首页 > 国外线缆
[问题求助] UL2464 20#一定要加铝箔和编织吗,收到的图纸没有要求
P:2011-03-22 10:20:36
外被最好用多少  P的胶粒    因为我是新手  请大哥们帮帮忙啊,
age reduction - 减缩率 (0) 投诉
P:2011-03-23 11:14:34
看一下2464的style page吧,屏蔽是可有可无的。
至于外被用多少P的料,只要能通过758里面要求的物性要求就可以。
UNDERWRITERS LABORATORIESAPPLIANCE WIRING MATERIAL
Subj.758Section 2Page 2464Issued:1968-05-02
Revised:2009-05-26
Style 2464Jacketed Cable.
Rating80 deg C, 300 Vac, Cable flame.
InsulationLabeled or complying with manufacturer's AWM Procedure.
AssemblyTwo or more singles, twisted pairs of groups of twisted singles twisted together or singles or groups of singles may be laid parallel to form flat, oval or round cable. Lay not specified. Barrier layer and/or fillers optional. Manufacturer shall maintain a complete description of each assembly. May use same or mixed AWG size.
ShieldOptional.
CoveringOptional.
BraidOptional, provided over Jacket.
JacketPVC
Dia of Cable under jacketMin averageMinimum at any point
0.700 inch or less30 mils24 mils
0.701-1.000 inch45 mils36 mils
1.001-1.500 inch60 mils48 mils
1.501-2.500 inch80 mils64 mils
2.501-4.000 inch110 mils88 mils
4.001 inch and larger140 mils112 mils
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInternal wiring or external interconnection of electronic equipment (such as desk-type calculators, dictating machines, or x-ray equipment).
SQC - standard quality control标准质量控制 (0) 投诉
P:2011-04-01 12:07:55
65P差不多了
high speed band marker - 线芯用高速色标印刷机 (0) 投诉
P:2011-04-05 22:39:21
看标准就可以了。
如果客人要的话,可以加
high linefoaming extrusion line - 高发泡挤出生产线 (0) 投诉
P:2011-06-24 14:52:18
ring code of cable cores - 电缆线芯的环形标记 (0) 投诉
P:2011-06-29 12:45:43
2464没有要求一定加屏蔽,可加可不加,外被用PVC,伸长达到100%以上,抗张达到1500PSI以上就可以了,55P至65P都可以。
waste - 废品,废料 (0) 投诉
P:2011-06-29 15:38:37
你们所说的55P、65P的“P”是什么意思?
maintenance instruction - 维护说明书,保养规程 (0) 投诉
P:2011-07-13 15:53:57
晕,P数是胶料的软硬度,P数越高,代表胶料越软,反之则硬.
AC - 软金属带鎧装型之分路及馈线电缆。 (0) 投诉
P:2011-07-14 09:27:17
主要还是看UL的规定,2楼发的那个就是2464UL的规定,只要在这个大范围内都可以的
sector conductor - 扇形导体 (0) 投诉
P:2011-07-29 16:33:41
UL对用料的硬度没有要求的,主要看客户的使用需求!有的客户有要求特软的。我们常规用Shore A80(60P) 左右即可。
flexural modulus - 弯曲模数 (0) 投诉
P:2011-08-04 19:53:20
硬度对应:
98A----28P
95A----32P
90A----45P
80A----60P
length/diameter ratio ratio - 长径比 (0) 投诉
