首页 > 专业英语|国际贸易
[专业词汇] 电线电缆行业词汇中英文对照
P:2011-02-28 09:12:06
电缆及设备安装程序PACE(program for arrangement of cables and equipment)
千伏安KvA(Kilovolt-ampere)
用浮筒把电缆拉上海岸 tofloat a cable ashore
浅海电缆、岸边电缆shallow water cable
浅海电缆、岸边电缆shallow-water cable
三聚氰胺石棉塑料asbestos filled melamine plastics
磺胺类药物 sulfa
磺胺类药 sulfadrug
直焊性聚酰亚胺漆包铜圆线solderable polyesterimide enamelled round copper wire
聚酰胺 polyamide
聚酰胺漆包线polyamide enamelled wire
聚酰胺-(酰)亚胺 polyamide-imide
聚酰胺-(酰)亚胺漆包铜圆线 polyamide-imide enamelled round copper wire
聚酰胺-酰亚胺漆包线 polyamide-imide enamelledwire
聚酰胺-酰亚胺浸渍漆 polyamide-imide impregnatingvarnish
聚酰胺纤维polyanide fiber
聚酰亚胺polyesterimide
聚酰亚胺漆包铜扁线polyesterimide enamelled rectangular copper wire
聚酰亚胺漆包铝圆线polyesterimide enamelled round aluminium wire
聚酰亚胺/聚酰胺复合漆包铝圆线 polyesterimide enamelledround aluminium wire overcoated with polyamide
聚酰亚胺漆包铜圆线polyesterimide enamelled round copper wire
聚酰亚胺/聚酰胺复合漆包铜圆线 polyesterimide enamelledround copper wire overcoated with polyamide
聚酰亚胺漆包线polyesterimide enamelled wire
聚酰亚胺/聚酰胺复合漆包铝圆线 polyesterimide overcoatedwith polyamide-imide enamelled round aluminium wire
聚酰亚胺/聚酰胺复合漆包铜圆线 polyesterimide overcoatedwith polyamide-imide enamelled round coper wire
聚酰亚胺涂层光纤polyimide coated optical fiber
聚酰亚胺漆包铜扁线polyimide enamelled rectangular copper wire
聚酰亚胺漆包铜圆线polyimide enamelled round copper wire
聚酰亚胺漆包线polyimide enamelled wire
聚酰亚胺薄膜polyimide film
尼龙、酰胺纤维 nylon
金属包层芳族聚酰胺纤维metal-clad aramid fiber
环已酰亚胺cycloheximide
抗组织胺antihistamine
聚酰胺PA(polyamide)
聚酰亚胺PI(polyimide)
二基乙酰胺DMA(dimethyl acetamide)
地表凹陷、地面下沉subsidence of ground
凹口试杆冲击试验notched bar impact test
有凹槽的 fluted
凹陷半径 dipradius
凹状梯度折射率光纤、凹形渐变折射率光纤 dipped graded-index fiber
牙、槽、凹陷 dent
凹陷型包复depressed clad
深凹陷内包层光纤depressed cladding fiber
凹陷深度 depth ofpip
粉末涂敷 powdercoating
流化床涂敷fluidized bed coating
十八盘两段卧式绞线成缆机18-bobbin 2-cage horizontal wire stranding and laying-up machine
十八盘绞笼 18-bobbin bay
模湿式拉丝机、八模湿拉机wet drawing machine with 8 dies
星绞八芯软电缆spiral-eight cable
扭绞八芯电缆、对绞四线组电缆、双四线组电缆 quad pair cable
八芯光纤连接器eight-ways optical fiber connector
摆杆式拉线机 dancerarm drawing machine
摆杆 dancerrocker arm
并列摆动分线板coordinated oscillating face plate
柱式荡轮、柱式荡轮式储线器、舞摆[动盘]式储线器 column-type dancer accumulator
在...支配或摆布下 at the mercy of
半导电膨胀阻水层semi-conducting moisture swelling layer
半导体釉semmiconducting glaze
半导电漆semiconductive varnish
半年、学期、半学年semester
半空气绝缘电缆semi-air space cable
半退火铝导体semi-annealed aluminium conductor
半自动电缆绝缘剥除机semi-automatic cable de-insulating machine
半自动电缆测量装置semi-automatic cable measuring system
半自动收线装置semi-automatic take-up
半自动双盘收线装置semi-automatic twin take-up
半导电的、半导体的semi-conducting
半导体丁基橡胶带semi-conducting butyl tape
半导体混合物semi-conducting compound
半导体护套semi-conducting jacket
半导电层、半导体层semi-conducting layer
半导体尼龙 semi-conductingnylon tape
半导体橡胶semi-conducting rubber
半导体屏蔽semi-conducting screen
半导体带semi-conducting tape
半导体漆semi-conducting varnish
半导电的、半导体的semi-conductive
半导体混合物semi-conductive compound
半导电线芯semi-conductive core
半导体层、半电导电层semi-conductive layer
半导体屏蔽、半导电屏蔽semi-conductive screen
半导体semi-conductor
半导体层、半电导电层semi-conductor layer
半连续铸锭机semi-continuous casting machine
半连续铸锭semi-continuous ingot casting
半硫化 semi-cure
半成品semi-cylindrical conductor
半圆形导体semi-finished product
半硬铝线 semi-rigidaluminium wire
半硬同轴电缆semi-rigid coaxial cable
半塞止式接头盒semi-stop joint
半切线式纸包头[绕包头] semi-tangential lapper
半切线式纸包头[绕包头] semi-tangential lapping head
半圆、半圆形体semicircle
半圆形导体semicircular conductor
半导体 semicon
半导体材料挤出机semicon extruder
半导电绝缘屏蔽semicon-insulation
半导体交联聚乙烯semiconducting crosslinked polyethylene
半导体材料semiconducting material
半导体纸、半导电纸semiconducting paper
半导电层、半导体层semiconductive layer
半导体纸、半导电纸semiconductive paper
半导体semiconductor
半导体材料semiconductor material
半硬铝线 semihard-drawnaluminium .
半盲的、愚笨的purblind
半[准]导体 semi(quasi)-conductor
半径损耗 radiiloss
辐射光线、半径范围radius
中间[半成品]线材、非银亮线材 process wire
外部曲率半径 outercurvature radius
外半导电层 outersemi-conducting layer
纤芯半径失配损耗mismatch-off-core-radii loss
电缆转弯的曲率半径与电缆平均直径、节径比、节距比 lay ratio
内半径电层 innersemi-conducting layer
中间[半成品、过程]线材 intermediate wire
半双工 halfduplex
半扭绞结构 halftwist structure
半硬铝线 half-hardaluminium wire
半硬铜线 half-hardcopper wire
动物)半冬眠 half-hibernate
半圆黄铜带half-round brass strip
半波导线 half-waveconductor
半球、范围hemisphere
(扇形线芯的)弯曲半径、棱角半径 edgeradius
二分法、两半dichotomy
临界半径 criticalradius
线芯半径 coreradius
扇形线芯的)棱角半径、弯边半径 corner radius
弯曲半径 bendingradius
允许弯曲半径allowable bending radius
铜芯或铝芯半导体屏蔽聚乙烯绝缘聚氯乙烯护套电缆 Lyonithene cable
金属氧化物半导体MOS(metal-oxide semiconductor)
最小弯曲半径Min.bending radius
作用半径R/A(radius of action)
电平(全)带宽、半最大值处(全)带宽 FWHM(full width at half maximum)
无纬绑扎带unidrectional binding tape
紧绑 swathe
绑结、绑扎、扎结stiching
圈线压紧绑扎机 rodcoil compacting-tying machine
捆、扎、绑、连接 lace
场控金属线绑扎field-controlling wire binding
场控金属线绑扎filed-controlling wire binding
电缆绑结 cablestitching
捆绑、包扎、装钉 bind
绑扎 binder tape
捆绑(物) binding
绑轧绳、捆绑绳binding yarn
包装 packaging
包封encapsulating
灌注 potting
密度 Density
十六锭高速编织机16-carrier high-speed braiding machine
双面双层十六头纱包机16-head double-side douoble-rosette cotton covering machine)
漆包 enamelling
立式四头包带机 4-headvertical tape lapping machine
盘纸包机 412-sheetpaper lapping machine
绕包带 taping
金属焊丝惰性气体保护焊MIG(Metal-Inert Gas) welding
聚酯漆包线漆polyester wire enamel
包封胶 埋封胶 encapsulating compound embadding compound
漆包线漆 wireenamel
成圈机)包扎机 wire coil wrapping machine
线(材)绕包 wire covering
线材绕包机 wirecovering machine
漆包线漆 wireenamel
单纱包线 wireinsulated with single cotton yarn sewings
材线包装 wirepackaging
铅包钢丝铠装、铅(护)套加钢丝铠装 wire-reinforced lead sheath
绕包、缠绕、电缆填充物wormings
披肩 wrap
绕包屏蔽 wrappedscreen
绕包机 wrapper
包装材料 wrapping
绕包方向 wrappingdirection
绕包机 wrappingmachine
钢带绕包 wrappingof steel tape
绕包车间 wrappingworkshop
纱包头 yarncovering head
纱包机 yarnwrapping machine
纱包头yarn-spinning head
立式笼型包带机、立式笼型绕[纸]包机 vertical cage lapper
立式笼型包带机、立式笼型绕[纸]包机 vertical cage type lapping machine
立式漆包炉 verticalenamelling oven
立式绕[纸]包机、立式包带机 vertical lapping machine
立式包带机 verticaltaping machine
涂蜡纱包线 waxedcotton covered wire
双层编包风雨线weatherproof double braid
无包层光纤 uncladfiber
通用绕包机universal wrapping machine
无包套光纤 unjackedoptical fiber
无磁性漆包铜圆线unmagnetic enamelled round copper wire
深漆玻璃丝包铜线varnish-bonded glass-lapped copper conductor
浸漆玻璃丝包铜扁线varnish-treated glass-fibre covered rectangular copper wire
漆包线 varnishedwire
三包层光纤 tripleclad fiber
三层纱包的 triplecotton-covered
十二头三层绕包机triple covering machine with 12 individual heads
三层环氧漆包圆铜电磁线triple epoxy-coated round copper magnet wire
三股编包线triple-braided
三层丝包线 triplexsilk covered wire
三层绕包线 triplycovered wire
三涂层[三包层]光纤 triply-coated fiber
挤包绝缘或护套 tubing
浇包、铸包、浇铸桶tundish
挤包实体绝缘三芯电缆three-core cable with extruded solid insulation
分相铅套[铅包]电缆 three-core single lead sheath cable
紧包光纤、紧套光纤tight (coated) fiber
紧包缓冲套 tightbuffer jacket
紧包保护光纤 tightprotected fiber
紧包结构<光缆的> tight structure
紧包光纤 tightlypackaged fiber
紧包的 tightlywrapped
紧包光纤tightly-buffered fiber
镀锡铜包钢线tin-caoted copper-clad steel wire
镀锡、包锡、挂锡tin-coat
镀[挂、包]锡 tin-coating
镀[挂、包]锡 tinning
螺旋式绕包 to applyhelically
螺旋式绕包 to applyspirally
挤压[挤包]铅护套、压铅 to apply the lead sheath
用纸绳绕包 to applythe paper string
用纸绳绕包 to spinthe paper string
拉线漆包机组 tandemwire drawing and enamelling line
切线式绕[纸]包机 tangential lapper
切线式纸包头[包带头] tangential lapping head
切线式绕包机tangential paper lapping machine
