[问题求助] 有没有能供电220v及单模光纤,控制信号混传的多芯光电复合缆
P:2010-11-26 23:36:33
如题:
COMPONENT A (4 芯)
PRIMARIES: CONDUCTOR: 导体规格#20 AWG (19/32) TINNED COPPER
INSULATION: PE
NOMINAL DIAMETER: .062” (1.57 mm)
COLORS: (2) BLACK, (2) WHITE
COMPONENT B (2芯)
PRIMARIES: CONDUCTOR:导体规格 #24 AWG (7/32) TINNED COPPER
INSULATION: PE
NOMINAL DIAMETER: .048” (1.22 mm)
COLORS: GRAY, RED
COMPONENT C (2 芯)
FIBER: TYPE: SINGLE-MODE
BUFFER: TYPE: TIGHT BUFFER
MATERIAL: THERMOPLASTIC
DIAMETER: 900 + 50 μm (.035 + .002”)
COLORS: BLUE, YELLOW
因为有光纤可能还需要14awg左右的钢丝加强筋
有哪位能做
copper alloy wire - 铜合金线 (0) 投诉
