiring of appliances where exposed to oil at a temperature not exceeding (60°C or 80°C, whichever is applicable).
</DIV>
ItemGaugeConductor AreaConductor Frameconductor
outer
diameter
insulation
thickness
wire O.DMax Cond.
resistance
No.(AWG)(mm2)wire core qtywire diameter(mm)(mm)(mm)(Ω/km)
1220.352170.1600.761.153.2057.50
2200.538210.1780.941.153.4034.60
3180.835160.2541.161.153.623.30
4161.357260.2541.491.153.917.40
5142.140410.2541.871.154.4015.10
6123.392650.2542.361.154.809.20
7105.6441050.2543.001.155.505.40
888.9241190.3004.251.156.804.10
superconductive - 超导的,超导电的,超导体的 (0) 投诉