切线式绕包机tangential type lapping machine
带、条 tape
带(状)绝缘、绕包绝缘 tape insulation
包带头、包带机 tapelapper
包带头 tapelapping head
包带机 tapelapping machine
包带式 tape type
带包绝缘导体 tapewrapped conductor
带包式电容锥tape-wrapped type condenser cone
绕包层 tapedcovering
内绕包层 tapedinner covering
带(状)绝缘、绕包绝缘 taped insulation
绕包型接头 tapedjoint
绕包式电缆终端头、绕包终端taped termination
带绕包、包带 tapedwrapping
包带机、包带头tapelapper
带绕包、带包、包带、绕包taping
包带头、带包头 tapinghead
包带机 tapingmachine
包带点 tapingpoint
包带装置 tapingunit
包带节距 tappingpitch
包带速度 tappingspeed
电话线芯[话缆]包带机 telephone core taping machine
丝包束合漆包铜线textile -covered bunched enamelled copper wire
绳绕包 stringspinning
绳绕包机、绕绳机 stringspinning machine
包含、包摄 subsume
合成漆包线synthetic enamel wire
钢带绕包头 steeltape spinner
钢带绕包头 steeltaping head
绞线纸包联合机stranding and paper lapping machine
绞合回转弓(绕包头) stranding flyer
直焊性聚氨脂漆包铜圆线solderable polyurethane enamelled round copper wire
溶剂粘接直焊性漆包线solvent bonding self-fluxing enamelled wire
绳、纱、丝、麻)绕包头 spining head
带包头、包带头、绕包头spinner
纸带(绕包)绝缘 spiral strip paper insulation
螺旋形绕包 spiralwrap
螺旋式绕包机 spiralwrapping machine
插入鞘、包、覆sheathe
有外护套层的卷边纵包金属护套布线电缆 sheathed metal-clad wiring cable
挤[包]护套、护套 sheathing
护套挤包设备sheathing equipment
屏蔽(层)、包屏蔽 shielding
屏蔽包制机shielding machine
包围、围攻 siege
石英包层光纤 silicacladded fiber
有机硅漆包线 siliconenamelled wire
硅酮包层光纤silicone-clad silica fiber
纱(编)丝包线 silk and cotton covered wire
丝包机 silkcovering machine
丝包机 silkwrapping machine
丝包机 silk yarncovered wire
丝包铜线silk-covered copper conductor
丝包软线silk-covered cord
丝包圆铜电磁线silk-covered round copper magnet wire
丝包线 silk-coveredwire
镀银铜包钢线silver-coated copper-clad steel wire
镀银铜包钢(导)线silver-plated copperweld conductor
挤包实体绝缘单芯电缆single cable with extruded solid insulation
单纱包的 singlecotton covered
单纱包漆包线 singlecotton covered enamel wire
单纱包线 singlecotton covered wire
单纱双丝包(的) single cotton double silk covered
单层环氧漆包圆铜电磁线single epoxy-coated round copper magnet wire
单玻璃丝包漆包圆线single glass-fiber covered enamelled round wire
单头单位式纸包机single head unit type paper insulating machine
单丝包线 singlesilk covered wire
单丝包漆包线 singlesilk enamel covered wire
单包层光纤single-coated fiber
单纱包机single-cotton covering machine
单(层)纱包漆包线 single-cotton enamel
单层纸包圆铜电磁线single-paper-covered round copper magnet wire
单丝包的single-silk covered
单丝包机single-silk covering machine
单丝漆包single-silk enamel
书包 schoolbag
密封绕包 sealingwrap
金属护套的无缝挤包、无缝护包金属护套 seamless extrusion of metal sheaths
自粘直焊漆包线self-bonding and self-fluxing enamelled wire
自粘直焊漆包线self-bonding solderable enamelled wire
自粘直焊漆包线self-fluxing and self-bonded enamelled wire
直焊性漆包铜圆线self-fluxing enamelled round copper wire
直焊性漆包线self-fluxing enamelled wire
直焊性聚氨酯漆包铜圆线self-fluxing polyurethane enammelled round copper wire
绕包头、旋转式浮拉器 rotatingflier
橡皮绝缘编包线rubber-covered braided
橡皮绝缘编包风雨线rubber-covered braided\weather-proof
橡皮绝缘双层编包线rubber-covered double braided
三明治(夹心面包片) sandwich
多层绕包的(电缆)外护层 sandwich covering
线盘包装机 reelpacking machine
误差率、误码率、(漆包线的)针孔数 reeor rate
加固带绕包头 reinforcementtape spinner
钱包、小钱袋、手袋purse
四层聚酯漆包扁铜电磁线quadruple polyester-coated rectangular copper magnet wire
人造丝包铜线rayon-covered copper conductor
浇包、铸勺、浇铸桶pouring ladle
浇包、铸勺、浇铸桶pouring-ladle
挤包绝缘电力电缆 powercable with extruded insulation
漆包线漆膜针孔 pinholeof insulation of enamelled wire
油性漆包线漆 plainenamel
平面式绕包头[纸包头] plane lapping head
平面式绕包机 planetype lapping machine
塑料薄膜包线 plasticfilm covered wire
塑料包覆光纤、塑料包层光纤plastic-clad fiber
聚酯漆包铜扁线polyester enamelled rectangular copper wire
聚酯漆包线polyester enamelled wire
聚酯漆包扁铜电磁线polyester-coated rectangular copper magnet wire
聚酯漆包圆铜电磁线polyester-coated round copper magnet wire
聚酯漆包矩形铜电磁线polyester-coated square copper magnet wire
聚酯玻璃丝包扁铜电磁线polyester-glass-fiber-covered rectangular copper magnet wire
聚酯玻璃丝包圆铜电磁线polyester-glass-fiber-covered round copper magnet wire
聚酯玻璃丝包矩形铜电磁线polyester-glass-fiber-covered square copper magnet wire
字形绕包聚乙烯护套polyethylene sheath of figure-8 formation
聚酰亚胺漆包线 polyimideenamelled wire
聚合物包层光纤polymer-clad fiber
聚硅氧烷包层光纤polysiloxane cladding fiber
聚砜及聚缩醛漆包线polysulfone and polyacetal-coated wire
聚氨酯漆包线polyurethane enamelled wire
聚氨酯漆包圆铜电磁线polyurethane-coated round copper magnet wire
聚氨酯-尼龙丝包圆铜电磁线 polyurethane-nylon-coatedround copper magnet wire
缩醛漆包铜扁线polyvinyl acetal enamelled rectangular copper wire
缩醛漆包铝圆线polyvinyl acetal enamelled round aluminium wire
缩醛漆包铜圆线polyvinyl acetal enamelled round copper wire
缩醛漆包线polyvinyl formal enamelled wire
高强度缩醛漆包铜圆线polyvinyl-formal enamelled round copper wire with high mechanical properties
缩醛漆包线polyvinylacetal enamelled wire
包装 packaging
包装等级 packaginglevel
包装机 packagingmachine
包装用线盘packaging reel
包装标准 packagingstandard
包装箱packing-case
纸包机 papare coveringmachine
纸包扁铜绕组线 papercovered rectangular copper winding wire)
纸包扁线 papercovered rectangular wire
纸包圆线 papercovered round wire
纸包头 papercovering head
纸包机 papercovering machine
纸包头 paperlapper
纸(带绕)包 paper lapping
纸包纱包联合机 paperlapping and cotton covering machine
纸包头 paperlapping head
纸包机 paperlapping machine
纸包工序 paperlapping operation
纸带(绕包)绝缘 paper ribbon insulation
纸带(绕包)绝缘 paper tape insulating
纸包 papertaping
纸包机 papertaping machine
纸包头 paperwrapping head
纸铝箔纵包机 paper-aluminium-foilapplicator
漆包纸绝缘电缆[电磁线] paper-core enamelled type cable
纸包铜线paper-covered copper conductor
纸包扁铜电磁线paper-covered rectangular copper magnet wire
纸包圆铜电磁线paper-covered round copper magnet wire
纸包矩形铜电磁线paper-covered square copper magnet wire
纸包线paper-covered wire
纸绝缘铅包的paper-insulated lead covered
纸包头 papperlapper
无磁性漆包线non-magnetic enamelled wire
非组合包套nonintegral jacket
漆包层数 number ofenamel coats
缺陷数、(漆包线)、针孔数 number of faults
尼龙丝包圆铜电磁线nylon-fiber-covered round copper magnet wire
油基漆、油性漆包线漆oil-base enamel
油性漆包线 oleoresinous enamelled wire
油性漆包线oleo-resin enamelled wire
油树脂漆、油性漆包线漆oleoresinous enamel
油树脂漆、油性漆包线漆oleoresinous varnish
疏绕、间隙绕包 openlapping
正反向绕包、正反向绞合opposite-direction lapping
松包光纤光缆 opticalfiber cable with fibers loosely packaged
紧包光纤光缆 opticalfiber cable with fibers tightly packaged
挤包实体绝缘多芯电缆multicore cable for extruded solid insulation
多头同心包带机multiple head concentric taping machine
(漆包机的)导轮组 multiplesheave
镍包铜线、镀镍铜线nickel coated copper conductor
镀镍铜线、镍包铜线nickel-clad copper wire
镀镍铜线、镍包铜线nickel-coated copper wire
镀镍铜包钢线nickel-coated copper-clad steel wire 包层不圆度 non-circularity of cladding
用金属包 metal
金属包覆导体 metalclad conductor
金属包覆层 metalcover layer
金属包层 metalcovering
金属包覆电缆metal-clad cable
金属包覆导体metal-clad conductor
卷边纵包金属护套布线电缆metal-clad wiring cable
金属包带 metalliccover tape
改性聚酯漆包铜圆线modified polyester enamelled round copper wire
低损耗 FEP
包层石英光纤 lowloss FEP-clad silica fiber
行李、皮箱、皮包luggage
电磁线、漆包线 magnetwire
匹配包层光纤 matchedcladding fiber
月牙板式钢带绕包头link-type tape wrapping head
单层纸 simplexpaper
单层滚筒七头拉线机single deck 7 heads type machine
单层金属编织机 singletier type wire braiding machine
单层的single-layer
单层电缆single-layer cable
单层绞线single-layer strand
单层纸 single-plypaper
单层纸single-wire paper
单层 monolayer
钢带铠装电缆 tapearmoured cable
钢带铠装 steeltape armour
钢带铠装电缆 steel tapearmoured cable
钢带铠装 steeltape armouring
钢带铠装机 steeltape armouring machine
钢带铠装电缆steel-tape armoured cable
铅包钢带铠装、铅套加钢铠装l.s.s.t.(lead-sheath,steel-taped)
铅包钢带铠装、铅套加钢带铠装lead-sheath,steel-taped
内钢带铠装电缆internal steel-tape armoured cable
双钢带铠装 double tapearmour
双层钢带铠装 doublelayer of steel-tape armour(d.s.t.a.)
