首页 > 国外线缆
[国外型号] UL 3398 电子线标准
P:2011-04-08 13:44:19
求ul3398电子线标准
chemical foam - 化学泡沫 (0) 投诉
P:2011-04-08 19:40:54
UNDERWRITERS LABORATORIES
APPLIANCE WIRING MATERIAL
Subj.758
Section 3
Page 3398
Issued:1980-03-31
Revised:2008-05-27
Style 3398
Insulated Wire
Rating
150 deg C, 300 Vac, Horizontal flame.
Conductor
32 AWG - 10 AWG solid or stranded, tinned, bare or silver plated copper, or solid or stranded coated high strength copper - minimum 90% conductivity.
Insulation
XLPE, 15 mils min average, 13 mils minimum at any point.
Covering
Optional - XLPE, 10 mils minimum average, 8 mils minimum at any point. Compound Designation same as Insulation.
Standard
Appliance Wiring Material UL 758.
Marking
General.
Use
Internal wiring of appliances where not subjected to movement or mechanical damage. Tags may indicate the following: 600 V peak - for electronic use only.
pretwisted core - 预扭线芯 (0) 投诉
