首页 > 专业英语|国际贸易
[专业词汇] 两根粘在一起的并排线,英语如何说?类似UL2468结构
P:2011-05-18 08:38:47
两根粘在一起的并排线,是不押外被的哦,,,,,英语如何说?
好像flat cable是押外被的排线???还是就是flat cable?
[newren 在 2011-5-18 8:40:20 编辑过]
macro-analysis - 宏观分析,总体分析 (0) 投诉
P:2011-05-18 10:12:25
是不是ribbon cable
production capacity - 生产能力,产量 (0) 投诉
P:2011-05-18 11:40:34
Style 2468    Flat Ribbon-Type Cable.
PCF - plast ic cladding optical fiber塑料包层光纤 (0) 投诉
P:2011-05-19 11:01:00
同意一楼的flat cable
voltage - 电压 (0) 投诉
P:2014-12-04 16:42:25
flat twin,绞线的话就是flat twist
rotor - 转子;转动体 (0) 投诉
P:2018-04-18 16:07:35
<div id="StylePanel" style='width: 1367px; text-align: center; color: rgb(0, 0, 0); text-transform: none; text-indent: 0px; letter-spacing: normal; font-family: "Courier New"; font-size: 12pt; font-style: normal; font-weight: normal; word-spacing: 0px; white-space: normal; orphans: 2; widows: 2; background-color: rgb(255, 255, 255); font-variant-ligatures: normal; font-variant-caps: normal; -webkit-text-stroke-width: 0px;'>
APPLIANCE WIRING MATERIAL
Subj.758Section 2Page 2468Issued:1968-05-07
Revised:2013-02-22
Style 2468Flat ribbon cable
Rating80 deg C, 300 Vac, Horizontal flame. Optional - 60 or 80 deg C Oil.
Conductor32 AWG - 16 AWG, solid or stranded.
InsulationExtruded PVC, 15 mils minimum average thickness, 13 mils minimum thickness at any point.
AssemblyTwo to one hundred and fifty conductors laid parallel and in one plane. May use same or mixed AWG size. Minimum average and minimum at any point of insulation thickness after ripping shall be 15 mils and 13 mils, respectively. This forms a flat cable with a single row of conductors having a 1/2 in. maximum width web between insulated conductors.
ShieldOptional.
CoveringOptional, extruded PVC, 5 mils minimum thickness at any point, 80 mils maximum thickness.
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInternal wiring.
UL and the UL Logo are trademarks of UL LLC © 2018
</div>
levitation casting process - 悬浮浇铸工艺,悬浮浇铸法 (2) 投诉