涂层钢带铠装电缆coated steel tape armoured
钢带铠装电缆band-armoured cable
单螺杆挤出机 singlescrew extruder
焦烧、早期硫化(挤出机筒内) scorching(in extrudercylinder)
螺杆式挤出机 screwextruder
挤出头、压力模座 pressblock
压力型多层一次挤出模pressure-type coextrusion die
分段式挤出机piggyback extruder
行星齿轮式挤出机planetary gear extruder
(塑料)挤出机plastic extruder
制粒挤出机pelletising extruder
(挤出机)斜角机头 obliquehead
单段式挤出机one-stage extruder
光缆护套挤出生产线optical cable sheathing line
多色挤出机multi-colour extruder
多层挤出机multi-layer extruder
多级[多段]式挤出机 multi-stage extruder
多根挤出法multi-wire insulation process
多头挤出装置multiline extrusion system
多层挤出 multipleextrusion
(挤出机)螺杆的计量区metering section of a screw
混炼挤出机mixer-extruder
混炼、排气、挤出联合机 mixing,venting and extruding machine
标色挤出机 markingextruder
铅管挤出机lead-pipe extrusion press
内皮挤出机 innerskin extruder
绝缘机头、挤出机头insulating machine head
高效挤出机 highoutput extruder
高速挤出生产流水线 highspeed tandemized extrusion line
高发泡挤出high-foaming extrusion
高发泡挤出生产线high-foaming extrusion line
高速挤出生产流水线high-speed tandemized extrusion line
卧式挤出机horizontal axis extruder
卧式挤出机horizontal extrusion press
热挤出 hotextrusion
热挤出用润滑剂 hotextrusion lubricant
静液(压)挤出 hydrostatic extrusion
模芯导向器(挤出机模子) guider tip
注气体挤出机gas-injection extruder
热挤出 hotextrusion
泡沫挤出生产线 foamextrusion line
泡沫绝缘挤出 foaminsulation extrusion
前端驱动挤出机front-end drive extruder
光纤松套管-紧包缓冲层挤出生产线 fiber-optic loosetube-tight buffer
出线区、挤出区 exitzone
挤出机 extr.
可挤出性、可挤压性extrudability
挤出物、挤制材料extrudate
挤出物温度extrudate temperaturev
挤出[压、包、制] extrude
挤出[压、包、制]的 extruded
挤出型绝缘电缆extruded cable
挤出型绝缘电缆extruded dielectric cable
挤出机、挤压机extruder
挤出机筒体 extruderbarrel
挤出机机筒内径extruder bore
直角挤出机头extruder crosshead
挤出(机)模具 extruder dies
挤出(机)头 extruder head
挤出机挤出量extruder output
挤出机螺杆 extruderscrew
挤出[制、包、压] extruding
挤出机 extrudingmachine
挤出[制、包、压] extrusion
挤出模具 extrusiondie
挤出(机)模具 extrusion dies
挤出涂漆法extrusion enamelling process
挤出发泡 extrusionfoaming
挤出发泡法extrusion foaming method
挤出(机)头 extrusion head
挤出指数 extrusionindex
挤出生产线速度extrusion line speed
挤出压力 extrusionpressure
挤出[压、包、制]方法 extrusion process
挤出工艺 extrusionprocessing
挤出性能 extrusionproperty
挤出量、挤出速度[量] extrusion rate
挤出(机)螺杆 extrusion screw
挤出技术、挤出工艺extrusion technology
挤出温度 extrusiontemperature
挤出机模芯extrusion tip
挤出模具 extrusiontool
挤出速度 extrusionvelocity
挤出轮 extrusionwheel
有壳挤出 extrusionwith shell
无壳挤出 extrusionwithout shell
(漆包线的)挤出涂漆法 emailexmethod
(漆包线的)挤出涂漆法 emailexprocess
双螺杆挤出机 doublescrew extruder
双层挤出(机)头 double(extruder)head
双层一次挤出(法) double-layer coating co-extrusion
双层挤出(机)头 double-layer extrusion head
双层挤出(机)头 dual (extruder) head
双层挤出机 dualextruder
非连续性挤出discontinuous extrusion
双层直角挤出机头double layer crosshead
挤出机机头口型 dielips
挤出机机头口型间隙 dielips gap
(控制)压力挤出法controlled pressure extrusion
粉末涂敷 powdercoating
室温固化 coldcuring cold setting
十八盘两段卧式绞线成缆机18-bobbin 2-cage horizontal wire stranding and laying-up machine2/2
芯单段成缆机2/2-core single cage laying-up machinev
成缆、布[配]线、敷设电缆[线] wire
未成缆光纤 uncabledfiber
绞线成缆联合机stranding and laying-up machine
单节距成缆机 singletwist cabler
单节距[单绞式]成缆机 single-twist cabling machine
刚性成缆机 rigidcabling machine
行星式成缆机planetary cabler
行星式成缆机planetary cabling machine
行星式成缆机planetary laying-up machine
行星式成缆机planetary-type cabling machine
光纤成缆技术 opticalfiber laying-up technology
成缆角 layingangle
绞缆、成缆、线芯绞合、敷设laying up
盘式成缆机 layingup drum twister
成缆工段 laying upsection
成缆 laying-up
成缆和包带生产线laying-up and taping line
成缆角 laying-upangle
成缆机、线芯绞合机laying-up machine
成缆操作、成缆工序laying-up operation
成缆用盘 laying-upreel
重型电缆敷设装置、重型成缆设备 heavy cabling equipment
双节距成缆机double-twist cabling machine
双绞式[双节距]成缆机 double-twist flyer-type high-speed stranding machine
双绞式[双节距]成缆机 double-twist strander/laying-up machine
盘式成缆机 drumcabling machine
盘绞式成缆机 drumtwister laying-up machine
盘绞式成缆机 drumtwister type cabling machine
盘绞式成缆机 drumtwisting assembling machine
盘绞式绞线机、盘绞式成缆机drum twisting machine
线芯绞合、绞缆、成缆core stranding
全套挤塑-成缆生产线 complete extrusion-cablingline
成缆材料、包覆材料cladding material
成缆、绞缆cable-laying
成缆机cable-laying-up machine
成缆构件 cabled complement
成缆光纤 cabledoptical fiber
成缆(后)包带 cabled tape
成缆机、成缆机、电缆盘cabler
成缆、成缆、电线敷设、布线、电缆敷设 cabling
成缆损耗 cablingabsorption
成缆工段 cablingdepartment
成缆设备、布线设备cabling equipment
成缆机 cablingmachine
成缆放装置 cablingpay-off
成缆工艺 cablingprocessv
电缆 cable
弓式成缆机 bowcabling machine
弓式成缆机 bow typestranding machine
绞缆机、成缆机assembling machineSZ
绞成缆机 SZcabling machineSZ
绞合机、左右绞合机、 SZ
成缆机 SZstrander
电缆填充 cablefilling
绕包、缠绕、电缆填充物wormings
凡士林填充市话电缆vaseline filled local cable
电缆内壁填充剂[物] wall cable filler
填料、填充、塞入 stuffing
填料[填充]法 stuffing process
浇注温度、填充温度pouring temperature
粉沫填充电缆 powderfilled cable
压力填充 pressureexcited filling
聚乙烯填充物polyethylene filler
聚丙烯填充绳polypropylene filler yarn
石油膏填充petrojelly filling
石蜡油填充聚乙烯绝缘电缆petrolatum-filled polyethylene-insulated cable
石油膏填充物、石油膏填充器petroleum jelly cable filler
石油膏填充petroleum jelly filling
非导电填充物non-conductive filler
矿物填充交联聚乙烯mineral filled crosslinked polyethylene
填充物、填料 loadingmaterial
膏状物填充松管光纤loose tube optical fiber filled with jelly
石油膏填充塑料电缆jelly filled plastic cable
石油膏填充设备jelly-filling equipment
麻填料、填充麻 jutefiller
内填充(料) inner filler
内填充(护套)料[混合物] innerfilling compound
内填充护套 innerfilling sheath
无填充料 inorganicfiller
填充包套联合生产线integrated filling and sheathing line
填充四线组、间充四线组interstitial quad
高填充胶料highly-extended compound
润滑脂填充线芯grease-filled core
全[连续]填充电缆、纵向密封电缆 fully filled cable
光缆填充机 fiberoptic cable filling machine
填充系数 fillfactor
填充系数、占体率 fillin ratio
填充线芯导线fill-core conductor
填充系数、占体率fill-in ratio
填充电缆 filledcable
填充用户电缆 filledservice cable
填充[封]物、填料、填芯 filler
填充剂 fillercompound
非填充电缆、无填充电缆fillerless cable
填充、充填、填料filling
填充复合物、填料、填充剂、填充混合物、浇注料、浇注剂 filling compound
填充机 fillingmachine
填充材料 fillingmaterial
填充温度、浇注温度filling temperature
挤包内护层、内填充护套extruded inner covering
环氧填充密封端 epoxyfilled sealing end
连续[全]填充电缆、纵向密封电缆 continuously filled cable
色标聚乙烯石油膏填充电话电缆color coded polyethylene jelly filled cable
石油膏填充粘结护套联合设备combined petro-jelly filling and bonded sheath equipment
填充率 compactionratev
装料、填充、充电、电荷charge
电缆填充剂cable-filling compound
电缆填充设备cable-filling plant
中心填充物 centerfiller
中心填充物、填芯centre filler
电缆填充、电缆占用率、电缆填充率、电缆线对利用率 cable fill
电缆填充 cablefilling
电缆填充装置 cablefilling applicator
电缆填充设备 cablefilling equipment
电缆填充机 cablefilling machine
电缆填充麻 cablefilling yarn
电缆填充用油膏、电缆填充油膏cable jelly
填充、填料、锁紧装置blocking
色标聚乙烯石油膏填充CCP-JF(color code polyethylene-jelly filled)
扁平编织线 flatbraid
编织 braiding
浇铸〔流延〕 casting
涂敷 coating
包封encapsulating
耐磨性 AbrasionResistance
电缆放线车 wheelcable drum carriage
放线车 wirebarrow
放线转台[转盘] wire pay-off turntable
放线车wire-barrow
立式越端放线架vertical flyer pay-off frame
垂直升降式收、放线装置vertical lift pay-off and take-up
轨道滑动式放线装置walk-through pay-off
放线、解绕、退绕unreeling
退扭放线装置untwisting pay-off system
退绕[放线]装置 unwinding device
移动式龙门收、放线架travelling drum take-up and pay-off stand in port
移动式龙门收、放线架travelling drum take-up and pay-off stand in portal execution
行走式放线装置travelling pay-off
行走式放线架travelling pay-off stand
双头立式放线架 twinheaded swift
放线(装置) take-off
放线架[装置] take-off stand
收放线(装置) take-up and pay-off
张力控制放线装置tension controlled pay-off
供方、承制厂、放线装置、交货方、制造厂 supplier
放线盘 supplybobbin
放线牵引轮 supplycapstan
放线架 supplyframe
放线盘 supplyreel
放线架[装置] supply stand
收放线装置spooler-unspooler
