[同轴电缆] 求购 BS 7870-3-50标准同轴电缆
P:2011-05-19 11:51:58
(1) Technical Specifications of Split Concentric cable Cu/XLPE/PVC 1x10/10/10mm² 600/1000 V
Specification Category 要求UnitsSpecification StandardBidder's Specification 供应商的数据(请填写)
Conductor Size 导体(芯)的大小mm10
Conductor Diameter  导体(芯)的直径 (approximate或相近)mm4
Insulation Type 绝缘类型TypeXLPE type GP8 or Equiv.
Insulation Thickness 绝缘层厚度mm0.7
Cable Diameter 电缆直径Mm12
Cable Mass 重量Kg/m (approx或相近.)0.33
Gross Mass (500 m reels) 毛重,以500米来算Kg (approx或相近.)200
Bending Radius 弯曲半径Min(最小). mm250
Current Rating in air 在空气中的电流等级Amps100
Resistance (ac @ 90 degrees C) 电阻Ω/km(max.最大)2.33
Reactance 电抗Ω/km0.1
Impedance  阻抗Ω/km2.3
Outer Sheathing (Black UV Stable) 外套(黑色的稳定UV)Type类型LLDPE or Equiv. LLDPE或相近
CU Class 铜等级Class2 or 4
  规格:1*10*10*10MM2  符合标准:BS7870-3-50 数量:70000米邮箱:LISUXIN-OP@163.com
four-wire repeater - 四线增音机 (0) 投诉
P:2011-07-11 10:53:26
供应  BV YJV 各种规格的电线电缆    电话:021-54166399
TCP - termination connection point终端连接点 (0) 投诉
