首页 > 国外线缆
[国外型号] 求助UL2468标准
P:2011-02-15 11:24:34
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 2 Page 2468 Issued: May 7, 1968
Revised: Jan. 8, 2001
Style 2468 Flat Ribbon-Type Cable.
______________________________________________________________________________
Rating 80°C, 300 Volts.
Conductor 2-150, Nos. 32-16 AWG. Tinned or bare, solid or stranded
* copper, conductors laid parallel and in one plane. Same
or Mixed AWG.
Insulation Each conductor has a nominal 1/64 in. wall or heavier
thermoplastic (PVC). This forms a flat cable with a single
row of conductors having a 1/2 in. maximum width web between
insulated conductors. The nominal and minimum insulation
thickness along the ripped edges for each conductor shall be
15 and 13 mils, respectively.
*Shield Optional.
Covering (Optional) PVC. 5 mils min. at any point 80 mils max.
*Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Tensile Strength and Elongation of Insulation, same as
*Representative for Class 43.
UL (4) Detailed Examination.
*Counter-Check (4) Tensile Strength and Elongation of Insulation.
Program (4) Heat Shock on insulated individuals after separation.
(4) Cold Bend on insulated individuals after separation.
* (4) Horizontal Flame Test on finished cable.
(4) Deformation on insulated individuals after separation.
*Marking General.
Use Internal wiring of Appliances; or internal wiring of
Appliances where exposed to oil at a temperature not
exceeding 60°C or 80°C, whichever is applicable.
or Mixed AWG.
*Shield Optional.
*Marking General.
cold-feed extruder - 冷喂料挤出机 (0) 投诉