固定放线装置stationary pay-off
固定式放线架stationary pay-off stand
固定式收放线架 stationarytake-up and pay-off stand
成捆或成筒放线装置stempack or drumpack pay-off system
圈式放线装置、捆式放线装置stempack pay-off
越端放线的刚性架绞线机spin-off rigid-frame strander
无轴式恒定张力放线装置shaft type constant tension pay-off
无轴式恒定张力放线装置shaftless constant tension pay-off
无轴式放线设备 shaftlesspay-off equipment
无轴式放线系统shaftless pay-off system
单头立式放线架 singleheaded swift
单盘放线装置 singlereel pay-off
转盘式放线装置 ringflyer
旋转放线装置 rotarypay-off
锥形旋转放线架rotating cone
旋转放线装置rotating pay-off
放线装置 re-reeler
门式放线架[装置] portal type pay-off
门式放线架 portal-typepay-off stand
放线(装置) pay off
放线人工控制速度 payoff manual speed control
放线装置 pay-ins
放线储线器、放线储存器pay-off accumulator
组合放线装置 pay-offand bank
收、放线装置 pay-offand take-up
收、放线设备 pay-offand take-up equipment
组合放线装置 pay-offbank
放线盘 pay-offdrum
放线架、放线框 pay-offframe
放线导轮架 pay-offguid sheave stand
放线机 pay-offmachine
放线平衡器 pay-offneutralizer
放线架 pay-offrack
放线盘 pay-offreel
放线速度 pay-offspeed
放线盘 pay-offspool
放线架[装置] pay-off stand
成圈铜杆放线架pay-off stand for copper rods in coils
放线架 pay-offswift
放线装置 pay-offunit
放线速度 pay-offvelocity
放线架pay-off-rack
放线角 pay-outangle
放线架 pay-outstand
放线装置 pay-outunit
放线 payed off
放线盘 paying outdrum
放线盘 paying outreel
放线自动控制微调payoff automatic-control triment
放线盘架 payoffbobbin retainer
放线张力 payofftension
越端放线(装置) over-end pay-off
越端放线装置over-end pay-off unit
越端放线、轴向放线over-flange pay-off
越端放线拉线over-head take-off drawing
越端放线装置 overenddereeler
越端[轴向]放线装置 overhead pay-off
越端式放线架overhead pay-off-rack
越端牵引、越端放线overhead-pull-off
电动放线装置motor-driven pay-off
机动放线架 motor-drivenwire pay-off swift
主动放线装置、电动放线装置motorised pay-off
多盘放线装置multi-bobbin pay-off
无驱动放线non-drive pay off
移动式放线装置 mobilepay-off
行走式放线架 mobilepay-off stand
手动螺杆升降式放线装置manual screw lift pay-off
放线装置 let-offapparatus
放线篮架 inputcore drum carrier
放线盘、进线线盘、生产用线盘、机用线盘 input reel
重型无轴式放线装置heavy duty shaftless pay-off
越端放线装置 flyerdereeler
浮转式放线装置 flyerpay-off
越端放线装置 flyerre-reeler
飞环[越端]式放线装置 flyoff hood arrangement
放线架[装置] feed stand
拉线鼓轮、(电缆敷设用)放线盘 drawing drum
被动式放线装置 drivensupply arrangement
筒式放线装置drumpack pay-off
双盘越端放线(装置) dual flyer pay-off
双盘越端放线(装置) dual flyer type pay-off
双盘放线装置 dualpay-off
双盘放线装置 dualpay-off unit
放线浮拉器de-reeling flyer
越端放线架de-reeling flyer frame
圈线绕机、圈线放线架decoiler
放线装置 dereeler
放线 despooling
放线装置despooling unit
退绕器、放线器dewinder
绕线轴架、多轴放线架creel
放线架 creelstand
毛刷式放线装置 curlflyer
恒定张力放线架constant tension lef-off stand
中心放线盘 corepay-off reel
锥形、锥、锥体、拉线鼓轮、(收、放线架的)托脚 cone
锥形越端放线装置cone-type flyer pay-off
成圈复绕装置、收放线装置coiling and uncoiling device
悬臂式收、放线装置cantilever pay-off and take-up
中心股放线架 centercore pay-off stand
中心放线站 centralpay-off station
电缆放线车 cabledrum carriage
线盘放线架 bobbinpay-off creel
线盘放线速度 bobbinpayout speed
自动放线装置automatic dereeler
退扭放线 backtwist pay-off
盘转式放线装置barrel-type pay off
毛刷式放线装置 curlflyer
中心放线站 central pay-offstation
越端放线装置的摩擦片abrasive plate
绕线、收线、绕包 wind
绕线、收线 wind up
收线器[机]绕线机 wire spooler
收线装置 wiretake-up device
绕线机、收线机 wirewinding machine
立式静盘成圈收线装置vertical axis stalabloc coiler
立式升降收线(装置) vertical lift take-up
立式螺旋升降收线架vertical screw lift take-up stand
立式静盘成圈收线装置vertical stationary block coiler
行走式收线架transportable take-up stand
自排式收线(装置) traversing take-up
双盘收线架 twindrum take-up stand
双盘收线装置 twinspooler
顶尖式收线器、无轴式收线装置tailstock spooler
绕线、收线 take up
收线架 take-offrack
绕线、收线、收线(装置) take-up
收线储存器、收线储线器take-up accumulator
收线绕线装置 take-upand winding unit
组合收线装置 take-upbank
收线装置 take-upblock
收线牵引轮 take-upcapstan
收线成圈机 take-upcoiler
收线盘 take-updrum
收线盘撑架 take-updrum cantilever
收线篮架 take-updrum carrier
收线架、收线框take-up drum frame
盘式收线架、收线盘架take-up drum stand
收线架 take-upframe
收线电机 take-upmotor
收线盘 take-upreel
收线速度 take-upspeed
收线盘 take-upspool
成盘收线装置 take-upspooler
收线架[装置] take-up stand
收线绞线机 take-upstrander
收线张力 take-uptension
收线架[装置]、收线装置 take-up unit
悬挂式收线架susceptance take-up station
绕线、收线 spool
自动收线装置spooling
收线设备、收线、绕线spooling equipment
收线装置 spoolingmachine
收线架 spoolingstand
局部退火、收线机 spotannealing
氨基甲酸酯橡胶urethane rubber
聚氨酯泡沫橡胶polyurethane foam
聚氨酯-尼龙丝包圆铜电磁线 polyurethane-nylon-coatedround copper magnet wire [化]阿摩尼亚、氨 ammonia
聚氨酯PUR(polyurethane)
布置、安装 set out
安装、装配、布置、设置set up
安装、装配、布置、设置set-up
安装、排字、布景setting
安排、解决 settle
安排、准备、配置 setup
安息日的sabbatical .
安全的、平安的 safeadv
安全地、平安地 safely
安全、可靠 safety n
安全设备、保险装置safety
安全[防护]装置 safety device
可靠性、安全性reliability
运行[操作]可靠性、运行[操作]安全性 reliability of operation
烦燥不安的perturbed
安全[保险、紧急]开关 overcurrent cut-out switch
运行[操作]可靠性、运行[操作]安全性 operating reliability
运行[操作]可靠性、运行[操作]安全性 operating safety
就职、安装、装置installation
安装电缆installation cable
安装费用、设备投资installation cost
安装图、施工图installation drawing
安装说明书installation instructions
安装[装置]工具 installation kit
安装程序installation program
安装规程[标准] installation rule
安装标准[规程] installation standard
无线电装置用电线、安装线、装备用电线 installation wires
敷设[安装]工程、敷设[安装]工作 installation work
安装容量、安装功率installed capacity
安装功率 installedpower
安装线interconnection wire
自身安全装置intrinsically safe installation
岛、安全地带 island
使安全、偿付indemnify
高安全性电缆high-safety electric cable
高温安装线high-temperature hook-up wire
布线用线、安装线、跨接线、柔软连接线 hook-up wire
适合 fit
安装工、装配工 fitter
安装说明 fittinginstruction
安装说明书 fittinginstructions
安装、修理、确定 fix
治愈(病人)、安顿 fix up
固定、安装、附件、接头fixing
固定安装线 fixturewire
带状(室内布)线、扁形编织安装线 flat webbed building wire
安全系数、安全[保险]系数 factor of assurance
电气安装 electricinstallation
安装线 equipmentand building wire
设备安装线equipment hook-up wire
安慰、取悦于conciliate
管道安装线conduit-installation wire
(做)预算、安排 budget
电缆安装、电缆敷设、电缆装置[设备] cable installation
电缆敷设[安装] cable laying
直径) screwlength nD
自焊性、直焊性self-solderability
直角连接器right-angle adapter
直角接头right-angle connector
直角插头right-angle plug
基准面直径reference surface diameter
预矫直机pre-straightener
预矫直机pre-straightening machine
预矫直装置pre-straightening unit
平均直径、层心直径pitch diameter
直埋式光缆 plow-inoptical cable
远程直接数据处理、远程在线数据处理 on-line remote data processing
直接蒸汽硫化 opensteam cure
标称直径 nominaldiameter
最小出线直径 min.final diameter
最小出线直径min.final diameter
最小出线直径 minimumfinal diameter
不同心度、偏心度、不成直线、失配、失调、不匹配 misalignment
模场直径 modefield diameter
低压直流输电信息传输 lowtransmission voltage d.c. data transmission
低压直流输电信息传输 lowtransmission voltage d.c.data transmission
最大允许直径 maximumacceptable diameter
最大允许直径 maxinumacceptance diameter
最大理论直径孔径maxinum theoretical numerical aperture
线性聚乙烯、直链聚乙烯linear PE
直线式储线器 linearaccumulator
直线式电缆牵引装置linear cable engine
大、中、小直径large,medium,small diameter
大直径电缆large-diameter cable
大号[直径]线、粗线 large-diameter wire
大号[直径]线、粗线 large-siza wire
大截面[直径]电缆 large-size cables
电缆的直接冷却[整体冷却]、电缆的间接冷却[单面冷却] lateralcooling of cables
进线直径 inletdiameter
直线式单头大拉机in-line bull block machine
高精度线材矫直器 highprecision wire straightener
耐热直焊性漆包线heat-resistant and solderable enamelled wire
光纤直径 fiberdiameter
出线直径、成品线直径finished wire diameter
固定垂直偏振 fixedvertical polarization(
线盘)侧板直径 flange diameter
压扁机、压延机、矫直机、扁条拉模、拉扁钢丝模、压延工 flattener
矫直辊、矫正辊dressing roll
有效纤芯直径effective core diameter
直埋 directburial
地下敷设、直埋 directburial (in earth)
直埋电缆 directburial cable
直埋电缆 directburied cable
冷却水管、电缆的直接冷却direct cooling of cable
直接牵引拉线机 directpull drawing machine
远程直接数据处理、远程在线数据处理 direct remote data processing
直接蒸汽硫化 directsteam cure
直流电压 directvoltage
直接水冷却电缆 directwater-cooled cable
