首页 > 国外线缆
[问题求助] UL2464的芯线选UL1015可以在芯线上印字吗
P:2010-12-06 15:45:43
如题<div>求解?</div>
distributing collar - 分线环,排线环 (0) 投诉
P:2010-12-06 15:50:36
当然可以.
degassing kettle - 去气罐 (0) 投诉
P:2010-12-06 15:54:04
我看了UL Style Page页里没有明确要印字,护套印字还是可选的<div>心里没底,所以发帖问问</div><div>谢谢楼上的兄弟
<div>
</div></div>
joint cabinet - 接头盒(一般指光缆的) (0) 投诉
P:2010-12-06 21:05:05
本人觉得1015是可以印,但是常用的105C是不可以印上去的,根据是UL758_12.1
”Insulated conductors with different temperature ratings that are mixed in a given cable complies with
the intent of this requirement when the cable is rated for the lowest temperature rating of any of the
constituent insulated conductors. The insulated conductors shall not be marked with a temperature rating
that is higher than that of the finished cable.“,
上述表明如果芯线的温度比成品线要高,则芯线的温度不可以印!
probability distribution - 概率分布 (0) 投诉
P:2010-12-07 11:45:24
alan79114:
嗯,我理解也是这样.
rubber-covered wire workshop - 橡皮线车间 (0) 投诉
P:2010-12-07 16:14:41
芯线不能印105C,UL758规定“绝缘线芯不得标上比成品电缆额定温度更高的温度”,具体详见UL758 12.1
heavy reel - 重型线盘 (0) 投诉
P:2010-12-09 14:54:55
谢谢各位帮忙
NEP - noise equivalent power噪声等效功率 (0) 投诉
P:2011-11-28 18:40:48
不强制要求印,印也没问题啦,
spinning head - (绳、纱、丝、麻)绕包头 (0) 投诉
P:2011-12-19 11:40:40
可以印
metal-clad aramid fiber - 金属包层芳族聚酰胺纤维 (0) 投诉
P:2011-12-19 11:40:41
可以印
working quality - 加工质量,加工性 (0) 投诉
