[同轴电缆] 有谁知道如下几款RG系列同轴线的具体规格?
P:2007-07-31 10:06:10
Technical parameters of commonly-used coaxial cable
型号 Model | No. of wire/O. D. (mm) | O. D. of insulation (mm) | Al foil | shield n/(mm) | O. D. of jacket (mm) | Characteristic impedance (Ω) | O.D. of steel messenger (mm) |
RG59U | 0.65 | 3.7±0.1 | 13×0.04 | 32/48/64/80/96/112/ 128/ 0.12 BC / | 6.0±0.1 | 75Ω±5 | |
RG59U | 0.65 | 3.7±0.1 | 13×0.04 | 32/48/64/80/96/112/ 128/ 0.12 BC / | 6.0±0.1 | 75Ω±5 | 1.20 single |
RG59U | 0.65 | 3.7± 0.1 | 13×0.04 | 32/48/64/80/96/112/ 128/ 0.12 BC / | 6.2±0.1 | 75Ω±5 | |
RG59U | 0.65 | 3.7±0.1 | 13×0.04 | 32/48/64/80/96/112/ 128/ 0.12 BC / | 6.73±0.1 | 75Ω±5 | |
RG58U | 1/0.8 | 2.95±0.05 | / | 32/48/64/80/96/112/ 128/ 0.12 BC / | 4.95±0.05 | 50Ω±3 | |
RG58C/U | 19/0.18 | 2.95 | / | 32/48/64/80/96/112/ 128/ 0.12 BC / | 4.95±0.05 | 50Ω±3 | |
RG6U | 1/1.02 | 4.8±0.10 | 17×0.04 | 32/48/64/80/96/112/ 128/ 0.12 BC / | 7.0±0.1 | 75Ω±5 | |
RG6U | 1/1.02 | 4.8±0.10 | / | 32/48/64/80/96/112/ 128/ 0.12 BC / | 7.0±0.1 | 75Ω±5 | |
RG6U | 1/1.02 | 4.8±0.10 | 17×0.04 | 32/48/64/80/96/112/ 128/ 0.12 BC / | 7.0±0.1 | 75Ω±5 | 1.20 single |
RG6U | 1/1.02 | 4.8±0.10 | 17×0.04 | 32/48/64/80/96/112/ 128/ 0.12 BC / | 7.1±0.1 | 75Ω±5 | |
RG6U | 1/1.02 | 4.8±0.10 | 17×0.04< | 32/48/64/80/96/112/ 128/ 0.12 BC / | 7.54±0.1 | 75Ω±5< | |
RG11U | 1/1.63 | 7.3±0.20 | 25×0.04 | 32/48/64/80/96/112/128/ 0.12 /0.15 BC/AL/TC | 10.3±0.20 | 75Ω±5 | |
RG11U | 1/1.63 | 7.3±0.20 | 25×0.04 | 32/48/64/80/96/112/128/ 0.12 /0.15 BC/AL/TC | 10.3±0.20 | 75Ω±5 | 1.83 single |
FOCIS - 光纤连接器互连标准 (0) 投诉
P:2007-07-31 12:15:35
RG type coaxial cable (UL Style 1354)
Standard:U.S.A.MIL-C-ITD
RG-5/U | 1/1.29 | 4.7±0.20 | 17*0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 8.4±0.20 | 51.5 |
RG-6/U | 1/1.0 | 4.8±0.20 | 17x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 7.0±0.20 | 75.0 |
RG-6/U | 1/1.02 | 4.7±0.20 | 17x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 8.4±0.20 | 76.0 |
RG-6/UR | 7/0.5 | 4.8±0.20 | 17x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 7.0±0.20 | 50.0 |
RG-6A/U | 1/0.724 | 4.7±0.20 | 17x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 8.4±0.20 | 75.0 |
RG-7/U | 1/0.914 | 7.0±0.20 | 25x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 9.4±0.20 | 75.0 |
RG-8/U | 7/0.724 | 7.2±0.20 | 25x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 10.3±0.20 | 50.0 |
RG-10/U | 7/0.724 | 7.2±0.20 | 25x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 12.0±0.20 | 52.0 |
RG-11/U | 7/0.4 | 7.2±0.20 | 25x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 10.3±0.20 | 75.0 |
RG-12/U | 7/0.4 | 7.2±0.20 | 25x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 12.0±0.20 | 75.0 |
RG-13/U | 7/0.4 | 7.1±0.20 | 25x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 10.6±0.20 | 74.0 |
RG-14/U | 1/2.59 | 9.9±0.20 | 34 x0.04 | 32/48/64/80/96/112/0.12 BC/AL/TC | 13.8±0.20 | 52.0 |
CLK - Clock 时钟输入 (0) 投诉
31