直接波 directwave
直流耐压试验direct-current withstand voltage test
直流式压铅机direct-flow lead press
直接冷却式模架directly cooled dieholder
不准直decollimation
直径控制装置、线径控制器diameter control device
直接耦合 directcoupling
直接串音 directcrosstalk
直流电(流) direct current
直流电缆 directcurrent cable
直流电力电缆 directcurrent power cable
直流电阻 directcurrent resistance
直接拉丝 directdrawing
直接传动 directdrive
电缆在屏蔽前的直径diameter of the cable beneath the shield
直径比 diameterratio
直径缩小、缩径diameter reduction
直径公差 diametertolerance
十字机头、直角机头cross head
十字机头、直角机头cross-head
十字头、直角机头crosshead
直流增音机d.c.relay repeater
直流电压d.c.voltage
直流电压强度d.c.voltage strength
恒(向、定、流)电流、等幅电流、直流 continuous current
直流电压continuous voltage
铜带矫直装置 copperstrip straightener unit
线芯直径、纤芯直径、(线盘)筒径 core diameter(
纤)芯(直)径偏差 corediameter deviation
电缆芯(直)径比 core ratio
瞬变[断]直流电压 chopped d.c. voltage
包层直径 claddingdiameter
包层表面直径偏差cladding surface diameter deviation
同轴式直角挤出机头coaxial extrusion crosshead
圈线预矫直机coil-end pre-straightenner
大截面[直径]电缆 cable with big cross-sectional areas
直埋电缆、地下电缆buried cable
直埋光缆 buriedservice lightguide
水线电码直接打印机cable code direct printer
电缆直径控制 cablediameter control(
线盘)轴孔直径、线盘轴孔直径 bore diameter
平均纤芯直径 averagecore diameter
筒体直径、线盘筒径barrel diameter
线模直径 bearingdiameter
直流电力电缆 D.C.Power cable
直流电阻不平衡 D.C.resistance unbalance
直流耐压试验 D.C.withstand test
直流电力电缆D.C.power cable
直流火花试验器[机、仪] DC spark testerdiameter
直径 DIA
导线直径 DOA
缆芯包带层直径 DOCC
泡沫/实心皮绝缘的泡沫部分直径 DOFC
双层护套电缆的内护套直径DOIJ
线对直径DiameteroverpairsDOP
屏蔽直径diameterovershieldDOS
钢屏蔽直径DiameteroversteelshieldDOSTL
直接淬火线杆 ED rod
高压直流输电子工业HVDC(high-voltage d.c. transmission)
高压直流输电HVDC(high-voltage direct current transmission)
长度与直径之比、长径比L/D ratio
结构高度(对绝缘子串元件) spacing(for stringinsulator unit)
绝缘子串 insulatorstring
绝缘子串元件 stringinsulator unit
不平衡电流、串音电流unbalanced current
不可懂串音、非线性串音unintelligible cross-talk
串列式三机架线材压扁整边机three-stand tandem wire flattening and edging mill
串列式三机架线材压扁机three-stand tandem wire flattening mill
串连 tandem
串列式退火机、连续拉丝退火机tandem annealer
串联、串列式布置[装置] tandem arrangement
串联、串列式布置tandem connection
串列式挤出机 tandemextruder
串列式轧机、直线式轧机tandem rolling mill
串列式线材轧机tandem-type rod mill
实路对幻路的串音side-to-phantom crosstalk
实路对幻路的远端串音side-to-phantom far-end crosstalk
实路对实路的串音、实线间串音side-to-side crosstalk
实路对实路的串音耦合、实线间串音耦合 side-to-side crosstalk coupling
实线间的远端串音side-to-side far-end crosstalk
串联电路、串联 seriescircuit
串联、串联电路 seriesconnection
串联干扰电压 seriesinterference voltage
串联电阻 seriesresistance
反射近端串音reflected near-end crosstalk
串音 overhearing
近端串音 near-endcrosstalk
近端串音衰减near-end crosstalk attenuation
近端串音损耗near-end crosstalk loss
近端串音 near-endtalk
可懂串音、线性串音intelligible (linear) cross-talk
间接串音 indirectcrosstalk
高频串音特性high-frequency crosstalk performance
光纤串扰 fibercross-talk
远端串音 far-endcrosstalk
远端串音衰减 far-endcrosstalk attenuation
远端串音损耗 far-endcrosstalk loss
远端串音防卫度far-end crosstalk ratio
端串扰、端串音 endcross-talk
串音、串话 crosstalk
串音[串话]特性 cross talk characteristic
串音测量[试]法 cross talk measuring method
抗串扰性 crosstalk resistance
串音信号cross-talk signal
串音、串话、串扰、串光、串色crosstalk
串音衰减 crosstalkattenuation
串音衰减当量crosstalk attenuation unit
串音平衡 crosstalkbalance
串音平衡 crosstalkbalancing
同(轴对)串四(线组) crosstalkbetween coaxial pair and quad
四(线组)串四(线组) crosstalkbetween star quad
四(线组)串同(轴对) crosstalkbetween star quad and coaxial pair
同(轴对)串同(轴对) crosstalkbetween two coaxial pairs
串音电路、串音耦合crosstalk circuit
串话补偿 crosstalkcompensation
串音耦合、串话耦合 crosstalkcoupling
串音耦合损耗crosstalk coupling loss
串音电流 crosstalkcurrent
镀锌 galvanising
镀锌 zincplating
镀锌槽 zincplating bath
镀锌铁丝zinc-coated iron wire
铠装用镀锌低碳钢丝zinc-coated low-carbon steel armour
镀锌钢绞线zinc-coated steel strand
镀锌钢带zinc-plated steel tape
镀锌 zinking
高强度镀锌钢丝[芯线]high-strength galvanized steel core
高强度镀锌钢丝[芯线]high-strength zinc-coated steel core
电镀、镀锌galvanizationvt
电镀、镀锌galvanize
电镀的、镀锌的galvanized
镀锌铠装钢丝galvanized armour wire
铅淬火高张力镀锌钢丝galvanized high-tensile plough-steel wire
镀锌软[低碳]钢丝 galvanized mild steel wire
镀锌铠装钢带galvanized steel armour tape
镀锌钢芯线、镀锌钢丝galvanized steel core wire
镀锌钢丝galvanized steel wire
镀锌钢绞线galvanized stranded wire
镀锌钢丝galvanized wire
镀锌槽、锌浴galvanizing bath
镀锌炉galvanizing furnace
镀锌装置、电镀装置galvanizing plant
镀锌收线架galvanizing take-up frame
电镀的、镀锌的galvanic
防腐镀锌钢丝corrosion preventing grease-coated galvanized wire
管式绞线机、管绞机 tubestrander
管式绞线机、管绞机tubular closer
管绞机 tubularstrander
管式绞线机、管绞机tubular stranding machine
管绞机筒体stranding rotor
高速管绞机 highspeed tubular stranding machine10
对群绞设备10- twingroup stranding machine
十三头绞线机13- foldtwisting machine
十八盘绞笼18-bobbin bay
压铝护套 ExtrudedAluminium Sheath
钢芯铝绞线 ACSR
钢芯铝绞线 ACSRcable4
对群绞设备4- twingroup stranding plant
绞盘、绞车 winch
钢丝绳、钢缆、钢绞线wire rope
绞线机wire-stranding machine
绕接、缠绕接线法、导体的扭绞连接 wire-wrap connection
钢丝绳、钢缆、钢绞线wirerope
带退扭的(绞线) with backtwist
不带退扭的(绞线) without backtwist
绞笼架 yoke
立式绞线机 verticaltwister
绞合电缆 twsitcable
绞合补偿器、节距调节器twsit compensator
分层绞线 twsitconductor
绞合对、多股绞合线twsit pair
扭绞节距、绞距 twsitpitch
复星绞组 twsitquadruplet
扭绞试样成型机 twsittest specimen forming machine
绞合线 twsit wire
同向绞合unidirectional lay
同节距绞合 unilaystranding
单位式(绞合)电缆 unit cable
单位式绞合 unitlay-up
单位屏蔽对绞电缆 unitshielded paired cable
单位式绞合 unitstranding
单位式绞缆机 unitstranding machine
单位绞电缆 unittwin cable
单位式(绞合)电缆 unit-stranded cable
单位绞unit-stranding
单位式(绞合)电缆 unit-type stranded cable
三层同心绞合电缆、三相同轴电缆 triple concentric cable
筒式绞线机tubolarbloc
管(筒)笼式绞线机 tubolarbloc cage strander
管绞机 tubularstrander
预加压管式绞线机tubular strander with prestressing
防噪音管式绞线机tubular strander with sound-proof guards
管(式)绞(合) tubularstranding
双绞和四线组对绞电缆twin and quad pairing cable
双芯电缆、对绞电缆 twincable
三层共挤 tripleextrusion
双金属挤压、多层一次挤出、共挤出(法)co-extrusion
共挤十字机头coextrusion crosshead
三层共挤 bonedtriple extrusion
直埋 dirdectburial
校直 straighten
辊式矫直机straighteners
矫直straighening
直径 diameter
成品电缆的标称直径BASFOD
线材矫直器 wirestraightener
线材矫直切割机 wirestraightening and cutting machine
垂直安装[排列] vertical arrangement
立式垂直浇铸vertical cast
立式垂直浇铸vertical casting
耐垂直蠕变性vertical creep resistance
垂直燃烧试验vertical flame test
垂直敷设 verticalinstallation
垂直升降式电缆盘架vertical lift type drum stand
垂直偏振 verticalpolarization
直升装置用电缆vertical riser cable
垂直敷设 verticalrun
垂直悬挂试验vertical suspension test
垂直托架火焰[燃烧]试验 vertical-tray flame test
垂直偏振电磁波vertically-polarized electromagnetic wave
地下电缆、直埋电缆underground cable
组合式辊压模、互成直角的四辊轮拉丝模装置 turks(-)head
互成直角的四辊轮拉丝模装置turks(head) roll
直径缩小、缩径thinning
直通线路 throughcircuit
直通线路 throughline
直接通信through-traffic
定线、与….成一直线 to be flush
定线、与……成一直线 to bein line with
将金属线拉制成大、中、小直径to draw wires down to large,medium,small diameters
拉伸、矫直stretching
直裂缝、裂缝[纹、口]、拼合的、分开的 split
直线式储线器straight accumulator
直接浸渍法 straightdipping process
平直侧板 straightflange
直通接头 straightjoint
直链聚乙烯、线性聚乙烯straight-chain PE
直链聚合物straight-chain polymer
直线式储线器straight-line accumulator
直线式拉线straight-line drawing
直线式拉线机straight-line drawing machine
直线式拉线机straight-line wire drawing machine
直通插头straight-plug
直[平]辊式拉线机 straight-roll wire drawing machine
直通接头[连接器] straight-through connector
直线式拉线straight-through drawing
直线式拉线机straight-through drawing machine
直通接头straight-through joint
直通式压铅机straight-through lead press
直通式压铅机straight-through press for lead-sheathing cables
拉直、(线材)矫直 straighten
矫直的电缆试样straightened cable sample
