首页 > 辐照 紫外 蒸汽交联
[紫外交联] 防UV(紫外线)线材用什么对应的标准?
P:2011-02-17 14:52:31
客人要求网络线要能防UV(紫外线),想问一下要用什么对应的标准?
知道电源线或UL1581中的一个Sunlight resistant(耐日光测试),具体是用carbon-arc exposure or xenon-arc exposure(碳弧或氙弧测试)
请问Sunlight resistant(耐日光测试)是不是防UV(紫外线)测试。不是的话要用什么标准?
谢谢!
short-circuit - 短路 (0) 投诉
P:2011-02-17 19:00:13
找客人要标准,他会要求你做几级测试.
swinging arm - 转臂,旋转臂,摆杆 (0) 投诉
P:2011-02-21 09:17:40
zhouwei:
找客人要标准,他会要求你做几级测试.
是联欣zhouwei吗?
elliptical optical fiber - 椭圆形光纤 (0) 投诉
P:2011-02-21 09:27:15
NO
optical fiber/electric power composite cable - 光纤/电力复合电缆 (0) 投诉
P:2011-02-21 11:21:25
hhsheng:
是用什么进行辐照呀?
aluminium press - 压铝机 (0) 投诉
P:2011-02-21 11:58:43
氙弧灯 高温高湿 轮换
high-speed bandmarking - 高速带式标志 (0) 投诉
P:2011-02-21 13:39:43
hhsheng:
氙弧灯 高温高湿 轮换
氙弧属于紫外线吗?
dual over-end pay-off - 双盘越端放线(装置) (0) 投诉
P:2011-02-21 13:51:10
模拟紫外线
hook-up wire - 布线用电线,安装线,跨接线,柔软连接线<如电话机上用的线等,最常见者为电子设备之内部接线,前面曾提及之UL 1007,UL 1015 皆属之。 (0) 投诉
P:2011-02-22 13:15:45
7.22 Sunlight resistant test
Any cable that is marked for sunlight-resistant use as described in Clause 8.3.8 shall be considered
acceptable for use in sunlight if the ratio of the average tensile strength and ultimate elongation of five
conditioned specimens of the overall jacket to the average tensile strength and ultimate elongation of five
unconditioned specimens of the overall jacket is 0.80 or more, when the finished cable is conditioned and
tested in accordance with the Weather (Sunlight) Resistance Test in CSA C22.2 No. 2556 or UL 2556,
using 720 h of carbon-arc exposure, or xenon-arc exposure.
UL444要求的测试,可参考UL2556
ASTM - American Standard of testing materials美国材料试验标准 (0) 投诉
P:2011-02-22 16:46:30
以前不知道哪找到的, 看看能不能帮到你.
signaller - (陆军或海军的)信号兵,信号手 (0) 投诉
P:2011-02-22 19:58:57
一直都搞不明白,耐日光和抗UV是否是一样?
upward continuous casting system - 上引法连铸机组,上引法连续浇铸机组 (0) 投诉
P:2011-02-23 17:58:00
不一样。。
SZ twinning/quadding machine - SZ双绞-四线组绞制机 (0) 投诉
P:2013-07-30 10:04:13
有国标或IEC的抗紫外线标准吗
far-end cross talk - 远端串音 (0) 投诉
P:2015-06-30 13:30:12
学习学习学习
copperbasis - 铜基 (0) 投诉
