首页 > 国外线缆
[技术资料] UL 3075 标准
P:2011-02-15 11:22:29
UNDERWRITERS LABORATORIES, INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 3 Page 3075 Issued: May 1, 1959
Revised: Oct. 26, 2000
Style 3075 Silicone Rubber-Insulated Wire.
______________________________________________________________________________
Rating 200°C, 600 Volts
Conductor No. 10 AWG Solid or Stranded of Nickel or Copper. All
Copper shall be Tin, Nickel or silver Coated. If tinned
Copper strands are used they shall be No. 26 AWG or
* larger.
Insulation Nominal 3/64 inch wall silicone rubber, Class 22
Covering Same as for Type SF-2 Fixture Wire.
*Standard Appliance Wiring Material UL 758.
Instructions Same as for Type SF-2 Fixture Wire but omit Insulationto
UL Resistance Test, and Vertical Flame Test
*Representative Spark Test
* Flame Test
UL (4) Same as for Type SF-2 Fixture Wire; aging shall be
Counter-Check conducted annually.
Program
*Marking General.
Use Internal wiring of electric clothes, dryers where exposed
to temperatures not exceeding 200°C or Internal wiring of
appliances where exposed to temperatures not exceeding
200°C.
* larger.
* Flame Test
Program
*Marking General.
200°C.
vacuum impregnation - 真空浸渍 (0) 投诉