矫直机[装置]、矫直器、校直机 straightener
矫直、校直straightening
矫直机straightening machine
矫直辊straightening roll
拉直、拉伸、拉紧stretch
拉伸机、矫直机stretcher
小(直径)同轴对 small-diameter coaxial pair
直焊性电磁线solderable magnet wire
中线直接接地 solidearthing of neutral
中线直接接地 solidgrounding of neutral
直接接地中线 solidlyearthed neutral
直接接地网络[系统] solidly earthed system
直接接地中线 solidlygrounded neutral
直接接地网络[系统] solidly grounded system
湿式中拉机 mediumwet drawing machine
中拉机 mediumwire drawing machine
中拉intermediate drawing
中拉机intermediate wire drawing machine
中拉机、大拉机 coarsewire drawing machine
粗-细线拉线机、中拉机 coarse-fine wire drawingmachine
多根拉线-退火-束线机组 multi-wire drawing-annealing-bunching line
四节距束线机 fourtwist bunching machine
双节距束线机 doubletwist buncher
双节距束线机double-twist bunch strander
双节距[双倍]束线机 double-twist bunching machine
双节距高速束线机double-twist laying-up machine
复合束线、复[混[合束线 compound bunch
磨光机、束线机buffing machine
束线、束绞、束线 bunch
束线、束绞bunch-strand
束绞铜束线bunch-stranded copper conductor
束线、绞合线 bunchedwire
束线机 buncher
束线机 bunchingmachine
灌注 potting
双面双层十六头纱包机 16-head double-side douoble-rosette cotton covering machine
立式双层鼓轮vertical double draft bull block
双层挤出(机)头 twin (extruder) head
双层鼓轮拉线机 twincapstan drawing machine
双头挤出、双层挤出twin-head extrusion
双层的 twin-layer
双层环氧漆包圆铜电磁线heavy epoxy-coated round copper magnet wire
泡沫皮绝缘、泡沫/实心双层绝缘 foam skin insulation
双层编织机 doubletier type braiding machine
双层钢丝铠装 doublewire armour
双层钢丝铠装电缆double wire-armoured cable
双层编织的double-braid
双层编织式外导体同轴电缆double-braid type coaxial cable
双层鼓轮拉线机double-capstan wire drawing machine
双层滚筒六头拉线机double-deck 6 head type machine
双层鼓轮double-deck bull block
双层拉线鼓轮double-deck drawing block
双层绝缘的double-insulated
双层的 double-layer
双层纸 double-plypaper
双丝包的、双层丝绝缘double-silk covered
泡沫/实心双层绝缘、泡沫绝缘 dual expanded plasticinsulation
双层挤出机 dualextruder
双层绕包头 duallapping head
双层的 duplex
双层纸 duplexpaper
双层护套、焊接的皱纹金属管护套 duplex sheath
双层绕包头duplicate lapping head
双层铠装 doublearmo(u)ring
双层鼓轮 doubleblock
双层鼓轮拉线机 doubleblock drawing machine
双层拉线鼓轮 doubledeck drawing capstan
双层环氧漆包圆铜电磁线double epoxy-coated round copper magnet wire
双层绝缘导线 doubleinsulated condutor
双层钢带铠装d.s.t.a.(double layer of steel-tape armour)
双层护套电缆的内护套直径DOIJ
单层纸 simplexpaper
单层的single-layer
单层纸 single-plypaper
单层 monolayer
单层甲板大帆船 galley
管绞机 tubularstrander
光纤拉丝 optical fibredrawing
拉丝乳剂 drawingcompounds
拉丝润滑剂 drawinglubricants
拉丝用皂 drawingsoaps8
拉线、拉丝 wiredrawing
拉线模、拉丝模 wiredrawing die
拉丝润滑剂 wiredrawing lubricant
拉线机、拉丝机 wiredrawing miller
拉丝、拔丝wire-draw
拉丝机、拉丝工 wire-drawer
拉丝架[机] wire-drawing bench
拉丝设备[车间] wire-drawing plant
拉丝、拔丝wireddrawing
拉丝模(板) wortle
钻石拉丝模超声抛光ultrasonic diamond die polishing
钻石拉丝模超声抛光装置ultrasonic diamond die polishing unit
超声波拉丝模打孔机ultrasonic drawing die drilling machine
超声波拉丝模加工机ultrasonic drawing die working machine
超声波拉丝机ultrasonic drawing machine
碳化钨(拉丝)模、硬质合金(拉线)模 tungsten-carbide(drawing) die
滑移式拉丝[线]机 slip drawing machine
拉丝溶液solution-drawing
单道拉丝 singledraft drawing
单模拉丝机 singledraft drawing machine
单道拉丝single-pass drawing(光纤)拉丝机 pullingmachine
拉丝模孔光洁度profiloscope
光纤拉丝塔 opticalfiber drawing tower
光纤拉丝机 opticalfibre drawing machine
多头拉丝、多模拉丝multiple drawing
多模拉丝机 multipledrawing machinen-
模连续拉丝机 n-diecontinuous wiredrawer
高性能拉丝生产线 highperformance drawing line(拉丝模的)研磨 grinding
光纤拉丝系统 fiberdrawing system
光缆拉丝机 fiberpulling machine
光纤拉丝机fiber-pulling machine
双列[双重]拉丝机 double row wire drawing machine
拉丝[线]机]、拔杆机 drawbench
拉丝机、拔杆机、拔管机drawbench
拉丝(润滑液)槽 drawing batch
拉丝[线]机、拔杆机 drawing bench
拉丝润滑剂 drawingcompound
拉丝塔轮、拉线鼓轮drawing cone
拉丝设备 drawingequipment
拉丝[线]润滑液 drawing fluid
拉丝[线]润滑液 drawing oil
拉丝[线]润滑液 drawing solution
拉丝模具 drawingtool
拉丝配模、配模 diesarrangement
直接拉丝 directdrawing(拉丝模)模座 die holder
塔轮式拉丝[线]机 cone-type drawing machine
拉丝模、拉丝机 bullblock
拉丝机、拉丝模bull-block
拉丝模、拉丝机bullblock
防滑动拉丝机anti-slipping drawing machine
立式单模大拉机、立式鼓轮vertical bull block
粗拉机、大拉机、开坯机rod breakdown machine
大拉rod-breakdown
大拉机 largedrawing mill
卧式单模大拉机、卧式鼓轮horizontal bull block
大拉机 heavydrawing machine
大拉 heavy roddrawing
大拉机 heavy roddrawing machine
拉线鼓轮、大拉机drawing block
大拉 coarsedrawing
单模大拉机 bulldrawing block
大拉机 bardrawblock
小拉机 fine wiredrawing
细拉mini-drawing
细拉机mini-drawing machine
细拉 mini-finedrawing
细拉 finedrawingvt
拉细丝、细拉finedraw
细拉机 finishingblock(铜杆)剥皮 shave
铜杆剥皮 shavingof copper rod
铜杆的压延 rollingof copper rod
圆铜杆 roundcopper rod
电工用圆铜杆 roundcopper rod for electrical purpose
热轧铜杆hot-rolled copper rod
铜杆 copper bar
铜杆、(电缆头用)铜出线梗、接线柱 copper rod
铜杆剥皮机 copperrod descaler
铜杆拉出 copperrod withdrawal
控制电缆 controlcables
自动带宽控制 ABC
断线控制系统 wirebreak control system
线张力控制 wiretension control
线张力控制仪、紧线器wire tensioner
电压控制 voltagecontro
扭力控制装置 torsioncontrol equipment
热液控制、液体控温(法) thermal liquid control
厚度(控制)仪、测厚仪 thickness gage
色调控制孔径toll-control aperture
带子张力控制 tapetension control
温度控制[调节] temperature control
液体控温(法)、热液控制 temperature control by a liquid medium
温度控制仪temperature control meter
张力控制[调节]装置 tension control device
张力控制装置 tensioncontrol unit
张力控制仪tensioner
测试线、控制[操作、监视]线 testing conductor
严格控制[检验、检查] strict control
严格控制[检验、检查] stringent test
监督、检验、检查、控制supervision
电场控制[调整]、应力控制 stress control
应力控制带 stresscontrol tape
应力控制管 stresscontrol tubing
电[磁]场控制的、应力控制的 stress-controlling
严格检验[检查、控制] severe control
严格检验[检查、控制] severe test
控制线路用多芯用电缆、船用控制电缆 shipboard multicore cable for control circuits
硅管外径控制器 silicatube outer diameter controller
设定值、控制点setpoint
严格检验[检查、控制] rigid test
严格检验[检查、控制] rigorous test
自动控制收线装置 robottake-up
垂度控制 sagcontrol
垂度控制器 sagcontroller
垂度控制环sag-control loop
调节[控制]范围 regulating range
调节[整]器、控制器 regulator
按扭控制[操纵] push-button control
质量控制[检验] quality control
质量检验[控制] quality inspection
生产过程控制、程序控制process control
工序控制检验 processcontrol inspection
生产过程控制production control
程序控制 programmecontrol
控制导线、辅助芯线pilot
控制线芯、监视线芯pilot conductor
导引绝缘线芯、控制线芯、监视线芯 pilot core
控制线、操作线 pilotline
压缩空气控制pneumatic operation
氢氧焰温度控制器oxyhydrogen flame temperature controller
控制板[配电盘]开关装置 panel switching equipment
操作台、操纵盘、控制板operator panel
操作台、控制台operator's desk
噪声控制装置 noisecontrol equipment
非接触式线径控制仪non-contact diameter monitor
微处理机控制话缆四线组测试仪microprocessor telephone quad tester
监测器--电容量控制 monitor-capacitance control
监督、检验、检查、控制monitoring
灯光显示控制luminous control panel
生产过程控制manufacturing control
流量控制器 massflow controller
柔软云母材料flexible mica material
软管;套管sleeving(
柔软)复合材料;复合箔 combined (flexible)material
软化温度;软化点softening temperature;softening point
软电缆 BX cable
屈服[流动、软化、击穿]点 yield point(YP)
屈服强度、软化强度yield strength
乙烯绝缘软电缆 vinylcabtyre cable
耐水软线water-resistan cord
热塑流试验、软化击穿试验thermoplastic flow test
三芯电力软线 threeconductor power cord
三芯软线three-core cord
三芯软线 three-waycord
镀锡软铜绞线 tinedsoft copper stranded wire
箔软线、塞线 tinselcord
电话软线 telephonecord
电信软件 telesoftware
电源软线 supplycord
交换机电缆[塞子软线] switchboard cable
退火(软)线 soft annealed wire
退火、韧炼、软化退火soft annealing
软电缆 soft cable
软陶瓷绝缘电磁线 softceramic insulated magnet wire
软涂层 softcoating
软拉 soft drawn
软或退火铜线、软铜线soft or annealed copper wire
箔软线、塞线 tinselcord
电话软线 telephonecord
电信软件telesoftware
电源软线 supplycord
软电缆 soft cable
软涂层 softcoating
软拉 soft drawn
软橡胶 softrubber
软链段 softsegment
软焊料钎焊、锡焊 softsoldering
退火铜线、软铜线soft-annealed copper wirev
软焊料钎焊、锡焊soft-solder
软化剂 softener
