首页 > 线缆设计|参数计算
[物理性能] 求助屏蔽双绞线特性阻抗的计算
P:2011-02-12 09:03:42
导体截面0.75mm2(计算直径1.1mm),PE绝缘厚度0.7mm,对绞之后用厚度为0.3mm的铜丝屏蔽的双绞线,要求特性阻抗是100Ω,而我算的特性阻抗是82Ω左右,谁帮我算下啊,谢谢了!
commissioning test - 投运试验 (0) 投诉
P:2011-02-12 09:23:48
看你屏蔽的类型了,屏蔽类型不一样计算方法不一样的
Prs·km - pairs·kilometer对公里 (0) 投诉
P:2011-02-12 09:34:44
铜丝屏蔽
roller guide - 轧辊导轮 (0) 投诉
P:2011-02-12 09:46:52
我的计算公式是:
<DIV> </DIV><DIV> <DIV class=O v:shape="_x0000_s1026"><DIV>其中: </DIV><DIV>    Zc:特性阻抗 </DIV><DIV>    a:两导体的中心距(mm) </DIV><DIV>    d:中心导体的直径(mm) </DIV><DIV>    Ds:屏蔽层内径(mm) </DIV><DIV>   εe:绝缘材料的等效介电常数 </DIV><DIV>    K3:编织影响的经验修正系数,取值为0.98-0.99 </DIV><DIV>    K1:导体修正系数,导体结构修正系数K1与导体根数之间的关系:        </DIV><DIV> </DIV><DIV> </DIV><DIV>
<DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">绞线内导体的导线根数</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">N</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">1</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">3</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">7</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">12</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">19</DIV>
<DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">内导体结构的修正系数</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">K1</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">1.000</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">0.871</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">0.939</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">0.957</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">0.970</DIV>
<DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">绞线内导体的导线根数</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">N</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">27</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">37</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">50</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">70</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">90</DIV>
<DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">内导体结构的修正系数</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">K1</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">0.976</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">0.980</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">0.983</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">0.986</DIV><DIV style="TEXT-ALIGN: center; mso-line-spacing: '80 20 0'">0.988</DIV>
</DIV><DIV> </DIV><DIV> </DIV><DIV>谁有空帮我看看哪个地方算的不对啊</DIV>
</DIV></DIV>
photoinduced birefringence - 光诱导双折射率 (0) 投诉
P:2011-02-16 14:59:41
沉了 谁抽空帮算下啊
pointing roll - 轧头辊,线头轧尖辊 (0) 投诉
P:2011-09-22 10:00:20
求计算公式
measuring line for medical purposes - 医用测量线路 (0) 投诉
