首页 > 专业英语|国际贸易
[翻译求助] 求助翻译UL817温升测试条文
P:2011-03-25 21:02:36
TEMPERATURE TEST, UL 817 87
METHOD
Cord Size (AWG) | Cord Type | Test Current (A) |
18 | SPT-2-R | 2.5 |
18 | SPT-2-R | 5.0 |
Six samples of Cat. No. SY-18 molded on Flexible Cords as tabulated above were placed in series and the blades of each sample shorted by a 14 AWG bare copper conductor (solid) to form a series circuit. Current was adjusted in circuit to the above specify test current using a low-voltage ac source and was allowed to operate until temperatures stabilized (minimum of 4 h). Thermocouples were used to record temperatures on blades.
[vhctc 在 2011-3-25 23:18:07 编辑过]
[vhctc 在 2011-3-25 23:19:26 编辑过]
URD extruded cable - 住宅区地下配电用挤包型电缆 (0) 投诉
来学习下,谢谢!