软化 softening
软化剂 softeningagent
软化[退火]装置 softening plant
软化点 softeningpoint
软化区、增塑区softening region
软钎焊(缝、点、头) soldered joint
软钎焊(缝、点、头) soldering joint
扁形(软线)接头 spade tag
扇形(软线)接头 spade terminal
螺旋芯软线、有弹簧的塞绳spiral-conductor flexible cord
星绞四芯软电缆spiral-four cable
星绞四芯软电缆spiral-four type cable
船用软同轴电缆shipboard flexible coaxial cable
爆破[放炮]用软线 shot-fire cord
镀银软或退火铜线、镀银软铜线silver-coated soft or annealed copper wire
单线软绳single-wire cord
可收缩软线、弹簧线retractile cord
橡套软电缆 rubberjacketed flexible cable
橡胶素炼机、软胶机rubber-homogenizer
软拉 s.d.(softdrawn)
游览车用软线recreational-vehicle cord
预装配的软电缆pre-assembled flexible cable
预装配的软电缆及软线pre-assembled flexible cables and cords
精密排列的扁形软电缆precision-tiered flat flexible cable
抽头、引线、软导线pigtail
超软细股线 pigtailwire
塑料护套软线plastic-sheathed flexible cord
移动式软线 portablecord
普通塑料护套软线 ordinaryplastic-sheathed flexible cord
普通型耐磨橡套软电缆ordinary tough-rubber sheathed flexible cable
普通耐磨橡套软线ordinary tough-rubber sheathed flexible cord
普通聚氯乙烯护套软线ordinary(PVC-)sheathed flexible cord
耐油软线 oil-proofcord
耐油软线oil-resistant cord
光纤软线 optical fibercord
多芯软线 multicorecord
多芯软线 multiplecord
网络软件 networksoftware
镀镍软或退火铜线、镀镍软铜线nickel-coated soft or annealed copper wire
麦克风[话筒]软线 microphone cord
麦克风[话筒]软线 mike cord
移动房屋用软线mobile-home cord
定型设计的电话软线、弹簧电话软线 modular telephone cord
防潮双绞软线moisture proof twisted cord
单塞绳、单软线monocord
低温柔软性 lowtemperature flexibility
低漏泄电流用户软线low-leakage-current service cord
轻型塑料护套软线 lightplastic-sheathed flexible cord
轻型聚氯乙烯护套软线light(PVC) sheathed flexible cord
电灯(软)线 lamp cord
铅合金包覆软铜线lead-alloy-coated soft copper wire
铅包软铜线lead-coated soft copper wire
仪器用软线[塞绳] instrument cord
绝缘软线 insulatedflexible wire
综合软件integrated software
高温软线high-temperature flexibles
素炼机、软胶机homogenizing roller
软管、橡皮管 hose
苛刻条件用软线hard-service cord
耐热护套软电缆heat-resistant sheathed flexible cable
重型耐磨橡套软电缆heavy tough-rubber sheathed flexible cable
玻璃丝绝缘软线glass-fiber-insulated flexibles
馈电软线 feed cord
一级软线 firstclass flexible cord
扁形软电缆 flatflexible cable
扁形双芯软线 flattwin flexible cord
扁形双芯软线[塞绳] flat twin tinsel cord
软线 flexconductor
柔软性flexibility
柔软度试验flexibility test
柔软的 flexible
软电缆 flexiblecable
矿工帽灯用软线flexible cable for miners' cap lamps
软接线 flexiblecircuit conductor
软导体、柔软导体、软线flexible conductor
软线、连接塞绳flexible cord
电缆软接头 flexiblejoint
移动式电力软线flexible portable power cord
电力软线 flexiblepower cord
软绞线 flexiblestranded conductor
软绞线 flexiblestranded wire
软[花、皮]线 flexible wire
软线布线 flexiblewiring
软线、软绳flexibles
弹性[延伸]软绳 extension cord
特软绞线 extra-flexiblestranded conductor
极苛刻条件用软线双芯软线[塞绳] double conductor cord
软化击穿cut-through
耐切通性、切通强度、耐软化击穿性能 cut-through resistance
切通温度、软化击穿温度cut-through temperature
切通试验、软化击穿试验cut-through test
连接塞绳、软线connecting cord
铜芯聚氯乙烯绝缘平型软线copper conductor PVC-insulated parallel flexible cord
铜芯聚氯乙烯绝缘绞型软线copper conductor PVC-insulated twisted flexible cord
软线[绳]、电线电缆、塞绳 cord
花线、装饰线路用软线cord for decorative chains
带有插塞的电话软线 cordsetextra-hard-service cord
成套塞绳、带有插塞的电话软线彩色软线 colour cord
通信软件communication software
锥形软模具 cone-shapedflexible die
同轴软线、同轴线塞绳coaxial cord
螺圈形软线 coiledcord
橡皮绝缘(软)电缆、橡套[软件]电缆 cabtyre cable
橡套电缆、软管电缆cabtyre sheathed cable
配套软件 bundledsoftware
软管电缆 cab-tirecable
橡皮绝缘软线〔软塞绳〕cab-tyre cord
电缆软接头 cableflexible joint
软连接用电缆 cablefor flexible connections
电缆软管 cablehose
电缆软管夹托架 cablehose clamp bracket
编织软绳 braidedflexible cord
退火、韧炼、软化anneal
屈服[流动、软化、击穿]点 YP(yield point)
柔软控制电缆FCC(flexible control cable)
硬链段与软链段的嵌段共聚物HYTREL
挤出机 extruders
挤出 extrusion
挤气式挤出机 ventextruder
通用回转式挤出机versatile turret extruder
立式连续挤出硫化机组vertical continuous extruding and vulcanizing machine
立式挤出机 verticalextruder
立式挤出 verticalextrusion
二段式挤出机two-stage extruder
三层挤出机 tripleextruder
三层挤出(机)头 triple extruder head
三层挤出(机)头 triple extrusion head
双螺杆挤出机twin-screw extruder
三层挤出绝缘电缆three-layer extruded cable(挤出机)模嘴、模芯、末端 tip
挤出物料的脱节starving of extrudate flow(挤出机)送料螺杆stockscrew
滤网<挤出机的> strainer
剪切式挤出机头shear-type extrusion head
护套挤出机 sheathingmachine
防串话环 crosstalkdamping ring
串音干扰 crosstalkdisturbance
串音[串话]因数 crosstalk factor
串音[串话]干扰 crosstalk interference
串音水平 crosstalklevel
串音损耗 crosstalkloss
串音测试装置crosstalk measuring set
串音测试仪crosstalk meter
串音噪声 crosstalknoise
串音路径 crosstalkpath
串音原理 crosstalkprinciple
串音防卫度crosstalk ratio
串音信号 crosstalksignal
串音理论 crosstalktheory
串音传输当量、串音衰减crosstalk transmission equivalent
经由第三回路的串音crosstalk via tertiary circuit
串话音量 crosstalkvolume
无串音特性crosstalk-free characteristics
串音频率特性 crosstalk-frequencycharacteristics
无串音的crosstalk-proof
连续拉线-退火机组、串列式退火机 continuous wire drawingand annealing
路际串音 channelcrosstalk
级[串]联、级联电路 cascade connection
级[串]联式冷却器 cascade cooler
电缆串音极限 cablecrosstalk limit
十六锭台式编织机16-carrier bench braiding machine16
锭高速编织机16-carrier high speed braider
十六锭高速编织机16-carrier high-speed braiding machine24
锭高速编织机24-carrier high speed braider
金属编织、金属丝编织wire braid
金属丝编织机、金属丝织机wire braiding machine
编织套、电缆屏蔽套wired tube
编织电缆 wovecable
编织电缆 wovencable
镀锡铜线编织 tinnedcooper braid
镀锡铜丝编织带[层] tinned copper braid
镀锡铜丝编织屏蔽tinned copper braid shielding
镀锡铜丝编织带[层] tinned copper mesh
镀锡铜丝编织带 tinnedcopper mesh(ed)
纤维编织、纱编织textile braid
金属丝编织带 textiletape with interwoven metal wires
钢丝编织 steelwire braiding
扁编织导线 strapbraided conductor
编织套[层]、套管 sleeving
防噪声编织机 soundenclosure braiding machine
屏蔽编织(层)、编织屏蔽(层) shieldedbraid
屏蔽编织 shieldingbraid
丝编织线 silkbraided wire
镀银铜线编织屏蔽(层) silver plated copper wire braidedscreen
单头编织机 single-headbraiding machine
编织层的浸渍saturation of braid(编织机)剪模 scissor die
屏蔽编织(层)、编织屏蔽层 screening braid(编织机)右旋侧架right-hand side frame
加强编织(层) reinforcing braid(编织机的)面板 race plate
编织覆盖率percentage of braiding coverage
编织机的]摆动臂 osciliating arm
金属(丝)编织 metal braiding
金属丝编织电缆metal-braided cable
金属(丝)编织(层) metallicbraid(编织机)左转侧架 left-hand side frame
束(绞)线、编织线 litz wire
束(绞)线、编织线 litzen wire
束(绞)线、编织线 litzenwire
束(绞)线、编织线 litzwire
编织机 loom
编织机 knitter
针织式编织机knitting machine
编织线芯超导体lattice braided supperconductor
编织节距 lay ofbraiding
高密度编织屏蔽high-density braid shield
高速编织设备high-speed braiding equipment
高速编织机high-speed braiding machine(编织机的)喇叭状齿轮 horngear
玻璃丝编织(层) glass coated micro wire
全自动双头编织机 fullautomatic dual-head braider
玻璃丝编织线fiber-glass braid wire
编织物 fabrictape
铜丝编织带 fabrictape with interwoven copper wire
双层编织的double-braid
双头编织机dual-head braider(编织机)模臂 die arm
棉纱编织(层) cotton braid
棉纱编织 cottonbraiding
棉纱编织机cotton-yarn braiding machine
铜丝编织屏蔽 copperbraid shielding
铜编织线 copperbraided wire
铜丝编织 copperbraiding
铜丝编织带 coppermesh tape
铜丝编织带 copperthreaded textile tape
铜线编织(层) copper wire braid
铜丝编织 copperwire braiding
铜丝编织屏蔽copper-mesh screen
铜丝编织屏蔽copper-mesh shield
布、编织物 cloth
玻璃丝编织尼龙护套电缆cable with glass braid and nylon finish
电缆编织机 cablebraider
电缆编织机 cablebraider machine
电缆编织机 cablecovering machine
编织、编织层 braid
编织角 braidangle
铜芯编织电缆 braidcable with copper conductor
编织同轴屏蔽 braidcoaxial shielding
编织导线 braidconductor
编织点 braidpoint
编织屏蔽电缆 braidshielded cable
编织线 braid wire
编织电缆braid-covered cable
编织导线 braidedconductor
铜丝编织屏蔽 braidedcopper screen
棉纱编织层 braidedcotton covering
编织屏蔽 braidedshield
编织线 braidedwire
编织屏蔽电缆braided-shiled cable
编织机 braider
编织 braiding
编织角 braidingangle
编织头 braidinghead
编织机 braidingmachine
编织机锭子 braidingmachine carrier
钢丝编织 braidingmachine for steel wire
编织车间 braidingworkshop
编织涂蜡braiding-impregnating
裸铜丝编织 barecopper braiding
氟化乙烯丙烯绝缘玻璃或石棉编织线 FEP insulated wire with glass or asbestos braid
氟化乙烯丙烯绝缘玻璃或石棉编织线 FEPB(fluorated ethylene-propylene insulated wire with glass orasbestos braid)
皱纹铝护套corrugated alumnimum sheath
热缩护套 the heathshrinkable sleeves
护套 jacket
铅护套 Leadsheath
外护套 outersheath
护套 sheathing
铝-聚乙烯粘接护套 APL sheath
铝-树脂-聚乙烯-铝-聚乙烯综合护套 ARPAP type sheath
铝-钢-聚乙烯综合护套 ASP sheath4
铝-聚乙烯综合护套电缆 Alpeth cable
铝-聚乙烯综合护套 Alpeth cover
铝-聚乙烯综合护套电缆 Alpeth sheathed cable
铝-聚乙烯综合护套 Alpeth-sheath
焊接皱纹钢带护套welding corrugated steel sheath
护套起皱 wrinkleof jacket
壁厚、绝缘[护套]厚度 wall thickness
内护套、内护层undersheath
硬橡皮电缆护套 toughrubber cabtyre sheath
高频熔焊皱纹金属护套toughlex sheath
挤包绝缘或护套 tubing
双活塞电缆护套挤压机 twin-ramcable sheathing press
热塑性氯化聚乙烯护套thermoplastic chlorinated polyethylene jacket
热塑性塑料绝缘及护套电缆thermoplastic insulated and jacketed cable
剥除电缆护套 tostrip the cable sheath
夯实、捣固、铅护套扩张试验tamping
丁苯合成橡皮护套styrene-butadiene synthetic rubber jacket
在接头处护套互联的电缆系统system with the cable sheaths connected across the joints
内护套、内护层undersheath
挤包绝缘或护套 tubing
双活塞电缆护套挤压机twin-ram cable sheathing press
钢-铝-聚乙烯综合护套电缆 stalpeth cable
钢-铝-聚乙烯护套 stalpeth cover
钢-铝-聚乙烯综合护套 stalpeth sheath
钢-铝-聚乙烯综合护套电缆 stalpeth sheathed cable
钢-铝-聚乙烯综合护套 stalpeth-sheath
钢护套 steelsheath
光护套、光滑护套smooth sheath
光滑铝护套smooth-profile aluminium sheath
光滑护套电缆smooth-sheathed cable
护层、护套 sheath
护套轧纹 sheathcrimping
护套偏心监控仪 sheatheccentricity monitor
护套涡流损耗系数sheath eddy current loss factor
护套绝缘环 sheathinsulating ring
护套损耗 sheathloss
护套损耗 sheathlosses
护套结构 sheathmake-up
护套加固箍 sheathreinforcing bandage
护套的接续 sheathsplice
护套的接续 sheathsplicing
护套加强元件、护套加强单元sheath strength member
护套剥除机、剥护套机sheath stripping machine
护套表面 sheathsurface
护套厚度 sheaththickness
护套换位 sheathtransposition
护套(内)壁 sheath wall
护套壁厚 sheathwallthickness
护套线、被覆线 sheathwire
护套电缆 sheathedcable
固定布线用护套电缆sheathed cable for fixed wiring
护套线、被覆线sheathed wire
挤[包]护套、护套 sheathing
护套混合物[料] sheathing compound
护套挤制生产线sheathing line
护套挤出机sheathing machine
护套材料 sheathingmaterial
护套试样 sheathingtest-piece
护套线、被覆线sheathing wire
护套颜色 sheatingcolor
护套工段 sheatingdepartment
单护套 singlesheath
单芯电缆(有或无护套) single-core cable (with orwithout sheath)
内部配线用单芯无护套电缆、布线电缆 single-core non-sheath cable for internal wiring
有护套的单芯导线single-core sheathed conductor
单护套电缆single-jacketed cable
聚乙烯密封护套sealpeth sheath
自粘性外护套self-bonding overcoat
护套剥离绳 rip cord
橡皮绝缘护套 rubberinsulating blanket
橡皮护套、橡套 rubbersheath
加固型铅护套reinforced lead sheath
增强型护套reinforced sheathv
剥除(绝缘、护套)、拆卸 remove
铝护套电力电缆 powercable with aluminium sheath
抗压力护套pressure-retaining sheath
护套 protectivejacket
护套、护层protective jackte
护套 protectivesheath
平[光]滑护套 plain sheath
塑料护套 plasticsheath
塑料护套厚度检测装置plastic thickness test unit
塑料[非金属]护套电缆 plastic-sheathed cable
氯丁橡胶护套电缆polychloroprene sheathed cable
聚乙烯护套polyethylene jacket
聚乙烯护套料polyethylene jacking compound8
聚乙烯护套料polyethylene sheating compound
聚乙烯护套电缆polyethylene-jacketed cable
铅-聚乙烯综合护套 polyethylene-protected leadsheath
聚乙烯铝膜粘接护套polyethylene/aluminium bonded laminate sheath
聚乙烯护套电缆polythene jacketed cable
聚乙烯绝缘聚氯乙烯护套电缆polythene-insulated cable sheathed with PVC
聚氯乙烯绝缘及护套电缆polyvinyl chloride insulated and sheathed cable
聚氯乙烯护套polyvinyl chloride jacket
护套的透潮permeation through jacket
普通塑料护套软线ordinary plastic-sheathed flexible cord
聚合物外护套 outerpolymeric sheath
外护套 outersheath
外护套 outershell
外护套、外护层overcoat
外护套、外护层oversheath
耐臭氧乙丙橡胶护套ozone-resisting ethylene propylene rubber jacket
包套、外护套 packagesheathing(
油浸)纸绝缘铅护套电缆 paper-insulatedlead-covered cable(
油浸)纸绝缘铅护套电缆 paper-insulatedlead-sheathed cable
纸绝缘金属护套电缆paper-insulated metal-sheathed cable
非金属护套non-metallic sheath
非金属护套电缆non-metallic-sheathed cable
无护套电缆non-sheathed cable
固定布线用无护套电缆non-sheathed cable for fixed wiring
非金属护套nonmetallic covering
尼龙护套电缆 nylonjacketed cable
尼龙护套光纤nylon-jacketed optical fiber
纸绝缘金属护套充油电缆oil-filled paper-insulated metal-sheathed cable
多层护套(北美采用) multilayered jacket
多层护套multilayered sheath
多层护套、层式护套multiple sheath
天然橡胶护套 naturalrubber jacket
金属护套 metalsheath
金属护套电缆metal-sheathed cable
铜芯矿物绝缘铜护套电缆mineral-insulated copper-sheathed cable with copper conductor
防潮护套 moisturebarrier jacket
防潮护套 moisturebarrier sheath
氧化镁绝缘金属护套电线magnesia-insulated metal sheathed wire
聚乙烯-铅综合护套层、铅-聚乙烯综合护套 lepeth
铅-聚乙烯综合护套电缆 lepeth cable
铅-聚乙烯综合护套电缆 lepeth-sheath cable
轻型聚氯乙烯护套电缆light PVC-sheathed cable
浅色护套light-colored jacket
铝-聚乙烯粘接护套 laminatedaluminum-polyethylene sheath
金属护套 metalsheath
铜芯矿物绝缘铜护套电缆 mineral-insulatedcopper-sheathed cable with copper conductor
层式护套、多层护套、薄层粘接护套 laminated sheath(
层状)粘接[结]带、金属-塑料综合护套用复合带 laminated tape
压铅机、电缆铅护套挤压机lead cable-sheathing press
压铅机、铅护套挤压机lead press
铅护套变形 leadsheath strain
铅护套、铅包 leadsheathing
铅合金护套lead-alloy sheath
铅合金护套lead-alloy sheathing
铅合金护套电缆lead-alloy-sheathed cable
铅-聚乙烯综合护套 lead-polyethylenev
挤压[挤包]铅护套、压铅 n
铅(护)套、铅护套 lead-sheath
铅护套挤压机、压铅机lead-sheathing press
内护套(北美采用) inner jacket
挤压[挤包]铅护套、压铅 n
绝缘与护套挤包设备insulating and jacketing plant
绝缘捩护套材料insulating jacketing material
护套(在北美、 sheath
仅指金属包覆层)、护层、外壳 jacket
护套渗漏 jacketleak
护套剥除工具 jacketremoval tool
护套、包护层 jacketing
护套 jacking
护套印字机 jackingmachine
聚氯乙烯绝缘单芯无护套高温电缆 high temperature PVC insulated single-core non-sheathed cable
高折射率护套higher-index jacketing
液压连续式电缆护套挤压机hydraulic continuous cable-sheathing press
无卤素护套材料halogen-free sheathing material
无卤护套halogon-free jacket
重型丁腈/聚氯乙烯护套 heavy-dutyacrylonitrile-butadiene/polyvinyl chloride(NBR/PVC) jacket
重型氯化聚乙烯护套heavy-duty chlorinated polyethylene(CPE)jacket
通用单芯无护套电缆general purpose single-core nonsheathed cable
通用丁腈/聚氯乙烯护套 general-purposeacrylonitrile-butadiene/polyvinyl chloride(NBR/PVC) jacket
通用氯化聚乙烯护套general-purpose chlorinated polyethylene(CPE) jacket
通用乙丙烯橡皮护套general-purpose ethylene-propylene rubber jacket
聚乙烯-铝带综合护套 glovar sheath
卷边[摺边]铝护套 folded aluminium sheath
卷[摺]边铝护套 folded aluminium shield
铝护套锉削 filingof the aluminium sheath(for jointing)
阻燃护套flame-retardant jacket
超重型黑色氯化聚乙烯护套extra-heavy-duty chlorinated polyethlene jacket
挤制铝护套 extrudedaluminium sheath
电缆上挤包护套extrusion of the sheath on to the cable
厚度均匀<绝缘、护套等> equithickness
双护套 doublesheath
双活塞电缆护套挤压机double-acting cable sheathing press
双护套光纤double-jacketed optical fiber
双活塞电缆护套挤压机double-ram cable sheathing press
双护套电缆double-sheathed cable
双护套电缆 dualjacketed cable
偏心(率、度)<绝缘、护套> eccentricityv
、 n(
管子或护套的)减径 die-downv(
金属护套的)减径 die down
皱纹铝护套corrugated aluminium sheath
皱纹铝护套电缆corrugated aluminium-sgeathed cable
皱纹铜护套corrugated copper sheath
皱纹无缝护套corrugated seamless sheath
皱纹护套corrugated sheath
皱纹钢护套corrugated steel sheath
皱纹钢护套电缆corrugated steel-sheathed cable
护套的龟裂 crackingof jacket
电缆护套的交叉连接[粘接] cross-bonding of cable sheaths
交联氯化聚乙烯护套crosslinked chlorinated polyethylene jacket
交联氯磺化聚乙烯护套crosslinked chlorosulfonated polyethylene jacketv
剥除(绝缘、护套) cut back
电缆护套损伤[损坏] damage to the cable sheath
外护套containment
连续式电缆护套挤压机continuous cable sheathing press
铜带屏蔽尼龙外护套电缆copper tape screen nylon jacketed cable
铜护套电缆copper-sheathed cable
皱纹护套电缆 cormexcable
电缆护套轧纹 v
轧纹 corrugate
耐寒护套 cold-proof sheath[saman4213 在 2011-2-28 9:34:27 编辑过]
wire milling - 线材轧制 (0) 投诉
